G.Skill RipjawsZ F3-14900CL9Q-16GBZL – overclockerski san
Datum objave 09.02.2012 - Krešimir Matanović
Zaključak - Conclusion
Na stranu postoje li stvarni benefiti od četverokanalne memorije, ovaj je G.Skillov kit jednostavno odličan. U ovako robusnoj quad-channel izvedbi i velikog kapaciteta od 16GB uspjeli smo ga natjerati na čak 558MHz višu frekvenciju od one deklarirane XMP profilom. Latencije smo istina dosta opustili, i napon podigli sa 1.5 na 1.65V no i dalje je ovo impresivan rezultat. Uz to, RipjawsZ hladnjaci odlično rade posao i memorija se niti u jednom trenutku ne pregrijava. U našem smo setupu imali lagani protok zraka preko kitova kojeg je stvarao 14 cm ventilator iz Noctue D14 no to ne mijenja činjenicu kako su hladnjaci dobri. Ovoga kita na domaćem tržištu još nema, a na Njemačkom mu se cijena kreće od 116 do 120 €, što je fer cijena za ono što se dobiva. RipjawsZ F3-14900CL9Q-16GBZL stoga po odnosu uloženo/dobiveno zaslužuje najvišu nagradu i svakako je odličan izbor za X79 platformu.
Conclusion
Aside the question if there is any real benefits from the quad channel memory, this G.Skill`s kit is simply great. In this big quad-channel configuration and with high capacity we managed to get it 558MHz above its declared speed in XMP profile. It is true that we had to set a bit loose timings, and raise the voltage from 1.5 to 1.65V but still, this is an impressive result. In addition, RipjawsZ heatsinks are doing a great job and memory does not overheat, even at overclocking. In our setup, we had a light air flow over the modules that was created by 14 cm fan from Noctua D14, but that does not change the fact that heatsinks are doing a good job. This kit is not yet available on Croatian market and in German it`s price ranges from 116 to 120 €, which is a fair price for what you get. RipjawsZ F3-14900CL9Q-16GBZL therefore has great investment/return ratio, and deserves the highest award. It is certainly an excellent choice for the X79 platform.
UPDATE: Čini se kako je kit ipak dostupan na našem tržištu i to po cijeni od 1170 kuna što je čak 35 € više nego u Njemačkoj.
G.Skill RipjawsZ F3-14900CL9Q-16GBZL | |||
Pozitivno + | Overclocking potencijal, komfor koji donosi 16GB, kvalitetna izrada. | ||
Negativno - | Nista posebno. | ||
Ocjena |
Ustupili | G.Skill |
Objavljeno prije 5 minuta
3DMark rezultati i komentariObjavljeno prije 24 minute
Glazbeni servisObjavljeno prije 1 sat
Xbox Series X/SObjavljeno prije 1 sat
Sam svoj majstor - razni radovi po kući/stanuObjavljeno prije 1 sat
P: HDD Ironwolf, sandisk, mob Xiaomi, Yamaha zvučniciNovosti
Elden Ring Nightreign dodaje novu klasu
Elden Ring Nightreign otkriva novu klasu pod nazivom Ironeye, koja nudi preuređeni pristup igranju na daljinu. Iako je Elden Ring Nightreign odvojen od osnovnog naslova Elden Ring, neke od promjena u stilovima igre u ovom spin-offu ostavile... Pročitaj više
FromSoftware najavljuje The Duskbloods
FromSoftware će kasnije ove godine izdati Elden Ring: Nightreign, ali ne znamo mnogo o planovima developera za budućnost. Do danas nije bilo novih igara na vidiku, a Nightreign djeluje više kao spinoff naslov koji povezuje sadašnje vrijeme... Pročitaj više
Potencijalno izlaze još dvije Assassin’ s Creed igre u 2025.
(izvor slike) Assassin's Creed Shadows tek je izašao, ali Ubisoft bi već mogao imati još jednu igru u pripremi. Prema Tomu Hendersonu, glavnom uredniku Insider Gaminga, Codename Invictus "trebao bi" biti lansiran kasnije ove godine. Nije ri... Pročitaj više
Zašto 4G/5G veza troši više baterije vašeg pametnog telefona?
Jeste li ikada primijetili da se baterija vašeg telefona brže prazni kada koristite mobilne podatke nego kada ste spojeni na WiFi mrežu? Postoji li korelacija između pražnjenja baterije i internetske veze putem mobilnih podataka u odnosu na... Pročitaj više
Kako gledati sve utrke Formule 1 uz pomoć VPN-a?
Ako ste kao i mi, veliki ljubitelji motosporta i poglavito Formule 1 tada znate da u Hrvatskoj nije moguće pratiti ovaj sport uživo. Ipak, uz pomoć VPN usloga je moguće pratiti sve treninge, kvalifikacije, utrke kao i dodatan sadržaj na TV... Pročitaj više
