Kingmax DDR2-667 512 MB – zeleno, jeftino, dobro
Datum objave 29.06.2006 - Denis Arunović
Zaključak (conclusion)
Kingmax je ponovo odradio izvrstan posao sa svojom memorijom. Premda ova memorija nema osobite performanse dok je rabimo na SPD postavkama, u stanju je pružiti zaista mnogo svima onima koji se ne overclockanja. Dakako, za to treba imati i solidnu ploču koja je memoriji u stanju pružiti odgovarajući napon. U nedostatku prave DDR2-800 memorije, Kingmax DDR2-667 je vrlo dobra alternativa, no treba imati na umu da vam ova memorija ipak ne može pružiti niske latencije pri taktu od 800 MHz. Ako takt pak planirate držati ispod ove vrijednosti, niske latencije bez problema postaju stvarnost.
Na kraju, kakva je situacija s dostupnošću i cijenom? Kingmax DDR2-667 module od 512 MB je bez problema moguće nabaviti u hrvatskim trgovinama i to po prilično niskoj cijeni od 310 do 350 kn. Sve u svemu, odlično.
Conclusion in english
Kingmax again did a very good with its memory. Altough modules we tested don’t have so good performance on SPD settings (defined by JEDEC), they are really excellent when it comes to overclocking. Of course, for this kind of sport you need to have a solid motheboard which is able to provide modules with enough "juice". In the absence of real DDR2-800 memory on the market (at least in mass quantities) , Kingmax DDR2-667 is a very good alternative, but you should still keep in mind that this memory can’t offer you agressive latencies on 800 MHz clock speed. On the other hand, if you are planning to keep the memory clock below this value, low latencies become a reality.
In the end, what is the situation with price and availabilty? Kingmax DDR2-667 modules with 512MB capacity can be easily obtained in croatian IT stores at a very competitive prices which ranges between 310 and 350 kn. All in all, excellent.
Kingmax DDR2-667 512MB | |||
Pozitivno + | Vrlo dobar overclocker. Postiže solidne latencije. Niska cijena. Zadovoljava ekološke regulative. | ||
Negativno - | Na taktu od 667 MHz ne može postići CAS 3. Za postizanje maksimalnih taktova, treba joj nešto viši napon (2V). | ||
Ocjena |
Ustupili | ASBIS Hrvatska, tel.: 01/600-9900 |
Objavljeno prije 4 minute
dionice i fondoviObjavljeno prije 6 minuta
Smart home/Home security - Pametni prekidaci, senzori i hub: Sonoff, Shelly, Aqara...Objavljeno prije 6 minuta
Windows 11 - info, how-to, pitanja, novosti, savjeti...Objavljeno prije 10 minuta
Mikrotik - za početnikaObjavljeno prije 18 minuta
Kakav miks...Novosti
Elden Ring Nightreign dodaje novu klasu
Elden Ring Nightreign otkriva novu klasu pod nazivom Ironeye, koja nudi preuređeni pristup igranju na daljinu. Iako je Elden Ring Nightreign odvojen od osnovnog naslova Elden Ring, neke od promjena u stilovima igre u ovom spin-offu ostavile... Pročitaj više
FromSoftware najavljuje The Duskbloods
FromSoftware će kasnije ove godine izdati Elden Ring: Nightreign, ali ne znamo mnogo o planovima developera za budućnost. Do danas nije bilo novih igara na vidiku, a Nightreign djeluje više kao spinoff naslov koji povezuje sadašnje vrijeme... Pročitaj više
Potencijalno izlaze još dvije Assassin’ s Creed igre u 2025.
(izvor slike) Assassin's Creed Shadows tek je izašao, ali Ubisoft bi već mogao imati još jednu igru u pripremi. Prema Tomu Hendersonu, glavnom uredniku Insider Gaminga, Codename Invictus "trebao bi" biti lansiran kasnije ove godine. Nije ri... Pročitaj više
Zašto 4G/5G veza troši više baterije vašeg pametnog telefona?
Jeste li ikada primijetili da se baterija vašeg telefona brže prazni kada koristite mobilne podatke nego kada ste spojeni na WiFi mrežu? Postoji li korelacija između pražnjenja baterije i internetske veze putem mobilnih podataka u odnosu na... Pročitaj više
Kako gledati sve utrke Formule 1 uz pomoć VPN-a?
Ako ste kao i mi, veliki ljubitelji motosporta i poglavito Formule 1 tada znate da u Hrvatskoj nije moguće pratiti ovaj sport uživo. Ipak, uz pomoć VPN usloga je moguće pratiti sve treninge, kvalifikacije, utrke kao i dodatan sadržaj na TV... Pročitaj više
