Leadtek WinFast DTV Dongle H – kronični nedostatak teletexta
Datum objave 04.06.2008 - Marin Kovačić
Zaključak - Conclusion
Leadtek
WinFast DTV Dongle H je jednostavan i korisnički susretljiv USB tuner kojeg
prati izvrsna WinFast DTV2 aplikacija. Nažalost, u Hrvatskoj smo ograničeni
na praćenje 4 kanala i jednog HD promo kanala, barem što se tiče digitalne televizije.
Nedostaci ovog tunera su slaba antena, čiji je prijam loš i nemogućnost pregledavanja
teletexta, iako tu funkciju drugi tuneri imaju. Što se tiče kvalitete slike,
ona je odlična jer se tu ipak radi o digitalnom signalu koji omogućava jako
dobru kvalitetu slike, bez snijega ili šuma. Slika ostaje kvalitetna i ako je
signal slab, ako je signal preslab slika i zvuk počinju zastajkivati dok se
kod analognog prijema pojavi poznati snijeg na slici. Ovaj tuner Vam mođemo
preporučiti iz više razloga (ukoliko izuzmemo činjenicu da teletekst ne radi).
Malen je te ga je jednostavno nositi u torbi uz prijenosnik, dobro radi, prati
ga solidan software te ima dobar daljinski upravljač.
Conclusion
The
Leadtek WinFast DTV Dongle H is a simple and user friendly USB TV tuner which
uses the excellent WinFast DTV2 application. The following drawbacks are: the
software’s inability to present the teletext to the user (this maybe happens
only in Croatia, so don’t take this for granted if you live in another country)
and the poor antenna. The video quality is excellent because there is now fuzziness
on digital TV, not to mention the snowy screens which can’t appear because of
the DTV technology. If the signal is too weak, the picture and sound will start
to break up and eventually disappear – simple as that. If the signal level is
sufficient enough, you will have the same quality as if the signal is at its
maximum level. We can recommend this product for several reasons (if we exclude
that TTX is not operational). It`s small, easy to carry around, it works very
well, software is very good and remote control is good.
Leadtek WinFast DTV Dongle H | |||
Pozitivno + | Dimenzije, funkcionalnost, software, daljinski upravljač. | ||
Negativno - | Antena, ne radi TTX. | ||
Ocjena |
Ustupili | Leadtek |
Objavljeno prije 17 minuta
Mehanicke tipkovnice i sve o njima (čitaj 1. post ! )Objavljeno prije 1 sat
Game key exchangeObjavljeno prije 1 sat
Samsung mobiteli - 2. dioObjavljeno prije 1 sat
Procjena: 7700k, lian liNovosti
CD Projekt Red apsorbira The Molasses Flood za razvoj Project Sirius-a
(izvor) Kupljen od strane CD Projekt Red 2021. godine, studio sa sjedištem u Bostonu bio je odgovoran za stvaranje “Project Siriusa,” multiplayer igre smještene u svijetu popularne serije Witcher. Originalno otkriven 2022. godine, zajedno... Pročitaj više
Druga sezona serije The Last of Us pokriva samo prvu polovicu igre
(izvor) Recenzije za drugu sezonu The Last of Us upravo izlaze, a većinom su pozitivne, osim nekoliko iznimki. Ova serija novih epizoda dugo je očekivana, jer je prošlo više od dvije godine od izlaska prve sezone koja je oduševila gledatelj... Pročitaj više
Jedna od najpopularnijih igara trenutno je pod istragom zbog kršenja autorskih prava
Jedna od najpopularnijih igara na Steamu u posljednjem mjesecu, Schedule 1, navodno je pod istragom zbog kršenja autorskih prava zbog sličnosti s indie serijom Drug Dealer Simulator. Posljednjih nekoliko mjeseci bilo je ogromno za gaming za... Pročitaj više
PC port The Last of Us Part 2 dodaje novi sadržaj
The Last of Us Part 2 Remastered izdana je na Steamu za PC korisnike, a otkriven je i početni broj igrača nakon lansiranja. Nadograđeni nastavak donosi grafička poboljšanja, nove načine igre poput No Return mod-a s roguelike iskustvom preži... Pročitaj više
Another Crab’s Treasure dobiva besplatan DLC i fizičko izdanje
Another Crab’s Treasure otkrio je besplatan update Year of the Crab koji dolazi 21. travnja, donoseći traženi New Game Plus i još sadržaja. Ovaj update pomaže developeru Aggro Crabu da proslavi prvu godišnjicu Another Crab’s Treasure i dola... Pročitaj više
