More FX5800 cooling problems
Datum objave 08.05.2003 - Uredništvo
How to cook a GF FX 5800 Ultra, Part II
Update 7:
Finally OFFICIAL NVIDIA info on the subject:
"In response to Issue #1 — fan turns off in 2D mode and when running
some 3D apps (such as screen savers and a few other applications).
All production GeForce FX 5800 Ultra’s do this. This is the most extreme definition
of "Silent Running"….it is truly silent. We did this to improve
the user experience for 2D and screen savers. We also adjust the core and memory
clocks as well as voltage levels to make the FAN-OFF operation safe for the
chip and other components on the board. During FAN OFF mode, the temperature
of the GPU may rise to 100+ degrees C. This is fine and is well below the safety
limits for the device. The device can actually run at 140 degree C without damage.
Issue #2 — Two Gainward cards have shown screen corruption when operated
in FAN OFF mode for an extended period and then switched to FULL 3D mode.
As before, NVIDIA cannot duplicate this. This board does not use the
NVIDIA FX Flow thermal solution, so the details of fan operation and temperature
may be different than that of the NVIDIA FX Flow. Of course, an end user should
contact the board vendor of the product if it shows screen corruption during
normal, within-spec operation."
While PC Ekspert team still feels its not risk-free to have a card that reaches
100C in your system, at least you know your FX Flow card won’t die. Its more
likely its heat will burn some cable or an adjacent card will heat up nicely and glow in the dark…
Seems FX Flow is over engineered a bit. The card can operate at insane temperatures – so why use FX Flow at all? NVIDIA could just have used an ordinary fan/heatsink and save all of us lot of noise.
On the other hand, if you are owner of a Gainward card, you are in
trouble! We wonder how many other vendors make cards that don’t use FX Flow
thermal solution and suffer from the same problems (we are sure Gainward is
not the only one…). NVIDIA also told us that they are working with Gainward on
this issue. It seems we now have to wait for info from Gainward about the whole thing!
Update 6 – It seems problems can be reproduced with Cg examples
A reader from Italy mailed us today and told us we should check Cg examples
from NVidia "The Cg Tutorial: The Definitive Guide to Programmable Real-Time
Graphics". He tried running ‘C7_refraction’ example and the fan would stop
running after some time. You can download these examples from: http://developer.nvidia.com/view.asp?IO=cg_tutorial_software
(17590Kb). The card he uses is ASUS V9900 Ultra/TD.
As we currently have no FX5800 cards (we had to return the one we had) we
can’t try it out right away. I am sure we will get another card in few days
but until then our hands are tied.
As you know, NVIDIA promised answers three weeks ago, but since then they have
been ignoring us, and there have been no driver updates. Speaks a lot about
how much they care about owners of their flagship FX5800 cards.
For previous article/updates about GeForce FX5800 cooling problems, click
here.
Objavljeno prije 1 sat
AutomobiliObjavljeno prije 3 sata
2x Dell AS501 SoundBar (zvucnici) za LCD, Original Maske za iPhone XS Max, 12 Pro MaxObjavljeno prije 3 sata
RUNE Rural Network InfrastrukturaObjavljeno prije 5 sati
Da li BIOS moe smanjiti temperaturu procesoraObjavljeno prije 6 sati
Nintendo Wii/SwitchNovosti
Ne možete nadograditi Windows 11 bez TPM-a 2.0? Microsoft objašnjava zašto je to važno
Kraj podrške za Windows 10 (listopad 2025.) sve je bliže, ali prema najnovijim podacima, više od 54% Windows uređaja još uvijek koristi Windows 10, a samo oko 42.69% nadogradilo je na Windows 11. Jedan od glavnih razloga za ovaj jaz je taj... Pročitaj više
Intel najavljuje više detalja o 18A procesu
Nedavno je Intel objavio više detalja o svom najnovijem procesnom proizvodnom procesu, Intel 18A, na simpoziju VLSI 2025., pokazujući svoj najnoviji iskorak u području poluvodiča i izravno se natječući s TSMC-ovim 2nm procesom. Intelov 18A... Pročitaj više
Apple ili Samsung, tko je najnoviji globalni lider?
Konkurencija među velikim brendovima mobilnih telefona postaje sve žešća, a tri poznate agencije za istraživanje tržišta Counterpoint, IDC i Canalys sukcesivno su objavile svoja globalna izvješća o prodaji mobilnih telefona za prvo tromjese... Pročitaj više
Google pred najvećim raskolom do sada nakon dva uzastopna antimonopolska poraza
Nakon pet godina borbe s antimonopolskim tužbama, čini se da obrambeni zidovi Googlea počinju popuštati. Tehnološki div trenutno se nalazi usred ozbiljnih pravnih bitki na dva najvažnija fronta – pretraživanju i online oglašavanju – s dvije... Pročitaj više
Instagam otključava značajku Edit Grid God (Uredi mrežu)
Instagram je društvena platforma bez koje mnogi mladi ljudi ne mogu svaki dan. Posebno je glavno bojno polje za online "ljepotice" i dijeljenje prekrasnih fotografija i stvaranje fantastične tipografije. Prije nekog vremena, IG je promijeni... Pročitaj više
