Point of View GF 9800GX2 – kalorifer
Datum objave 07.05.2008 - Krešimir Matanović
Zaključak - Conclusion
PoV GeForce 9800GX2 je vrlo brza kartica te je trenutno najbrže
rješenje koje možete kupiti ukoliko želite maksimalne grafičke performanse.
Naravno, ovu karticu u snazi mora pratiti i ostali hardver pa ćete morati
izdvojiti popriličnu količinu novca kako ne bi bilo uskih grla. Isto tako,
preporuka je i monitor sa visokom rezolucijom jer nema smisla vrtiti igre
na 1680×1050 sa ovom mrcinom. Ukoliko novac ne predstavlja problem ovu karticu
vam toplo preporučamo uz samo jedan uvjet. S obzirom da se izuzetno zagrijava
treba omogućiti dobar propuh u kućištu koji će osigurati njeno adekvatno hlađenje.
Point of View uz karticu daje solidan bundle, a u HG Spotu će vas čitavo zadovoljstvo
koštati 3.999kn.
Conclusion
PoV GeForce 9800GX2 is a very fast graphics card and it is currently
the fastest solution for maximum graphic performance. Obviously, the rest
of your hardware needs to be powerful so u can avoid any bottlenecks that
may occur. Also, you have to have a screen with higher resolution because
there is no point playing in 1680×1050 with this card. For all that you need
a lot of money, but if that is not a problem we can highly recommend 9800GX2
under only one condition. Because the card generates large amount of heat
you have to ensure your case has a great airflow in order to keep it from
overheating. Point of View has thrown a nice bundle with the card and in Croatia
you can buy it for approximately 550 €.
Point of View GF 9800GX2 | |||
Pozitivno + | Vrhunske performanse. | ||
Negativno - | Veliko zagrijavanje, slab sistem hlađenja, cijena. | ||
Ocjena |
Ustupili | HG Spot |
Objavljeno prije 17 minuta
Nvidia GeForce RTX 50X0 series (Blackwell)Objavljeno prije 33 minute
AutomobiliObjavljeno prije 34 minute
wifi+bluetooth modul za Asus S410U laptopObjavljeno prije 59 minuta
Linux OS - info, how-to, pitanja, novosti, savjeti, problemi...Objavljeno prije 1 sat
RAMDisk - Ubrzavanje kompa uz pomoc prebacivanja cache/temp foldera na RAM DiskNovosti
Nova piratska igra u svemiru
