Samsung SpinPoint F1 1TB – Veliki bolid
Datum objave 09.04.2008 - Marin Kovačić
Zaključak - Conclusion
Tehnologije koje je Samsung ugradio u ove diskove za povećanje performansi i za
smanjenje zagrijavanja i buke pokazale su svoje prednosti. SpinPoint F1 serija
doista zaslužuje "F1" u svom nazivu jer su ti diskovi brži od svoje
konkurencije. Samo 3 ploče u disku ovakvog kapaciteta svakako su pridonijele
manjem zagrijavanju pa su tako ovi diskovi hladni i tihi. Tijekom rada njihova
temperatura nije prešla 30°C što je vrlo pohvalno. S ovim diskovima nećete imati
problema sa njihovim pregrijavanjem.
No F1 seriju prate glasine o nepouzdanosti. Igrom slučaja, ili možda ne pukom
slučajnošću mi smo dobili jedan defektan disk na testiranje. Ovo je stvarno
šteta jer bi u suprotnom dobili veću ocjenu, koju svojim performansama definitivno
zaslužuju. Cijena ovih diskova na našem tržištu se kreće oko 1700 kn čime se
svrstavaju u sredinu cjenovnog ranga.
Conclusion
Technologies which Samsung integrated into their hard drives
for improving performance and decreasing the heat and noise levels have shown
their advantages. The SpinPoint F1 series really deserves the "F1"
complement in its name because these disks are faster than their opponents.
Only 3 platters per drive have given their contribution in less heat dissipation
and because of this hard drives are cool and quiet. During the operation their
temperature didn’t exceed 30°C which is very good, so you won’t have any concerns
regarding overheating problems. Unfortunately there are rumors regarding the
poor realiability of these hard drives. One of the hard drives we got for the
testing was dud, so maybe these rumors are true. This really is a shame, because
otherwise these drives would receive a higher mark.
These drives cost around 1700 kn in Croatia (around 235 € including VAT) which
is in the middle of the price range.
Samsung SpinPoint F1 1TB | |||
Pozitivno + | Izvrsne performanse, niska razina buke, malo zagrijavanje tijekom rada. | ||
Negativno - | Mogući problemi sa pouzdanošću. | ||
Ocjena |
Ustupili | Asbis |
Objavljeno prije 48 minuta
M.2 NVMe SSD - specifikacije, pitanja, rasprava, review, firmware update,...Objavljeno prije 1 sat
deronjeObjavljeno prije 2 sata
AutomobiliObjavljeno prije 5 sati
Filmovi - dojmovi, komentari i preporukeObjavljeno prije 6 sati
Telemach (ex Tele2)Novosti
Uz kupnju pametnih telefona HONOR Magic7 Pro, HONOR 400 Pro i HONOR 400 stiže i prijenosni aparat za kavu
Ljeto je pravo vrijeme za nove početke, putovanja, spontane avanture i male rituale koji čine svaki dan posebnim. Ove sezone, HONOR je pripremio kampanju koja spaja napredno i ugodno. Uz kupovinu pametnih telefona HONOR Magic7 Pro, HONOR 40... Pročitaj više
10 stvari koje treba učiniti odmah nakon kupnje novog Android telefona
Posjedovanje novog Android pametnog telefona svakako je uzbudljivo jer postoji toliko mnogo mogućnosti prilagodbe. Evo 10 stvari koje trebate učiniti odmah nakon uključivanja uređaja kako biste maksimalno iskoristili mogućnosti personalizac... Pročitaj više
Kineska tvrtka izazvala je groznicu u PC zajednici: lansirala je "ogroman" CPU hladnjak s 4 ventilatora
Nakon serije JF13K, JIUSHARK, kineska tvrtka specijalizirana za razvoj i proizvodnju CPU hladnjaka, nastavlja privlačiti pažnju modelom hladnjaka JF15K Diamond – masivnim dizajnom tornja opremljenim s do 4 ventilatora od 100 mm, hlađenjem d... Pročitaj više
Njemačka traži od Applea i Googlea da izbace DeepSeek iz svojih trgovina aplikacija
Njemačka se pridružila sve većem broju europskih zemalja koje pooštravaju mjere protiv kineskih AI aplikacija – sada traži od Applea i Googlea da uklone DeepSeek iz svojih trgovina aplikacija u Njemačkoj. Njemačka povjerenica za zaštitu pod... Pročitaj više
ASUS ruteri – najbolji izbor za vrhunsko Starlink iskustvo
U Hrvatskoj sve više korisnika prepoznaje prednosti Starlink satelitskog interneta – brzi, stabilni i dostupni internet gotovo na svakom mjestu, bez obzira nalazili se u gradu ili na selu. No, za maksimalno iskorištavanje brzine i pouzdanos... Pročitaj više
