Cooler Master MasterBox Q500L
Datum objave 02.04.2019 - Krešimir Matanović
Cooler Master je pokazao novo kućište Q500L, maleno i robusno namijenjeno standardnim ATX pločama i ATX napajanjima. Glavne karakteristike prenosimo izvorno, na engleskom jeziku:
- Minimized Dimensions for Standard ATX – The MasterBox Q500L supports standard ATX motherboards and PSUs, with a body depth and height of only 386 x 381mm.
- Fully Perforated Chassis – The top, front, rear, and bottom panels are fully perforated to offer airflow for various cooling configurations.
- Movable I/O Panel – Orientation for the chassis is versatile, with the option to move the I/O panel to retain accessibility.
- Vertical and Horizontal Position – The case can be oriented vertically or horizontally. Rubberized screws also function as feet to supplement horizontal orientation.
- Vertical PSU Placement – The PSU is positioned on the front of the chassis to fully utilize internal space. The bracket can be relocated depending on hardware configuration and motherboard form factor.
- Magnetic Dust Filters – The magnetic dust filters feature a unique design. Magnets allow for quick removal and installation for easy cleaning of the dust filters with rubber stompers to keep the filters in place.
- Clean Routing Space – Behind the motherboard tray, 27~30mm width of space is offered for cable management with the entire perimeter acting as a channel for cables.
- Edge-to-Edge Transparent Side Panel – The side panel displays system builds in full view.
MasterBox Q500L će se na tržištu naći uskoro po prihvatljivoj cijeni od 50 €.
Datum objave 01.04.2019
Valve VR Headset
Valve je potvrdio da uskoro na tržište izbacuju vlastiti VR headset imena Valve Index. Za sad Valve Index jedino možemo vidjeti na Steamu, no nikakvi detalji nisu dostupni osim „svibanj 2019“ što je očekivani datum izlaska. Ako se vratimo u prošlost i sjetimo curenja informacija o prototipu o kojem je uploadvr.com izvještavao specifikacije koje možemo očekivati su FOV preko 110° te ukupna rezolucija od 2880×1600. Za sad nema informacija o refresh rateu.
Iako VR nije toliko zaživio zbog iznimno visoke ulazne cijene samih headsetova te poprilično visokih hardverskih zahtjeva treba uzeti u obzir da pad cijena grafičkih kartica i procesora su hardverske zahtjeve ipak puno više približili prosječnim korisnicima. Kao jedan zadnji korak povećanju adaptacije ostaje osmisliti i kreirati povoljniji headset što se navodno od Valve Indexa i očekuje. Naravno pomanjkanje sadržaja kreiranog kompletno za VR i pravih AAA naslova koji bi korisnike „navukli na VR“ igra svoju ulogu no uz najavu Gabe Newella iz veljače 2017. godine da Valve radi i na razvoju 3 kompletno nove, VR fokusirane igre. Jednu baziranu na Unity enginu i druge dvije bazirane na Soruce 2 možemo vidjeti da VR još uvijek živi i nije zapostavljen.
Za kraj bismo dodali da i mi, kao i ostatak interneta, živimo u nadi da će jedna od spomenutih 3 igara biti i Half Life VR ilitiga svojevrsni nastavak Half Life serijala koji nikako da dočekamo
Intel širi GPU tim
Tom Peterson, jedan od ključnih ljudi Nvidije, kojem je zadnja pozicija bila direktor tehničkog marketinga napušta tu kompaniju nakon 14 godina i prelazi u Intel Visual Technologies grupu. Radi se o veteranu industrije koji je radio na dizajnu procesora prije no što se pridružio u Nvidiji. Od poznatijih stvari na kojima je radio bio je dio inžinjera koju su razvijali G-Sync tehnologiju te posjeduje preko 50 tehnoloških patenata.
Intel je dosad ugrabio nekoliko ključnih ljudi iz AMD-a za svoj GPU tim tako da se Tom Peterson prodružuje Raji Koduriu, Jim Kelleru i Chrisu Hooku. Definitivno nas čeka zanimljiva budućnost u GPU svijetu, ako uzmemo u obzir koliko je Intel do sad investirao i koliko debelo su ovaj puta zagrizli u GPU svijet, jedino što možemo je nadati se da ovaj projekt neće pasti u zaborav i da će ponuditi ozbiljnu konkurenciji Nvidiji (a samim time i AMD-u) za razliku od Larrabee arhitekture.
DNA Storage
Nature.com objavio je zanimljiv članak i pohrani podataka koristeći sintetski DNA gdje su biotehničari Christopher N. Takahashi, Bichlien H. Nguyen, Karin Strauss i Luis Cez uspjeli po prvi puta napraviti automatizirani sustav koji može zapisati, kodirati, pročitati i dekodirati podatke. Radi se o zapisivanju 5 bitova podataka – riječ „HELLO“, njihovo kodiranje te dekodiranje i ponovno čitanje uz ugrađeni mehanizam ispravljanja grešaka. Čitav end-to-end postupak trajao je 21 sat.
Razlog ovom istraživanju je gustoća zapisa koju sintetska DNA nudi je barem 3 reda veličine veća od danas dostupnih tehnoloških rješenja, takvo povećanje gustoće zapisa omogućilo bi drastično smanjenje veličine i količinu potrebnih dana centara.
Ovo je prvi proof-of-concept kojim se pokazuje da tehnologija radi te je izrađen po principima maksimalne modularnosti i smanjenja kompleksnosti. Maksimalna modularnost kako bi se sustav mogao što lakše replicirati i ponovno iskoristiti što bi omogućilo paralelno istraživanje i ubrzati razvoj svih dijelova sustava. Dok smanjenja kompleksnost omogućuje lakšu primjenu i komercijalizaciju proizvoda.
Iako možda automatizacija zapisivanja i čitanja 5 bitova podataka uz write to read latenciju od 21 sat ne djeluju impresivno kada to stavimo u kontekst da je prvi proof of concept nuklearnog reaktora u dalekoj 1942. godini bio „snage“ svega 5W te smo od početnih 5W došli do nekoliko GigaWata.
Datum objave 27.03.2019
Hotcdkeys: Nadogradite svoj Microsoft softver po niskim cijenama!
Uhvatite Windows 10 Pro za samo 10,52 €, Office 2016 Pro za samo 26,07 €, i još mnogo toga na Hotcdkeys!
Lider u performansama i inovacijama, operativni sustav Microsoft Windows 10 sada je dostigao 800 milijuna uređaja, što ga čini najkorištenijim operativnim sustavom na svijetu! Pružajući višestruke mogućnosti za uštedu vremena za rad i bolju ukupnu učinkovitost u igri – Windows 10 okuplja najbolje od svih svjetova u jednom paketu!
Osim toga, Microsoft nam je donio i svoj poznati Office Suite – koji se koristi za izradu tekstualnih dokumenata, proračunskih tablica za analizu podataka, prezentacija, upravljanje e-poštom i još mnogo toga!
Zajedno sa sustavom Windows 10, on postaje savršena kombinacija i najkompletniji paket koji zadovoljava sve vaše potrebe! Ali gdje ga možete kupiti – i bez trošenja sveg svoga novca? Hajde da vidimo!
Na prvi pogled, čini se da je teško dobiti originalnu licencu za Windowsa 10 po razumnoj cijeni, budući da cijene mogu ići do 170 €! Stoga je vrijedno dobro pogledati online trgovine. Jedan koji se brzo ističe je Hotcdkeys.com, specijaliziran za prodaju softvera i proizvoda za video igre – po najpovoljnijim cijenama!
Za početak, ovdje imate dodatnih 18% popusta koristeći sljedeći kod “Ypcekspert18” na najpopularnijim Microsoftovim proizvodima!
Evo nekoliko najboljih ponuda ovoga trenutka:
- Windows 10 Pro Professional CD-KEY (32/64 Bit) za 10,52 €
- Microsoft Office 2016 Pro Professional Plus CD-KEY (1 PC) za 26,07 €
- Windows 10 Pro + Office 2016 Pro – Bundle za 31,15 €
- Microsoft Office 2019 Professional Plus CD-KEY (1PC) za 49,19 €
- Windows 10 Pro + Office 2019 Pro – Bundle za 53,29 €
- Microsoft Office 365 (1 Year) 1 Device (WIN/MAC) za 16,39€
Zašto baš Hotcdkeys?
Hotcdkeys.com je brzo rastuća internetska platforma koja nudi softverske licence, ključeve za video igre i igraće karte po nevjerojatnim cijenama! S više od deset godina iskustva i vrlo pozitivnih povratnih informacija od korisnika, Hotcdkeys nastavlja sjati s najkonkurentnijim cijenama na tržištu!
Jednostavan za kupnju, jednostavan za plaćanje!
Shopping na Hotcdkeys.com ne može biti lakši! Ubrzo nakon narudžbe, primit ćete poruku e-pošte s ključevima proizvoda – bez čekanja na odgovor! Osim toga, ako postoji neki problem ili imate samo pitanje, služba za korisnike pružit će brzu i sveobuhvatnu pomoć. Pogledajmo koliko je jednostavno!
Na primjer, evo kratkog objašnjenja kako kupiti ključ OEM licence za Windows 10 Professional – koristeći kod za popust “Ypcekspert18“.
Najprije odaberite svoj proizvod i kliknite gumb “Dodaj u košaricu” na stranici s opisom proizvoda:
Nakon što je taj korak gotov, idite na vašu košaricu, kliknite gumb “Primijeni kupon” – i tamo unesite kod popusta “Ypcekspert18“. Potvrđivanjem vidjet ćete da se popust odbija od izvorne vrijednosti:
Nakon toga, jednostavno „nastavite s preuzimanjem“ i konačno odaberite željeni način plaćanja* – još pogledajte oko web-mjesta ako želite kupiti i nešto drugo. Brzo i jednostavno!
Koristimo priliku da vas podsjetimo da najprije morate preuzeti ispravne verzije na svoje računalo i tek onda ih aktivirati novim ključevima koje ste kupili:
Microsoft Windows 10 Professional: [veza za preuzimanje]
Microsoft Office 2016 Professional Plus: [veza za preuzimanje]
Microsoft Office 2019 Professional Plus: [veza za preuzimanje]
Posjetite njihovu web stranicu na www.Hotcdkeys.com kako biste saznali više
Služba za korisnike E-mail: service@hotcdkeys.com
(sponzorirani sadržaj)
EU parlament i (ne)sloboda interneta
Europski parlament usvojio je „Directive on Copyright in a Single Digital Market“ i problematične Članake 11 i 13. No još uvijek nije gotovo, kontroverzna direktiva još uvijek mora odobriti i Europsko vijeće čiji sastanak se očekuje 9. travnja 2019. godine.
Što sve konkretno znači za slobodu interneta, još uvijek se ne zna. Direktivu, ako prođe kroz EU vijeće, svaka zemlja članica mora primijeniti „u duhu nacionalnih“ zakona do 2021. godine.
Dva najveća problema su u „porezu na linkove“ koji predstavlja Članak 11 te zahtjeve koje na pružatelje online usluga stavlja Članak 13 vezane uz provjeru intelektualnog vlasništva čak i prije uploada.
Ono što Electronic Frontier Foundation ističe jest da je Članak 13 u sukobu sa starijom E-Commerce direktivom koja eksplicitno zabranjuje prisiljavanje pružatelja online usluga da proaktivno prate je li sadržaj koji će se tek staviti na njihovu platformu tuđe intelektualno vlasništvo. Što je svojom presudom 2011 godine potvrdio i EUCJ.
Za više informacija svakako posjetite stranice Electronic Frontier Foundation stranicu, i a sažetije informacije o tehničkom aspektu direktive dostupne su na Wikipediji.
Novi(ji) Intel procesori 9. generacije
Prema objavi Asusa, dostupnoj na sljedećem linku, Intel planira uskoro izbaciti novi stepping 9. generacije svojih procesora. Procesori se očekuju u drugoj polovici 2019. godine.
Asus već ima spremne BIOS nadogradnje za većinu matičnih ploča 300 serije dok se za ostatak očekuje uskoro.
S obzirom da konkretne objave od strane Intela u ovom trenutku u ovom trenutku se ne zna o kojim se konkretno promjenama radi.
Datum objave 26.03.2019
PCIe SSD polaganim tempom na SATA III SSD-e
S obzirom na to da je brzina gotovo svih SATA III diskova ograničena brzinom sučelja ne čudi da proizvođači sve više i više iskorištavaju mogućnosti koje nudi M.2 format, a prije svega brzinu. Ponuda M.2 SSD-a je sve veća i veća, a s druge strane cijena NAND-a je u konstantnom padu što omogućuje puno povoljnije cijene NVMe PCIe SSD-a.
Zadnja istraživanja govore da bi PCIe SSD-i trebali postati mainstream sredinom 2019. godine kada se očekuje da će proći brojku od 50% tržišnog udjela.
Guru3D raspolaže informacijama da je „per unit“ cijena za 512 GB PCIe SSD-e pala na 55 USD u prvom kvartalu 2019. godine, što je pad od oko 11%, dok su istovremeno SATA SSD-i pali za svega 9%. Pad cijena SSD-a kapaciteta 500GB do 1TB očekuje se u narednim mjesecima.
Dodajmo na gornje informacije činjenicu da je razlika u cijeni između SATA i PCIe SSD-a sve manja i manja ne čudi da se sve više korisnika okreće ka bržim NVME PCIe SSD-ima.
Asus i Asrock AMD X570 matične ploče
Videocardz je objavio listu ASRock i Asus matičnih ploča baziranih na zadnjem AMD X570 chipsetu. X570 matične ploče dizajnirane su primarno za Ryzen 3000 seriju procesora, a nepotvrđene glasine govore da se rade o kompletnom AMD in-house dizajnu, a ne kao što su dosad koristili ASMedia rješenja.
Liste nisu finalne, no daju nam blagi okvir vezan uz širinu ponude s kojom AMD i partneri žele izaći na tržište prije početka druge polovice 2019. godine.
Hakeri iskoristili Asus Live Update tool kao backdoor u Windowse
Kaspersky Lab je otkrio da su nepoznati hakeri 2018. godine kompromitirali hosting server za Asus Live Update tool i iskoristili ga za distribuciju zlonamjernog backdoora za Windows bazirana računala.
Sofisticirani napad kodnog imena „Operation ShadowHammer“ opskrbnog lanca Asus Live Update alata otkrili su u siječnju 2019. godine, a pretpostavlja se da se napad dogodio između srpnja i rujna 2018. godine. Napadnuto je minimalno 57 000 tisuća korisnika, uz pretpostavku da bi preko milijun korisnika moglo biti ugroženo. Napadači su identificirali zaražene korisnike putem MAC adresa.
Od napada do otkrića je prošlo puno vremena iz razloga što se za instalaciju zaraženog alata koristio legitimni certifikat kompanije te nitko nije ni sumnjao na legitiman software.
Kompletna dokumentacija i istraživanje biti će dio prezentacije na Security Analyst Summit u Singapuru sljedeći mjesec.
Asus je u međuvremenu izbacio verziju koja rješava problem (v.3.6.8), a više informacija o tome i o dijagnostičkom alatu koji provjerava stanje pogođenih sistema pronađite na njihovim stranicama.
Objavljeno prije 3 minute
NAS - Network Attached Storage ili mrezni diskObjavljeno prije 4 minute
Vijesti, novosti i glasine o nadolazećim Radeon grafičkim karticamaObjavljeno prije 5 minuta
Nvidia GeForce RTX 50X0 series (Blackwell)Objavljeno prije 6 minuta
Battlefield X (koncept, nema jo ime)Objavljeno prije 12 minuta
Mini PCNovosti
Obavijest: 62% popusta na Microsoftove licence ističe uskoro! Doživotna Office licenca samo 15,29€! Čeka vas još popusta na Windowse!
14. listopad 2025., krajnji rok podrške za Windows 10 sada i nije više tako daleko, pa je vrijeme da ozbiljno razmislite o svojim sljedećim koracima. Iako ćete možda moći nastaviti koristiti Windows 10 nakon tog datuma, postoji jedna velika... Pročitaj više
Microsoft Majorana 1
Microsoft je najavio procesor Majorana 1 (QPU) za kvantna računala. U središtu ove inovacije leži otkriće i kontrola neuhvatljive čestice Majorana, koja omogućuje stvaranje topoloških kubita, a karakterizira ga činjenica da je manja vjeroja... Pročitaj više
DJI je predstavio stabilizator za pametne telefone i kamere koji dolazi sa značajkom praćenja objekta
Kineski brend predstavio je svoj novi DJI RS 4 Mini gimbal namijenjen svima koji bi željeli stabilizirati svoj pametni telefon ili kameru. Stabilizator može podržati kamere težine do 2 kg. Novi RS 4 Mini gimbal nudi relativno kompaktan form... Pročitaj više
Huawei Mate XT prvi trostruki pametni telefon stiže po "skromnoj" cijeni
Huawei Mate XT, prvi i jedini pametni telefon koji se sklapa na dvije različite točke na zaslonu, spreman je za lansiranje izvan Kine. Međutim, njegova cijena neće biti pristupačna svima, naime, košta 3499 eura. Analitičari IDC-a sugerira... Pročitaj više
Intel pod pritiskom: TSMC i Broadcom razmišljaju o kupnji različitih odjela
Prema izvješću Wall Street Journala, dva tehnološka diva, Taiwan Semiconductor Manufacturing Co (TSMC) i Broadcom, navodno procjenjuju mogućnost podjele Intela, kultnog američkog proizvođača čipova. Izvori upoznati s tim pitanjem rekli su d... Pročitaj više
