Fractal Define 7 & Define 7 XL
Datum objave 25.02.2020 - Krešimir Matanović
Define_7_TGD_Black_Left_Front
Fractal je redefinirao svoju Define seriju kućišta i predstavio Define 7 i Define 7 XL modele. Oni donose noviji, svježiji izgled, novo dizajniranu unutrašnjost koja je adaptivna te prima i najveće EATX ploče, do 14 tvrdih diskova, 4 SSD-a, pa čak i optički uređaj. U unutrašnjost je moguće smjestiti i 420-milimetarske radijatore i do devet ventilatora.
Define_7_Sheetmetal_Black_wo_sidepanel_XL_Left_Front
Glavne značajke Define 7 kućišta:
  • Spacious and extensively adaptable dual-layout interior easily accommodates large motherboards up to and including 285 mm E-ATX
  • Support for radiators up to 360 mm in front, 420 mm up top, or 280 mm in the base in the default Open Layout
  • Convert to Storage Layout for up to 14 HDDs along with 4 dedicated SSD mounts and one ODD bay (6 HDD/SSD + 2 SSD brackets + 1 multi-bracket included)
  • The single 5.25” ODD bay can be converted to an additional 140 mm front fan mount with filtered louver covering
  • Silence-optimized construction with industrial sound-damped front, top, and side panels
Define_7_Sheetmetal_Black_XL_Blowout
Glavne značajke Define 7 XL kućišta:
  • Spacious, extensively adaptable dual-layout interior easily accommodates large motherboards up to E-ATX and SSI-EEB
  • Mount up to 18 HDD/SSDs plus five SSDs in the Storage Layout (6 HDD/SSD trays + 2 SSD brackets + 2 multi-brackets included)
  • Use the Open Layout for more headroom and gargantuan water-cooling with radiators up to 480 mm in front or top and 280 mm in the base
  • Two 5.25” ODD bays can be converted to an additional front fan mount with filtered louver covering
Više... Vaš Komentar Top
Corsair komponente za vodeno hlađenje u bijeloj izvedbi
corsair_white_2020
Corsair od danas neke od svojih popularnih komponenata za open loop vodena hlađenja nudi i u bijeloj boji. Tako su se na popisu bijelih komponenata našli iCUE QL RGB ventilatori svaki od kojih ima čak 34 LED-ice,  zatim XC7 RGB CPU vodeni blok i XD5 RGB te XD3 RGB pumpe/rezervoari iz Hydro X serije. Ujedno su objavili i da su dodali podršku za ASUS Aura Sync RGB softver za matične ploče u svoj iCUE softver.
Kingstonov IronKey D300 USB uključen u NIAPC
Datum objave 19.02.2020
IKD300S_IKD300SM_y
Kingston  je objavio da je njegova IronKey D300 enkriptirana serija USB Flash Drive ostvarila NATO certifikaciju ograničene razine. To ukazuje da su nakon detaljnog postupka provjere, Kingston IronKey D300, IronKey D300S i IronKey D300SM uvršteni u NATO-ov Information Assurance Product Catalogue (NIAPC) koji ispunjavaju operativne zahtjeve civilnih i vojnih tijela NATO zemalja.
NIAPC je osnovan na temelju INFOSEC direktive i osigurava da se u skladu s NATO sigurnosnim politikama ocjenjuju i odobravaju za upotrebu samo kriptografski proizvodi koji su razvijeni u zemlji članici NATO- a. Serija IronKey D300 je sada uključena na ovaj popis, što znači da je kvalificirana za enkriptirani Flash drive koji zadovoljava razine zaštite podataka koje je uspostavio NATO radi zaštite informacija od gubitka ili cyber napada. Osjetljivo prenošenje podataka mora biti zaštićeno, jer svaki gubitak ili kršenje može rezultirati štetom snagama NATO-a, njegovim članicama ili misiji.
ADATA SSD SE760
ADATA SSD SE760
adata_se760
ADATA predstavlja SE760 prijenosmu memoriju, kompaktnog i optimiziranog dizajna za korištenje u pokretu. Njegova glatka vanjština s teksturiranom površinom od uglačanog metala izgleda dobro te je ugodna na dodir. SE760 nudi sve praktične prednosti koje SSD-ovi imaju pred tvrdim diskovima, uključujući otpornost na udarce i vibracije te tih rad. Uz to, on koristi najnoviji USB-C (Type C) priključak koji je reverzibilan, pa nema iritantnog okretanja kao kod starijih vrsta USB priključaka, odnosno nema više isprobavanja. On se bez posebne pripreme koristi i na sustavima Windows, Mac OS i Android, što znači da korisnici mogu bez ograničenja premještati sadržaje s jednog na drugi uređaj. USB 3.2 Gen 2 sučelje mu omogućuje brzine čitanja / pisanja do 1000 MB/s.
GeForce RTX 2080 Ti Cyberpunk 2077 Edition na nagradnoj igri
Datum objave 18.02.2020
cyberpunk-2077-geforce-rtx-2080-ti-special-edition-gpu-001-740x416
Nvidia je jučer najavila GeForce RTX 2080 Ti Cyberpunk 2077 Edition grafičku karticu koju izdaju u suradnji s CD Project RED-om, developerima Cyberpunk 2077 igre koja izlazi u travnju ove godine. Ova grafička kartica posebnog dizajna biti će proizvdena u svega 200 primjeraka i neće ići u prodaju, ali ni na testove. Ipak, i mi ovdje u Hrvatskoj imamo prilike dokopati se jednog od 77 primjeraka koji će završiti na nagradnoj igri na #RTXON sweepstake eventu. Kako sudjelovati u nagradnoj igri provjerite na wccftechovim stranicama.
SilentiumPC Armis AR6
silentiumpc_ar6
Poljski SilentiumPC predstavlja tri nova Armis AR6 modela kućišta koji nasljeđuju AR5 kućišta, od kojih smo jedno imali prilike i testirati. Tri nova kućišta dijele isti unutarnji dizajn ali im se vanjština ponešto razlikuje kao i (A)RGB osvjetljenje. Svi su bazirani na novoj Natissis internoj arhitekturi koja nalasak stavlja na visoku protočnost zraka s dizajnom dvije komore. AR6X TG RGB i AR6X EVO TG ARGB dolaze s ukupno pet 120-milimetarskih ventilatora iz tvornice, a AR6Q EVO TG ARGB s dva. Kućišta primaju matične ploče od Mini-ITX do E-ATX modela, radijatore vodenih hlađenja dužine do 360 milimetara, te imaju dovoljno mjesta za SSD/HDD kombinacije. Sva tri dolaze s dvogodišnjim jamstvom i cijenama od 65 € za AR6Q, te 83 € za AR6X  AR6X EVO.
AMD Radeon Pro W5500
Datum objave 17.02.2020
Radeon Pro W5500
AMD je lansirao novi profesionalni grafički ubrzivač, baziran na najnovijoj RDNA grafičkoj arhitekturi. Radeon Pro W5500 pruža performanse i donosi napredne funkcije profesionalcima u CAD/CAM modeliranju, 3D animaciji i video produkciji. Kako bi udovoljio današnjim zahtjevima aktivnih profesionalaca za dizajn i proizvodnju, te za arhitekturu, inženjerstvo i građevinarstvo (AEC), AMD je također najavio Radeon Pro W5500M GPU za profesionalne prijenosne radne stanice nove generacije.
Radeon Pro W5500 grafička kartica koristi novu RDNA arhitekturu, a opremljena je s 8 GB GDDR6 memorije. Pruža do 25% više performanse po taktu od prethodne generacije s GCN arhitekturom. Kartica omogućava do 10 puta bolje procijenjene performanse u konkretnom radu s profesionalnim softverskim paketima, u odnosu na konkurenciju u referentnoj vrijednosti SPECvievperf 13 pod opterećenjem više zadataka.Kombinacija energetski efikasne AMD RDNA arhitekture i Radeon Pro upravljačkog softvera, omogućava skaliranje kako bi kartica zadovoljila zahtjeve profesionalnih aplikacija, pri čemu troši do 32% manje sistemske energije od konkurencije u prosjeku u SOLIDWORKS modeliranju.
Radeon Pro Software za Enterprise nudi poboljšanja performansi, a tu je i AMD Remote Workstation koji profesionalcima omogućava pristup fizičkim radnim stanicama s bilo kojeg mjesta. Radeon Pro W5500 će biti dostupna u drugoj polovini mjeseca po preporučenoj maloprodajnoj cijeni od 399 USD.
Licence Windowsa za ispod 14 € na Whokeysu!
Datum objave 13.02.2020
Licence Windowsa su obično vrlo skupe. Tako primjerice originalna licenca za Microsoftove Windowse 10 Pro košta 298 USD na Microsoftovom webshopu. Naravno, postoje i jeftinije alternative kao što je whokeys.com store gdje možete uštedjeti značajne iznose na softver, alate i igre.
whokeys_pcekspert.com2.13_0
Whokeys je globalna online platforma za prodaju svih vrsta softverskih licenci, i proizvodi ne uključuju samo ključeve, tj. licence za Microsoftove Windowse ili Office pakete. Također nude i ključeve za alate kao što je Bitdefender Internet Security i još mnoštvo toga.
Osim što već nudi niske cijene, Whokeys svim PCEkspertašima nudi dodatnih 20% popusta na određene proizvode s kodom “PP20“.
Kupovina je iznimno jednostavna kao što će te vidjeti na primjeru kupovine Windows 10 Pro OEM licence. Potražite proizvod koji želite kupiti (u našem slučaju Windows 10 Pro OEM i kliknite “Buy Now”.
whokeys_pcekspert.com2.13_1
Nakon kratke registracije novog računa (za slučaj da ga već nemate), dolazite do potvrde narudžbe gdje ukucavate kupon kod “PP20“.
whokeys_pcekspert.com2.13_2
Potvrdite narudžbu s Apply tipkom i nakon toga će vam se pokazati cijena s popustom. Naredbom “Send Order” potvrđujete narudžbu.
whokeys_pcekspert.com2.13_3
Nakon odabira načina plaćanja, bit će te preusmjereni na proces plaćanja. Nakon što se taj proces izvrši potrebno je svega par minuta da vaš ključ bude “otključan”, a naći će te ga u “user center” dijelu, uz standardnu potvrdu na vašu email adresu.
Gotovo! Proces je jednostavan i brz. Sada ste ponosni vlasnik nove Windows 10 Pro OEM licence po senzacionalnoj cijeni. Ako želite istražiti cijeli whokeys.com i kupiti ostali softver na ponudi ne zaboravite iskoristiti “PP20” kod za popust.
(sponzorirani sadržaj)
Corsair Scimitar RGB Elite
scimitar_rgb_elite
Corsair je danas predstavio Scimitar RGB Elite miš namijenjen MOBA i MMO igrama. Igračima donosi 17 programabilnih tipaka i patentirani Key Slider sistem za jednostavan pristup prečacima i macro naredbama. Miš je opremljen s optičkim senzorom rezolucije 18.000 DPI-a. Novi miš će se idealno slagati i s novom podlogom imena MM500 Extended 3XL. Podloga je napravljena od tkanine otporne na habanje i dimenzija je 1220 x 610 milimetara.
Petnaesti Job Fair u znaku tematskih Talkova
Datum objave 12.02.2020
Job Fair_Datum_HR_1_Banner (2)
Na Fakultetu elektrotehnike i računarstva 13. i 14. svibnja tradicionalno će se održati netradicionalno izdanje Job Faira, najvećeg sajma poslova u Hrvatskoj. Ovogodišnji, petnaesti po redu sajam uz već poznat program uključuje i novitete u obliku panel diskusija i tematskih Talkova, koji će se tijekom dva dana sajma održavati u KSET-u. Sajam organiziraju FER, Centar karijera FER-a, Savez studenata FER-a (SS FER) i Klub studenata elektrotehnike (KSET).
Nakon četrnaest godina rasta i razvoja, ovogodišnji Job Fair prerasta klasični oblik sajma i poprima oblik konferencije. Tako će, uz standardni program, koji uključuje predstavljanje poduzeća na štandovima te praktične radionice, zainteresirani studenti dobiti priliku iz prve ruke saznati zanimljivosti o projektima, tehnologijama i specifičnim vještinama kroz tematske Talkove, koje će predstavnici pojedinih poduzeća održati na pozornici KSET-a. Uz navedene tematske Talkove, KSET će tijekom dvodnevnog sajma ugostiti stručnjake iz poslovne i znanstvene sfere na dva panela, čime će studenti dobiti priliku sudjelovanja u uzbudljivim raspravama.
Glavna sastavnica novog izdanja Job Faira su tematski Talkovi, koji predstavnicima poduzeća pružaju priliku da u dvadeset minuta publici predstave nove tehnologije, daju dublji uvid u inovativne ideje ili pak iznesu izazove i prepreke s kojima se u svom poslu svakodnevno susreću. Moguće je odabrati jednu od tri kategorije, odnosno teme Talka, ovisno o tome koju od njih poduzeće smatra idealnom za predstavljanje svog područja i projekata.
Prijave za poduzeća otvorene su do 21. veljače, a prijaviti se možete putem internetske stranice Job Faira.  Ponudu za ovogodišnji Job Fair moguće je zatražiti putem e-maila jobfair@fer.hr.
Objavljeno prije 7 minuta
Sumnjive poruke na eMail ?
Objavljeno prije 9 minuta
RAMDisk - Ubrzavanje kompa uz pomoc prebacivanja cache/temp foldera na RAM Disk
Objavljeno prije 19 minuta
F1 sezona 2025
Objavljeno prije 31 minuta
P: Samsung Galaxy S10+ (S10+), 8/128 i S23 Ultra 12/512, odlično stanje
Objavljeno prije 32 minute
Automobili
Nova piratska igra u svemiru
