Fractal Define S
Datum objave 22.04.2015 - Krešimir Matanović
Fractal Define S
Fractal predstavlja novi dodatak u Define seriju, model S. Riječ je o kućištu koje donosi sve glavne značajke Define serije – tehnologiju za utišavanje zvuka i podršku za široki raspon uređaja, a ima potpuno novi layout unutrašnjosti. Tako primjerice uopće nema nosač za optičke uređaje nego je više orijentirano na maksimiziranje protoka zraka i različite mogućnosti kombiniranja sistema vodenih hlađenja.
Glavne značajke (na engleskom):
- Optimally designed for silent computing, while not compromising on airflow and cooling capabilities
- Innovative internal layout, providing a perfectly straight airflow path to the CPU heatsink for air cooling set ups or extensive radiator mounting possibilities for water cooling set ups
- Extensive water cooling support for a case of this size; housing radiators up to 420mm in the top and 360mm in the front
- Including smart reservoir brackets; featuring drill-free reservoir mounting on the front of the motherboard tray and pre-drilled pump mounting holes on the bottom panel
- Equipped with ModuVent fan slot covers providing the option of additional cooling or maximum sound absorption
- Including two Fractal Design Dynamic GP14 140mm fans developed for superlative airflow while still maintaining low noise levels
- Maintaining a dust-free interior with dust filters that cover the front and bottom air intakes
- Introducing newly designed hard drive trays placed vertically behind the front partition of the motherboard tray; Three sturdy steel trays with vibration-dampening grommets allowing for installation of one 3.5″ or 2.5″ drive on each tray, without disrupting the airflow or interfering with the radiator mounting possibilities
- An additional 2 dedicated steel SSD trays cleanly placed behind the motherboard tray
- Long motherboard tray extending to the front panel contributing to an extremely clean build, hiding both hard drives and cables
- Define S model is also available with a large window on the side panel
Datum objave 20.04.2015
Pedeset godina Mooreova zakona: uvijek može bolje
Gordon Moore iznio je 1965. predviđanje koje će odrediti dinamiku suvremene digitalne revolucije. Pozornim proučavanjem novog trenda Moore je došao do zaključka da će se u sektoru tranzistora – temeljnih sastavnica mikroprocesora i digitalnog doba – cijene eksponencijalno smanjivati, a performanse povećavati. Te davne 1965. nije ni naslućivao da je time svijetu donio revolucionarnu ideju koja će postati poznata kao “Mooreov zakon” te će (barem) idućih pola stoljeća biti pokretačka sila preobražajnih tehnoloških promjena.
Ove godine obilježavamo pedesetu godišnjicu Mooreova zakona te možemo reći da se njegovi trajni učinci i dobrobit osjećaju na mnogim područjima čak i pedeset godina poslije. Kao jedan od suosnivača Moore je Intelu utro put za proizvodnju još bržih, manjih, cijenom pristupačnijih tranzistora koji su temelj naših suvremenih uređaja za rad i zabavu. Njegovo predviđanje da će se broj tranzistora na čipu svake godine udvostručiti omogućilo je ubrzano širenje tehnologije diljem svijeta te postalo simbol brzih tehnoloških promjena. Postalo je to zlatno pravilo elektroničke industrije i odskočna daska za inovacije.
Gospodarski učinak
Performanse (snaga) i cijena dva su ključna pokretača tehnološkog razvoja. Kako je s vremenom postajalo moguće u sve manji prostor smjestiti sve više tranzistora, tako su se povećavale snaga procesora i energetska učinkovitost, a sve to po manjoj cijeni za krajnje korisnike. Time nije samo omogućen napredak u postojećim gospodarskim granama i povećana produktivnost, već je potaknuto i stvaranje potpuno novih djelatnosti potaknutih ekonomičnim i snažnim računalstvom.
Tehnološki učinak
Mooreovo opažanje preobrazilo je računalstvo iz egzotične i skupe avanture u sveprisutnu i svima pristupačnu nužnost. Sva suvremena računalna tehnologija koju poznajemo i koristimo nastala je na temeljima koje je položio Mooreov zakon. Od interneta kao takvog do društvenih medija i moderne analize podataka – sve te inovacije izravno potječu od Moorea i njegovih zaključaka.
Društveni učinak
Cijenom pristupačno i sveprisutno računalstvo koje se ubrzano širi u sva područja života iz temelja mijenja naš način rada, zabave i komunikacije. Temeljna snaga Mooreova zakona potaknula je revolucionarne promjene u suvremenim gradovima, prijevozu, zdravstvu, obrazovanju i energetici. Teško je i zamisliti kako bi suvremeni svijet izgledao da nije Mooreova zakona.
Mnogi uređaji koji se svakodnevno koriste temelje se na mikroprocesorima, koji se sastoje od tranzistora. Kako se cijena tih uređaja drastično smanjivala, a performanse i energetska učinkovitost povećavale – sve to zahvaljujući Mooreovu zakonu – postali su neizostavan dio naših života. Telefoni i satovi postali su pametni, a automobili su se pretvorili u pokretna računala.
- Kada bismo telefon sa sustavom Android i Intelovim procesorom proizveli pomoću tehnologije iz 1971., samo bi mikroprocesor takvog telefona bio veličine parkirališnog mjesta. Pa sad vi uslikajte selfie.
- U usporedbi s prvim Intelovim mikroprocesorom, modelom Intel® 4004, današnji 14‑nanometarski procesori nude tri i pol tisuće puta bolje performanse i devedeset tisuća puta veću učinkovitost, a sve to po jednoj šezdesettisućini ondašnje cijene.
Mooreov je zakon težnja, a ne prirodni zakon. Omogućuje ga čitava vojska ljudi koja na kušnju stavlja temeljne fizikalne zakone. Danas Intelove tvornice u sekundi proizvedu više od deset milijardi tranzistora za nevjerojatne uređaje koji služe milijardama ljudi diljem svijeta.
- Prvi poluvodički tranzistori bili su veličine gumice na olovci. Zahvaljujući Mooreovu zakonu, u točku na kraju ove rečenice stalo bi više od šest milijuna 22-nanometarskih tranzistora Tri-Gate.
- Današnji tranzistori nisu vidljivi golim okom. Da bi bilo moguće vidjeti jedan tranzistor, prosječan bi čip trebalo uvećati na veličinu kuće.
Sveprisutan inovacijski duh koji je pokrenuo Mooreov zakon danas nastavlja preobražavati tehnološku industriju i čitav svijet. Mladi stvaratelji, ambiciozni izumitelji, znanstvenici u usponu, liječnici i mnogi drugi i dalje će zadivljivati svijet idejama i izumima koje danas ne možemo ni zamisliti.
50 godina Mooreovog zakona
Jučer se navršilo točno 50 godina od kako je Gordon E. Moore u časopisu Electronics objavio svoje poznato opažanje, danas poznato kao Mooreov zakon. Povodom toga je Intel objavio nekoliko infografika koje označavaju važnost ovoga zakona, a mi iznad prenosimo vremenski tijek zakona i njegovog učinka na mikroprocesore.
Datum objave 17.04.2015
ASUS na Tjednu dizajna u Milanu
ASUS centar za dizajn, nagrađivani dizajnerski studio unutar tvrtke ASUS, otvorio je izložbu pod nazivom Zensation na Milanskom tjednu dizajna 2015. koja je postavljena u Milano Via Tortona 20 i trajat će od 14. do 19 . travnja. Ova izložba prikazuje dizajnerska rješenja inspirirana Zen filozofijom koja spaja različite elemente doprinoseći izbalansiranim, skladnim kreacijama koje korisnicima jamče nevjerojatno iskustvo i pristupačnu ljepotu.
Zensation izložba pruža nevjerojatno iskustvo putem interaktivne projekcije dugačke 15 metara koja prikazuje tri vodeća proizvoda inspirirana Zen dizajnom – ZenFone 2, Transformer Book T300 Chi i Zenbook UX305. Pored toga, posjetiteljima je na raspolaganju i veliki izbor ASUS proizvoda, od pametnih telefona, tankih i laganih prijenosnika, 4K notebook, tablet računala, kompaktnih desktop računala, monitora i projektora kao i mrežnih kategorija.
Posjetitelji Milanskog tjedna dizajna su pozvani da posjete Zensation izložbu i iz prve ruke vide kako ASUS proizvodi stvaraju nevjerojatnu harmoniju moćne funkcionalnosti i prelijepog dizajna.
Datum objave 16.04.2015
SilverStone Kublai KL06
SilverStone predstavlja novi dodatak u Kublai seriji kućišta – model KL06. Riječ je o Micro-ATX kućištu koje prima do osam 2.5″ i jedan 3.5″ uređaj, a inovativni dizajn kaveza za diskove mu omogućuje smještanje sistema vodenog hlađenja bilo s prednje, bilo sa stražnje strane. To znači kako ima modularni dizajn u kojem je moguće premještati i kavez za diskove i gornji panel i nosač matične ploče. Uz KL06 dolaze i dva tiha 120 mm ventilatora, kućište je filtrirano protiv prašine te ina neovisni otvor za ventilator napajanja. Preporučena cijena bez poreza za EU je 71 €, a na tržištu će se naći uskoro.
ASUS najavjuje TUF Trooper B85
ASUS je najavio TUF Trooper B85 matičnu ploču dizajniranu da izdrži sve vrste opterećenja, a koja je testirana prema vojnim standardima. Upotrebom kvalitetnih komponenata osigurana je visoka trajnost i pouzdanost. Trooper B85 je certificirana od strane TUF inženjera kao serverska ploča, te ima petogodišnje jamstvo. Trooper B85 ima i ekskluzivne TUF značajke, uključujući TUF LANguard Ethernet, TUF ESD Guards 2 zaštitu od elektrostatičkog pražnjenja, a tu je i Hi-Fi Audio TUF te fleksibilna kontrola temperature s TUF Thermal Radar Core tehnologijom.
NVIDIA Quadro M6000
Nvidia je nedavno predstavila novu karticu u Quadro obitelji – M6000. Riječ je o grafičkoj kartici namijenjenoj profesionalnoj upotrebi, a krasi ju snaga Maxwell arhitekture od 7 Teraflopsa (single precision) i 12GB memorije, te podrška za simultani prikaz slike na dva 4K monitora. Donosi 2.4x brže performanse u ray-tracingu u odnosu na prethodnicu, a podržava i 36-bitne boje za monitore visokog dinamičkog raspona.
Corsair dodao 960 i 480GB modele u LS seriju SSD-a
Corsair je u svoju LS seriju Force SSD-a uz postojeće modele od 60, 120 i 240GB nadodao i dva nova – 480 i 960GB. Kako sami kažu, LS serija je idealna za prijenosnike zbog debljine od 7 mm, ali i brzina transfera od 560MB/s za čitanje i 540MB/s za zapis. No, LS je naravno pogodan i za desktop korisnike jer se uz diskova opcionalno isporučuje i 2.5″ na 3.5″ adapter. Preporučena cijena za manji model je 190 USD, a za veći 380 USD.
Datum objave 15.04.2015
AMD pozdravlja GTA V, novog člana Gaming Evolved obitelji
AMD je ponosan što je „Grand Theft Auto V” iz kompanije Rockstar Games najnoviji član „Gaming Evolved” obitelji.
Tom prilikom su izjavili: “Mi smo blisko surađivali s našim prijateljima u Torontu i Leeds-u i kao dio te suradnje ova igra podržava AMD-ovu „Contact Hardening Shadows” (CHS) tehniku. Ova tehnika dinamički čini rubove sjena tvrđim ili mekšim u ovisnosti od udaljenosti sjene od izvora svetlosti i objekta koji baca tu sjenu. To omogućava mekše sjene koje se rasipaju na realističniji način. U igri je potrebno odabrati AMD CHS iz „Soft Shadows” padajućeg menija i vidjeti razliku. Igra također ima i ugrađeni benchmark test, koji olakšava testiranje različitih hardverskih konfiguracija. Znamo da su svi vrlo nestrpljivo čekali lansiranje ove igre na PC-u, i mi smo također – naši najnoviji AMD Catalyst driveri su spremni za preuzimanje, i omogućavaju najbolje moguće iskustvo Radeon korisnicima koji igraju GTA V.“
Arctic P324 BT
Arctic predstavlja P324 BT Sports Bluetooth 4.0 slušalice priolagođene aktivnim sportašima:
- ekstra lagani supra-aural dizajn s uklonjivim i perivim podloškama za uši
- ugrađeni mikrofon
- 20 sati playback-a
- Sklopivi dizajn za efikasniji transport u tvrdoj kutiji
- dostupne u crnoj, bijeloj, plavoj, ljubičastoj, ručičastoj i boji limete
Objavljeno prije 1 minute
AMD Ryzen "ZEN5" (9000 CPU series) Info threadObjavljeno prije 5 minuta
Stari hardware za kojim se sliniloObjavljeno prije 7 minuta
Mozilla FirefoxObjavljeno prije 23 minute
K: Nvme m.2 ssd diskoveObjavljeno prije 30 minuta
Half-Life 1 / 2 / EP1 / EP2 / Alyx / Black MesaNovosti
Zabilježite datum: 14. listopada 2025. znači kraj podrške za mnoge popularne Microsoftove proizvode. Što to znači za vaše poslovanje?
Microsoft će 14. listopada 2025. službeno prestati pružati podršku za nekoliko široko korištenih softverskih proizvoda, uključujući Windows 10, Office 2016 i Office 2019. Za tvrtke koje se oslanjaju na ta rješenja, ova prekretnica postavlja... Pročitaj više
AMD lansirao Radeon RX 9000 seriju grafičkih kartica
AMD je danas predstavio dugo očekivanu grafičku arhitekturu AMD RDNA 4 lansiranjem AMD Radeon RX 9070XT i RX 9070 grafičkih kartica kao dijela Radeon RX 9000 serije. Nove grafičke kartice imaju 16 GB video memorije i opsežna arhitektonska p... Pročitaj više
AMD Monster Hunter Wilds Game Bundle
Kao dio AMD-ovih najnovijih najava, kompanija nudi vremenski ograničenu promociju paketa igara. Kupci koji kupe kvalificirani AMD proizvod tijekom promotivnog razdoblja mogu iskoristiti ekskluzivni paket igara. Sve pojedinosti, uključujući... Pročitaj više
Obavijest: 62% popusta na Microsoftove licence ističe uskoro! Doživotna Office licenca samo 15,29€! Čeka vas još popusta na Windowse!
14. listopad 2025., krajnji rok podrške za Windows 10 sada i nije više tako daleko, pa je vrijeme da ozbiljno razmislite o svojim sljedećim koracima. Iako ćete možda moći nastaviti koristiti Windows 10 nakon tog datuma, postoji jedna velika... Pročitaj više
Samsung je slučajno predstavio 9100 PRO PCIe 5.0 SSD
Samsung je predstavio 9100 PRO seriju solid-state diskova standarda PCIe 5.0. Navodno se najava dogodila prije vremena, jer se vijest o tome pojavila na službenoj web stranici indijskog Samsunga, ali je stranica naknadno uklonjena. Najvjero... Pročitaj više
