Gigabyte GV-R9800 MAYA II & GV-R9200
Datum objave 07.03.2003 - Ivan Šolaja
Upravo primismo objavu za medije iz Gigabyte-a – najavu za 2 nove grafulje bazirane na Radeon 9800 i 9200 VPUima (tak to oni zovu). Dok je devettisućaosamsto zvijer namijenjena high-end potrošaćima, devettisućadvjesto je mid-market kartica.
Ajmo prvo o 9800 – u dopisu nema bas previse detalja osim standardnog spominjanja AGPx8, DirectX9.0, TruForm 2.0 i SmartShader 2.0. Evo kraćeg izvatka na engleskom, iako to vjerojatno već znate:
“The GV-R9800 series also enable to render up to eight pixels simultaneously with full floating point precision. This is accomplished by eight-parallel-128-bit floating-point-rendering-pipelines, each with its own independent texture unit and pixel shader engine. The texture unit of each rendering pipeline can sample up to 16 textures in a single rendering pass. These textures can be one-, two-, or three-dimensional, with bilinear, tri-linear, or anisotropic filtering applied depending on the desired quality level.”
Više detalja izdvajaju za 9200 – Izdaju se 3 karice pod oznakama B3, C3 i VIVO, a evo vam i tablice sa svim specifikacijama da moš’te to detaljno proučiti
Model Name | GV-R9200-B3 | GV-R9200-C3 | GV-R9200-VIVO |
Chip | R9200 | R9200 | R9200 |
AGP Type | AGP 8X / 4X | AGP 8X / 4X | AGP 8X / 4X |
Core Feq. | 250MHz | 250MHz | 250MHz |
Mem. Feq. | 400MHz | 400MHz | 400MHz |
Memory Size | 64MB | 128MB | 128MB |
Mem. Bandwidth | 128 bit | 128 bit | 128 bit |
D-Sub | Yes | Yes | Yes |
DVI | DVI-I | DVI-I | DVI-I |
TV-Out | Yes | Yes | Yes |
Video-In | n/a | n/a | Yes |
Configuration | ATX | ATX | ATX |
DirectX | 8.1 | 8.1 | 8.1 |
Packing | PowerDVD XP Serious Sam |
PowerDVD XP PowerDirector PRO Serious Sam |
Radeon 9800, 9600 i 9200
Evo i prvih testova novih Radeon kartica – 9800, 9600 i 9200! Testove možete
naći na:
Chip na kojem su bazirane 9800 i 9800 Pro kartice, R350, nije ništa drugo nego
potweakani R300 koji radi na višem taktu. RV350 chip je pak baza za
9600 seriju. Prvi je ATi GPU rađen u 0.13 mikronskoj tehnologiji i isključivo
podržava 128-bitni način rada. Kako je RV350 poseban GPU, neće biti moguće izvesti
trikove kao na R9500 pa jednu 9600 karticu pretvoriti u 9800. R9200 serija pak
nije ništa drugo nego R9000 s podrškom za AGP 8X. Što se tiče benchova,
ima ih samo za R9800 Pro (a takt je 380/680MHz). Najveći (i skoro jedini) pomak
u performansama je tamo gdje je po nama i bitno – kada se koristi FSAA i Anisotropic
filtering.
Datum objave 06.03.2003
AOpen NForce2
OC Workbench je postavio galeriju slika nove AOpen AK79G Max ploče bazirane na NForce2 chipsetu. Obavezno pogledati.
GeForce QuadroFX 2000
NVidia je izdala svoju novu grafičku karticu za profesionalne korisnike. Sve detalje saznajte na Tom`s Hardwareu.
Playstation 3
Na ovotjednom “Games Developer Conference-u” riječi će biti i o Sonyevoj budućoj Playstation 3 konzoli. PSX3 će koristiti tehnologuiju ćelija, najvjerojatnije će biti pogonjen sa IBM PowerPC procesorom i imat će memoriju Rambus tehnologije. Priča se kako će to biti revolucija na tržištu konzola.
Sapphire Radeon 9800 Pro
Punim imenom Sapphire Atlantis Radeon 9800 Pro je najnovija kartica sa ATI-evim čipom. U Sapphire-ovoj izvedbi imat će 256MB i 128MB radne memorije koja radi na 256bita.
Intel već reklamira Centrino
Intel je već počeo reklamirati Centrino brend. Centrino tehnologija uključuje novi procesor (i novi chipset), 802.11 wireless network (WLAN) te manju potrošnju energije.
Datum objave 05.03.2003
FX5200 i FX5600
NVidia je spremna na tržište poslati svoe FX5200 (NV34) i FX5600 (NV31) grafičke kartice. Sve dodatne informacije pročitajte na Inquireru.
IBM povlači 56000 monitora
IBM je do sad primio pet prijava o prevelikom grijanju i dimu koji izlazi iz njihovih monitora prodanih između lipnja 1997 i prosinca 1998 godine. Monitora ima oko 56000 komada, a ako ste jedan od sretnika koji ga imaju javite se IBM-u.
Cijene DRAM-a padaju
Po DRAM Exchangeu cijene DDR memorije će još ovaj tjedan ostati stabilne, ali njihov pad se očekuje već idućeg tjedna. Trenutno se cijena jednog OEM DDR čipa od 128MBita i 256MBita kreće između $ 2 i $ 3.5. Ostaje samo da vidimo koliko će cijena zapravo pasti idući tjedan i koliko brzo će se to odraziti na našem tržištu.
Objavljeno prije 2 minute
AutomobiliObjavljeno prije 8 minuta
Teretana, utezi i sprave za vjebanjeObjavljeno prije 20 minuta
HP ProDesk 600 mini G3Objavljeno prije 53 minute
Dobra klimaObjavljeno prije 1 sat
Sancta-domenica (informacije i iskustva)Novosti
Realme UI 6.0 Stiže u listopadu: GT 5 Pro s prvim ažuriranjem
Realme, brend pametnih telefona koji se ubrzano penje na ljestvici popularnosti, ponovno privlači pozornost korisnika diljem svijeta. U listopadu 2024. službeno će biti predstavljen novi operativni sustav Realme UI 6.0, što je najavio sam p... Pročitaj više
Serija Huawei Mate 70 mijenja izgled: Početak novog ere u dizajnu mobilnih telefona?
Izvor U ovoj tehnološkoj eri koja se neprestano mijenja, lansiranje svakog flagship mobilnog telefona nije samo pitanje tehničkih specifikacija, već i istraživanje te predviđanje budućih stilova života. Vijest o dramatičnim promjenama u izg... Pročitaj više
Potvrđeno je da je iQOO 13 opremljen samorazvijenim e-sport čipom Q2, a njegova igraća izvedba je nadograđena
Potvrđeno je da je iQOO 13 opremljen samorazvijenim e-sport čipom Q2, a njegova igraća izvedba je nadograđena. Nedavno je voditelj proizvoda iQOO, @galanV, otkrio važnu informaciju na društvenim mrežama koja ukazuje da će nadolazeći mobilni... Pročitaj više
Super moćni OPPO K12 Plus
OPPO K12 predstavlja sveobuhvatnu nadogradnju svog prethodnika, s impresivnim SuperVOOC punjenjem od 100 W i baterijom kapaciteta 5500 mAh, koja omogućuje produljeno trajanje baterije. Ovaj model popularizira brzo punjenje od 100 W i iznimn... Pročitaj više
G.Skill DDR5-9000
G.Skill ponovno predvodi svijet s ultra visokom brzinom DDR5 memorije na 9000 MT/s pri CL44-56-5, kapaciteta 48GB u 24GB x2 izvedbi. Ovo je postignuto s AMD Ryzen 7 8700G procesorom i ASUS ROG CROSSHAIR X870E HERO pločom. G.SKILL-ov starij... Pročitaj više
