Kondenzatori – Loša kvaliteta je problem cijele industrije?
Datum objave 15.02.2003 - Ivan Šolaja
Kondenzatori - Loša kvaliteta je problem cijele industrije?
Dobili smo vrlo zanimljiv dopis iz Abit-a, a tiče se kondenzatora, kvalitete istih i utjecaja na industriju hardware-a u cjelini. Evo Quote cijelog dopisa da ja sad tu ne prevodim, ak neko nezna engleski, mejlajte me!
Recently IEEE Spectrum Online wrote an article on the capacitor problem.
The
site IEEE Spectrum Online is a well-respected media. It is a
subsription website, but I have included the main points below:
“So far, the only motherboard maker to admit to the problem is ABIT
Computer
Corp. (Taipei), and the only major PC maker to acknowledge being
affected is
IBM Corp. But the problem is likely to be more widespread. Indeed, those
who
have repaired the damaged boards say that they have encountered crippled
motherboards from Micro-Star International, ASUSTek Computer, Gigabyte
Technology, and others.”
Others have said “Hopefully these companies (MSI, ASUS, Gigabyte) will
buck
the industry trend and follow ABIT’s example. Prompt disclosure and
acknowledgement of a problem will greatly expedite the repair / return
process for all concerned and help both consumers and manufacturers get
back
to business. Mistakes, after all, happen, but people tend to be much
more
forgiving of those who admit them than they who do not.”
The Iquirer
All very appreciative that ABIT came forward first with the information
and
angered that the other motherboard makers whose motherboards are
obviously
affected by this problem. Most important for Sales is to make sure that
your distributors and resellers understand that this is not an ABIT
problem.
This is an industry-wide problem. ABIT is the first to admit that there
was
an issue with capacitors and to have action on this issue. The other
motherboard makers are being pressured to admit the same and will be
forced
to have some action to correct their problems.
I mi smo imali raspravu na forumu prije nekoliko mjeseci (poštovani gdin. Pajo se dotakao iste) u kojoj se spominjalo i govorilo o kondenzatorima, proizvodnom procesu i kvaliteti istih. Ak vas to zanima, skok na forum (zgodno je jel je Pajo stavio i link na listu ‘sigurnih’ proizvodjaća.
Zaključak ovog gore bi mogo bit da od sad prvo moramo proučiti od kuda se nabavljaju kondenzatori za dotičnu komponentu, a tek onda gledat performanse, cijenu, izgled, điđe koje dolaze u paketu itd.
WD 10000rpm SATA disk
Dugo dugo se priča o ATA diskovima na 10000 okretaja. WD je sad najavio svoj Enterprise-level SATA disk – WD Raptor. Najljepša stvar na disku je seek time – 5.2ms – dakle na nivou SCSI diskova (a i garancija je na 5 godina).
Pentium4 vs. AthlonXP
Nadasve zanimljiva usporedba Pentium4 (2.4b) i AthlonXP (2600+) procesora istog radnog takta (2.4GHz). Kako se čini, razlika između 2.4GHz (18*133) Intela i ADMa i nije baš tako velika, s time da je AMD značajno skuplji (US$ 192 naprema US$ 261). Doduše, i sam autor teksta napominje da je Athlon 2400+ oko US$ 20 jeftiniji, ali njega su zanimale stvarne, a ne nazivne brzine.
4x Mobile Pentium4
Usporedni test 4 Pentium4 procesora namijenjena prijenosnim računalima. Koliko se koji isplati (s obzirom na brzinu i cijenu) i kolika je stvarna razlika među njima, pogledajte na Tom’s Hardware-u.
Datum objave 14.02.2003
Još o GeForce FX
Kako se čini, nVidia ima velikih problema s isporukom GF FX GPU-om. Naime, dio chipova je DOA (dedonarajvl). Čini se da će NV35 biti zapravo samo NV30, samo što će raditi na 600MHz. Inače, čini se da NV30 GPU ima “clock throttling” (usporavanje pri pregrijavanju).
Apple Powerbook G4 12" II. put
Još jedan test Apple Powerbook G4 12″, ali ponešto u drugačijem svjetlu.
Datum objave 13.02.2003
Riješena tajna skrivena u jezgri Bartona
Slovački znanstvenik Gunov Bombirakov je uz pomoć opakog ultra turbo močnog (SCM) mikroskopa otkrio tajnu skrivenu u samoj jezgri Bartona. Što skriva, pogledajte na linku.
3DMark 2003
Stigla je najnovija verzija 3DMarka, najpopularnijeg softwarea za prepucavanje “moje računalo je brže od tvoga”. Navaaaali narode! Friško! Svježe! Najnajnaj!
Datum objave 12.02.2003
Iako pompozno najavljivan od Apple-a kao najmanji i najdostupniji Powerbook na tržištu, to ima i svoju cijenu. Strašno zagrijavanje nakon 2-3 sata rada i loš 12″ LCD monitor nisu u skladu s reputacijom koji nosi.
Da ne bi bilo zabune, riječ je o vrlo sposobnom računalu, vrhunski opremljenom, a istovremeno minijaturnom.
Datum objave 11.02.2003
Barton testovi!
Pojavio se Barton! Prve testove možete naći ovdje:
AMD je svojim najdražim stranicama podijelio Bartone 3000+ koje krasi takt
od 2.16GHz (13x166MHz, isti takt kao i Thoroughbred AthlonXP 2700+). Koristi
od veće cache memorije ima, ali nije drastična. T-Bred 2800+ je često brži od
Bartona 3000+ zbog većeg takta, no sveukupno gledavši Barton je bolji. S druge
strane, Barton će biti vrlo skup. Od gore navedenih članak preporučamo x-bitov
test jer je stvarno dobar i u njemu nema gluposti (u ostalim člancima smo našli
svakojakih provala).
Objavljeno prije 4 minute
3DMark rezultati i komentariObjavljeno prije 23 minute
Glazbeni servisObjavljeno prije 1 sat
Xbox Series X/SObjavljeno prije 1 sat
Sam svoj majstor - razni radovi po kući/stanuObjavljeno prije 1 sat
P: HDD Ironwolf, sandisk, mob Xiaomi, Yamaha zvučniciNovosti
Elden Ring Nightreign dodaje novu klasu
Elden Ring Nightreign otkriva novu klasu pod nazivom Ironeye, koja nudi preuređeni pristup igranju na daljinu. Iako je Elden Ring Nightreign odvojen od osnovnog naslova Elden Ring, neke od promjena u stilovima igre u ovom spin-offu ostavile... Pročitaj više
FromSoftware najavljuje The Duskbloods
FromSoftware će kasnije ove godine izdati Elden Ring: Nightreign, ali ne znamo mnogo o planovima developera za budućnost. Do danas nije bilo novih igara na vidiku, a Nightreign djeluje više kao spinoff naslov koji povezuje sadašnje vrijeme... Pročitaj više
Potencijalno izlaze još dvije Assassin’ s Creed igre u 2025.
(izvor slike) Assassin's Creed Shadows tek je izašao, ali Ubisoft bi već mogao imati još jednu igru u pripremi. Prema Tomu Hendersonu, glavnom uredniku Insider Gaminga, Codename Invictus "trebao bi" biti lansiran kasnije ove godine. Nije ri... Pročitaj više
Zašto 4G/5G veza troši više baterije vašeg pametnog telefona?
Jeste li ikada primijetili da se baterija vašeg telefona brže prazni kada koristite mobilne podatke nego kada ste spojeni na WiFi mrežu? Postoji li korelacija između pražnjenja baterije i internetske veze putem mobilnih podataka u odnosu na... Pročitaj više
Kako gledati sve utrke Formule 1 uz pomoć VPN-a?
Ako ste kao i mi, veliki ljubitelji motosporta i poglavito Formule 1 tada znate da u Hrvatskoj nije moguće pratiti ovaj sport uživo. Ipak, uz pomoć VPN usloga je moguće pratiti sve treninge, kvalifikacije, utrke kao i dodatan sadržaj na TV... Pročitaj više
