Brzi test – Gigabyte Radeon HD7850 OC
Zaključak – Conclusion
Gigabyteova se GV-R785OC-2GD u domaćim informatičkim dućanima i webshopovima može naći za oko 1.950 kuna s PDV-om čime je izjednačena sa Sapphireovom HD7850 OC. Od nje je za oko 2% brža, 8°C hladnija i tek malo bučnija. Overclocking potencijal im je identičan, s istim relativno niskim maksimalnim taktom memorije. Sapphire pak s druge strane donosi bolji bundle koji uključuje DiRT Showdown igru pa će konačna odluka ovisiti o osobnim afinitetima kupca. Mi ćemo laganu prednost dati Gigabyteovoj kartici, koja je brža i hladnija out-of-the-box.
Conclusion
Gigabyte`s GV-R785OC-2GD card in Croatian IT shops and webshops can be found for around 1950 kuna including VAT (260 €), which is about the same amount you have to pay for Sapphire`s HD7850 OC card. As we have seen from tests, Gigabyte`s card was about 2% faster, 8 °C cooler and a little bit noisier. Overclocking potential is identical, and with the same (relatively low) maximum clock speed. Sapphire, on the other hand brings a better bundle that includes Dirt Showdown game and the final decision will depend on the personal preferences of the customer. We will give a slight advantage to the Gigabyte`s card, which is faster and cooler out-of-the-box.
Stranica 4 od 4
