Corsair iCUE H115i RGB PRO XT recenzija
· · Hlađenje · Stranica 3 od 4
Rezultati testova
AMD Ryzen 9 3900X @ Stock
Temperature (Tdie)Gigabyte Aorus LC 280: 67,8Gigabyte Aorus LC 28067,8Corsair H115i Pro XT @ Extreme: 68,5Corsair H115i Pro XT @ Ext…68,5Cooler Master ML240L V2 RGB: 70,4Cooler Master ML240L V2 RGB70,4Raijintek EOS 240 RBW: 70,5Raijintek EOS 240 RBW70,5Corsair A500: 72,9Corsair A50072,9Raijintek Orcus 240 RBW: 75,3Raijintek Orcus 240 RBW75,3Corsair H115i Pro XT @ Balanced: 78,3Corsair H115i Pro XT @ Bal…78,3Noctua D15: 78,8Noctua D1578,8087
U prvom testu vidimo razliku od velikih 10°C između tihog Balanced i Extreme profila u maksimalnoj temperaturi procesora.
AMD Ryzen 9 3900X @ 4.3 GHz (1.35 V)
Temperature (Tdie)Corsair A500: 75,5Corsair A50075,5Raijintek EOS 240 RBW: 80Raijintek EOS 240 RBW80Gigabyte Aorus LC 280: 80,9Gigabyte Aorus LC 28080,9Cooler Master ML240L V2 RGB: 82Cooler Master ML240L V2 RGB82Corsair H115i Pro XT @ Extreme: 82Corsair H115i Pro XT @ Ext…82Corsair H115i Pro XT @ Balanced: 85Corsair H115i Pro XT @ Bal…85Raijintek Orcus 240 RBW: 87,3Raijintek Orcus 240 RBW87,3Noctua D15: 91,1Noctua D1591,10100
Kod overclockinga je razlika puno manja, procesor se više zagrijava i dolazi do termalnog zasićenja no brži ventilatori ipak uspijevaju skinuti 3°C. Ovdje je ipak najuspješniji bio A500 i to će biti teško nadmašiti, ali je i buka naravno visoka.
Intel i7-8700K @ Core Enhancement (4.7 GHz)
Temperature (Tdie)Raijintek EOS 240 RBW: 77Raijintek EOS 240 RBW77Asus ROG Ryujin 240: 80Asus ROG Ryujin 24080Asus ROG Ryuo 240: 80Asus ROG Ryuo 24080Cooler Master ML240L V2 RGB: 80Cooler Master ML240L V2 RGB80Asus ROG Ryujin 360: 80Asus ROG Ryujin 36080Corsair A500: 81Corsair A50081Corsair H115i Pro XT @ Extreme: 81Corsair H115i Pro XT @ Ext…81Gigabyte Aorus LC 280: 81Gigabyte Aorus LC 28081Raijintek Orcus 240 RBW: 81Raijintek Orcus 240 RBW81CoolerMaster ML360R RGB: 82CoolerMaster ML360R RGB82Corsair H115i Pro XT @ Balanced: 82Corsair H115i Pro XT @ Bal…82Noctua D15: 83Noctua D1583Arctic LF 240: 88Arctic LF 24088Be Quiet! Dark Rock Pro 4: 90Be Quiet! Dark Rock Pro 490Be Quiet! Dark Rock 4: 92Be Quiet! Dark Rock 492Cryorig H7: 92Cryorig H792Arctic Freezer 12: 95Arctic Freezer 12950105
Samo 1°C razlike između Balanced i Extreme profila nije pravi pokazatelj stanja. Prosjek maksimalnih temperatura na svim jezgrama je iznosio 73,66°C na Extreme  profilu, a 78°C na Blanced. Samo za usporedbu, prosječna je temperatura A500 hladnjaka bila 77.83°C, Orcusa 240 RBW 76,16 °C, a Noctua D15 na visokih 81°C.
Buka
Buka (dBa)Corsair H115i Pro XT @ Balanced: 35,5Corsair H115i Pro XT @ Bal…35,5Cooler Master ML240L V2 RGB: 40Cooler Master ML240L V2 RGB40Raijintek Orcus 240 RBW: 41,5Raijintek Orcus 240 RBW41,5Raijintek EOS 240 RBW: 41,6Raijintek EOS 240 RBW41,6Noctua D15: 42Noctua D1542Corsair H115i Pro XT @ Extreme: 44,5Corsair H115i Pro XT @ Ext…44,5Gigabyte Aorus LC 280: 45Gigabyte Aorus LC 28045Corsair A500: 49Corsair A50049054
Na maksimalnih su 2.000 okretaja ventilatori čak 5,5 dBA tiši nego kod onih na A500 hladnjaku, a na Balanced profilu su gotovo pa nečujni – nešto iznad ambijentalne buke koja je iznosila 34 dBA. H115i PRO XT dakle pokriva širok spektar upotrebe, može biti potpuno tih u Zero RPM modu, a može biti i moćan te glasniji na Extreme modu. Ipak, tih 44,5 dBA je i dalje sasvim prihvatljivo.
Rezultati testova
Stranica 3 od 4
