Gigabyte Radeon RX 7700 XT Gaming OC recenzija
· · Video · Stranica 2 od 6
Test sistem
Test sistem :: Hardware
Matična ploča ASUS Maximus Z790 Hero
Procesor(i) Intel i9 13900K
Memorija 2x 16 GB DDR5 G.Skill Trident Z5 RGB 6.800 MHz
Grafičke kartice Gigabyte Radeon RX 7700 XT Gaming OC; Driveri: Adrenaline 23.20.01.05
Zvučna kartica On Board
Napajanje SuperFlower Leadex Platinum 1200W
SSD ADATA Swordfish 2TB
Monitor Dell S2721DGF
Testni sistem :: Software
OS Windows 11 22H2
DirectX verzija 12
3DMark TimeSpy, Port Royal, Speed Way, VRS
Anno 1800 In game benchmark, max. details, DX12
Borderlands 3 In-game benchmark, Ultra details
Cyberpunk 2077 In-game benchmark, Ultra details
Resident Evil 4 Gameplay benchmark, max details
FarCry 6 In-game benchmark, max. details
For Honor In-game benchmark, max. details
Ghost Recon Breakpoint In-game benchmark, Ultra
Godfall In-game benchmark, Epic details (DXR on & off)
F1 22 In-game benchmark, Max. details
Horizon Zero Dawn  In-game benchmark, Ultimate
Shadow of the Tomb Raider In-game benchmark, max. details, RTX On, SSAO Off
The Division 2 In-game benchmark, max. details
The Riftbreaker  In-game benchmark, max. details
The Calysto Protocol In-game benchmark, max. details
Company of Heroes 3  In-game benchmark, max. details
Način testiranja
Karticu smo testirali na Intelovoj platformi, a kao što znamo nema većih razlika između dvije platforme koje imamo za testove – Core i7-13900K i Ryzen 9 7950X. Resizable BAR je bio po defaultu uključen u BIOS-u ploče pa smo tako i testirali. Iako na grafovima ima kartica koje nisu testirane s BAR-om uključenim u budućnosti ćemo sve testirati tako jer je sada to defaultna postavka u BIOS-u. Testovi i usporedbe s ranije testiranim karticama bit će samo u 1440p rezoluciji. AMD karticu pozicionira za 1440p segment, pa smo ovaj put tako i testirali. 1080p rezultate, ako vas zanimaju pogledajte u originalnoj recenziji RX 7800 XT i RX 7700 XT modela. Ujedno, kod ovog testa smo izbacili UL Benchmark (3DMark) testove da ne pretrpavano s informacijama, a performanse svih RX 7700 XT su u par postotnih bodova kao što će te vidjeti i u ovom testu. Testni monitor je Dellov S2721DGF rezolucije 2.560x 1.440 i stope osvježenja od 165 Hz. Baterija testova je standardna, s dodatkom najnovijeg naslova Starfield. Kao i do sada, napravili smo i testove zagrijavanja te potrošnje kroz nekoliko naslova. Uvijek uzimamo najveću vrijednost, a mjerena je potrošnja cijelog sistema. Vrijednosti buke koju navodimo u članku smo dobili mjerenjem uz pomoć Meterk MK09 mjerača. Ponašanje kartice i drivera kod testiranja Testirali smo s Adrenaline 23.20.01.05 driverima u beta verziji na Windowsima 11 22H2 i nismo imali nikakvih problema ili nestabilnosti tijekom testiranja. Overclocking
Overclockirali smo uz pomoć Adrenaline drivera i Performance taba uz primjenu malo drugačije taktike kao kod testa Sapphire Nitro+ kartice. Malo smo spustili napon GPU-a na 1,1V, minimalni GPU takt postavili na 2,7 GHz, a maksimalni na 5 GHz, te maksimalnu snagu za +15%. Naravno, GPU-u će uz pomoć algoritma tako sam odrediti maksimalne taktove. Uz to, memoriju smo podigli na 2,4 GHz tj. 19,2 Gbps – Gigabyte koristi Hynix memoriju koja nije sjajan overclocker. Provjerom GPU-Z loga smo utvrdili kako je maksimalni takt GPU-a bio 2.746 MHz što i nije puno više od tvorničkog pa ćemo vidjeti rezultate. Maksimalni board power draw se pri tom spustio na 278 W zbog nižeg napona. Ni ova kartica nije potpuno optimizirana s te strane i previše troši za svoje performanse. Rezultate overclockinga će te naravno vidjeti u zasebnim grafovima kao i uvijek.
Stranica 2 od 6
