Nvidia GeForce GTX980Ti – novi flagship je tu
· · Video · Stranica 6 od 7
Rezultati testova – treći dio
BasemarkCL v1.1AMD Radeon R9 295X2: 428,032AMD Radeon R9 295X2428,032Nvidia GTX980 Ti: 342,477Nvidia GTX980 Ti342,477ASUS Matrix Platinum GTX780Ti: 198,372ASUS Matrix Platinum GTX78…198,3720471
OpenCL performanse nove kartice su jednostavno izvrsne – čak 72% više od “nabrijane” GTX780 Ti.
Luxmark v2.0AMD Radeon R9 295X2: 2.993AMD Radeon R9 295X22.993ASUS GTX780Ti DCU II @ SLI: 2.695ASUS GTX780Ti DCU II @ SLI2.695Nvidia GTX980 Ti: 2.228Nvidia GTX980 Ti2.228AMD R9 290X: 1.505AMD R9 290X1.505AMD R9 290: 1.367AMD R9 2901.367ASUS Matrix Platinum GTX780Ti: 1.360ASUS Matrix Platinum GTX78…1.360ASUS GTX780Ti DCU II: 1.335ASUS GTX780Ti DCU II1.33503.292
I u ovome OpenCL benchmarku GTX980 Ti pokazuje svoju veliku moć i nadvisuje Matrix Platinum GTX780 Ti za gotovo 64%.
BukaGainward GTX970 Phantom: 44Gainward GTX970 Phantom44MSI GTX980 Gaming 4G: 44MSI GTX980 Gaming 4G44Asus GTX780 STRIX OC: 45Asus GTX780 STRIX OC45Gigabyte GTX970 Gaming G1: 45Gigabyte GTX970 Gaming G145MSI R9 290X Lightning: 45MSI R9 290X Lightning45ASUS Matrix Platinum GTX980: 46ASUS Matrix Platinum GTX98046Nvidia GTX780: 47Nvidia GTX78047Nvidia GTX780 Ti: 47Nvidia GTX780 Ti47Asus GTX680 DCUII: 48Asus GTX680 DCUII48ASUS Matrix Platinum GTX780Ti: 48ASUS Matrix Platinum GTX78…48Nvidia GeForce GTX980: 48Nvidia GeForce GTX98048Sapphire R9 290X Vapor-X 4GB OC: 48Sapphire R9 290X Vapor-X 4…48Sapphire R9 290X Vapor-X 8GB: 48Sapphire R9 290X Vapor-X 8…48AMD Radeon R9 290X @ Uber: 49AMD Radeon R9 290X @ Uber49AMD Radeon R9 290 @ Uber: 49AMD Radeon R9 290 @ Uber49ASUS GTX780Ti DCU II: 49ASUS GTX780Ti DCU II49Nvidia GTX980 Ti: 49Nvidia GTX980 Ti49Sapphire R9 290X Tri-X 8GB: 49Sapphire R9 290X Tri-X 8GB49ASUS MARS 760: 51ASUS MARS 76051AMD R9 295X2: 53AMD R9 295X253058
Kartica je razmjerno tiha u početku no kako igra napreduje tako raste i temperatura pa se ventilatoru brzina s početnih 1050 okretaja brzina diže i na malo ispod 2300 okretaja u minuti. Oklop hladnjaka je pri tome jako vruć na dodir i nije moguće držati prst na njemu duže od par sekundi.
PotrošnjaNvidia GTX980: 375Nvidia GTX980375Gigabyte GTX970 Gaming G1: 383Gigabyte GTX970 Gaming G1383MSI GTX980 Gaming 4G: 394MSI GTX980 Gaming 4G394Gainward GTX970 Phantom: 400Gainward GTX970 Phantom400ASUS Matrix Platinum GTX980: 412ASUS Matrix Platinum GTX980412Nvidia GTX780: 427Nvidia GTX780427Gigabyte GTX960 G1 @ SLI: 440Gigabyte GTX960 G1 @ SLI440Nvidia GTX980 Ti: 465Nvidia GTX980 Ti465Asus GTX780 STRIX OC: 495Asus GTX780 STRIX OC495ASUS Matrix Platinum GTX780Ti: 497ASUS Matrix Platinum GTX78…497ASUS GTX780Ti DCU II: 499ASUS GTX780Ti DCU II499Sapphire R9 290X Tri-X 8GB: 500Sapphire R9 290X Tri-X 8GB500MSI R9 290X Lightning: 501MSI R9 290X Lightning501AMD Radeon R9 290: 502AMD Radeon R9 290502Sapphire R9 290X Vapor-X 4GB OC: 502Sapphire R9 290X Vapor-X 4…502Sapphire R9 290X Vapor-X 8GB: 503Sapphire R9 290X Vapor-X 8…503AMD Radeon R9 290X: 508AMD Radeon R9 290X5082x PowerColor R9 270 @ CFX: 5412x PowerColor R9 270 @ CFX541AMD R9 295X2: 733AMD R9 295X27330806
Potrošnja čitavog sistema je očekivano dosta visoka no i dalje je u razumnim granicama.
ZagrijavanjeGigabyte GTX970 Gaming G1: 60Gigabyte GTX970 Gaming G160ASUS GTX780 DCU II OC: 62ASUS GTX780 DCU II OC62AMD R9 295X2: 63AMD R9 295X263ASUS Matrix Platinum GTX980: 64ASUS Matrix Platinum GTX98064MSI GTX980 Gaming 4G: 68MSI GTX980 Gaming 4G68MSI R9 290X Lightning: 69MSI R9 290X Lightning69Sapphire R9 290X Vapor-X 4GB OC: 70Sapphire R9 290X Vapor-X 4…70Asus GTX780 STRIX OC: 71Asus GTX780 STRIX OC71Gigabyte GTX580 SOC: 71Gigabyte GTX580 SOC71MSI GTX770 TwinFrozr: 71MSI GTX770 TwinFrozr71Gigabyte GTX770 OC: 71Gigabyte GTX770 OC71Sapphire R9 290X Vapor-X 8GB: 71Sapphire R9 290X Vapor-X 8…71Sapphire R9 290X Tri-X 8GB @ OC: 72Sapphire R9 290X Tri-X 8GB…72Sapphire R9 290X Tri-X 8GB: 75Sapphire R9 290X Tri-X 8GB75ASUS Matrix Platinum GTX780Ti: 75ASUS Matrix Platinum GTX78…75Gainward GTX970 Phantom: 75Gainward GTX970 Phantom75Sapphire R9 290 Tri-X: 80Sapphire R9 290 Tri-X80Nvidia GTX980: 83Nvidia GTX98083Nvidia GTX980 Ti: 84Nvidia GTX980 Ti84Nvidia GTX780 Ti: 93Nvidia GTX780 Ti93ASUS MARS 760: 94ASUS MARS 76094AMD Radeon R9 290: 95AMD Radeon R9 290950105
Vrlo velik, kompleksan i brz GPU nije lako hladiti i zbo toga je ventilator i nešto malo bučniji, a i temperatura je dosta visoka. Aftermarket hladjaci će imati teži posao nego kod GTX980 no oni najbolji na tržištu će sigurno donijeti nižu razinu buke i zagrijavanja.
Stranica 6 od 7
