Raijintek EOS 240 RBW recenzija
· · Hlađenje · Stranica 3 od 4
Rezultati testova
AMD Ryzen 9 3900X @ Stock
Temperature (Tdie)Gigabyte Aorus LC 280: 67,8Gigabyte Aorus LC 28067,8Cooler Master ML240L V2 RGB: 70,4Cooler Master ML240L V2 RGB70,4Raijintek EOS 240 RBW: 70,5Raijintek EOS 240 RBW70,5Raijintek Orcus 240 RBW: 75,3Raijintek Orcus 240 RBW75,3Noctua D15: 78,8Noctua D1578,8087
EOS 240 RBW na stock postavkama procesora 3900X ima performanse sasvim u razini ML240L V2 RGB, a čak je za 5°C bolji od Orcusa 240 RBW. Uz ventilatore koji se pri tom vrte na oko 1.500 okretaja tek je mrvicu bučniji od ML240L i u istoj razini s Orcusom 240 RBW.
Ono što je vrlo zanimljivo je da je prosječni takt na svim jezgrama je tijekom testa iznosio visokih 4,2 GHz pri 1.33V, a kod Orcusa je bio 4,175 GHz pri 1.325V.
AMD Ryzen 9 3900X @ 4.3 GHz (1.35 V)
Temperature (Tdie)Raijintek EOS 240 RBW: 80Raijintek EOS 240 RBW80Gigabyte Aorus LC 280: 80,9Gigabyte Aorus LC 28080,9Cooler Master ML240L V2 RGB: 82Cooler Master ML240L V2 RGB82Raijintek Orcus 240 RBW: 87,3Raijintek Orcus 240 RBW87,3Noctua D15: 91,1Noctua D1591,10100
Impresivno! Najniža temperatura, i čak 7,3°C bolji rezultat od Orcusa 240 RBW. Očito su pumpa u radijatoru i velika disipacijska površina bakrene ploče pun pogodak. A sve za istu razinu buke.
Intel i7-8700K @ Core Enhancement (4.7 GHz)
Temperature (Tdie)Raijintek EOS 240 RBW: 77Raijintek EOS 240 RBW77Asus ROG Ryujin 240: 80Asus ROG Ryujin 24080Asus ROG Ryuo 240: 80Asus ROG Ryuo 24080Cooler Master ML240L V2 RGB: 80Cooler Master ML240L V2 RGB80Asus ROG Ryujin 360: 81Asus ROG Ryujin 36081Gigabyte Aorus LC 280: 81Gigabyte Aorus LC 28081Raijintek Orcus 240 RBW: 81Raijintek Orcus 240 RBW81CoolerMaster ML360R RGB: 82CoolerMaster ML360R RGB82Noctua D15: 83Noctua D1583Arctic LF 240: 88Arctic LF 24088Be Quiet! Dark Rock Pro 4: 90Be Quiet! Dark Rock Pro 490Be Quiet! Dark Rock 4: 92Be Quiet! Dark Rock 492Cryorig H7: 92Cryorig H792Arctic Freezer 12: 95Arctic Freezer 12950105
Opet izvrstan rezultat, 77°C je najniža vrijednost koju smo vidjeli s ovim procesorom. Prosječna je temperatura 73°C što ponovno odlično. Orcus 240 RBW je prosjek imao na 76,16 °C, Aorus LC 280 na malo boljih 72,16°C, a Noctua D15 prosjek drži na visokih 81°C.
Buka
Buka (dBa)Cooler Master ML240L V2 RGB: 40Cooler Master ML240L V2 RGB40Raijintek Orcus 240 RBW: 41,5Raijintek Orcus 240 RBW41,5Raijintek EOS 240 RBW: 41,6Raijintek EOS 240 RBW41,6Noctua D15: 42Noctua D1542Gigabyte Aorus LC 280: 45Gigabyte Aorus LC 28045050
Pri 1.500 okretaja u minuti su ventilatori s oko 39,5 dBA vrlo tihi, a na toj vrijednosti maksimalno rade na 3900X procesoru. Kod 8700K su se znali zavrtjeti na maksimalnih 1.800 okretaja i tada bi mjerenje pokazalo 41,6 dBA što je tek mrvicu iznad maksimuma Orcusovih ventilatora te i dalje sasvim ugodno za uši.
Rezultati testova
Stranica 3 od 4
