Sapphire Pulse RX 7600 XT 16G OC recenzija
· · Video · Stranica 2 od 6
Test sistem
Test sistem :: Hardware
Matična ploča Gigabyte Z790 Aorus Master X
Procesor(i) Intel i9 14900K
Memorija 2x 16 GB DDR5 G.Skill Trident Z5 RGB 6.800 MHz
Grafičke kartice Sapphire Pulse RX 7600 XT 16G OC; Driveri: Adrenaline 23.40.01.15
Zvučna kartica On Board
Napajanje SilverStone DA1000R Gold
SSD ADATA Swordfish 2TB
Monitor Dell S2721DGF
Testni sistem :: Software
OS Windows 11 22H2
DirectX verzija 12
3DMark TimeSpy, Port Royal, Speed Way, VRS
Anno 1800 In game benchmark, max. details, DX12
Borderlands 3 In-game benchmark, Ultra details
Cyberpunk 2077 In-game benchmark, Ultra details
Resident Evil 4 Gameplay benchmark, max details
FarCry 6 In-game benchmark, max. details
For Honor In-game benchmark, max. details
Ghost Recon Breakpoint In-game benchmark, Ultra
Godfall In-game benchmark, Epic details (DXR on & off)
F1 22 In-game benchmark, Max. details
Horizon Zero Dawn  In-game benchmark, Ultimate
Shadow of the Tomb Raider In-game benchmark, max. details, RTX On, SSAO Off
The Division 2 In-game benchmark, max. details
The Riftbreaker  In-game benchmark, max. details
The Calysto Protocol In-game benchmark, max. details
Company of Heroes 3  In-game benchmark, max. details
Način testiranja
Karticu smo testirali na Intelovoj platformi, a kao što znamo nema većih razlika između dvije platforme koje imamo za testove – Core i7-14900K i Ryzen 9 7950X. Resizable BAR je bio po defaultu uključen u BIOS-u ploče pa smo tako i testirali. Iako na grafovima ima kartica koje nisu testirane s BAR-om uključenim u budućnosti ćemo sve testirati tako jer je sada to defaultna postavka u BIOS-u. Iako AMD karticu pozicionira za 1080p segment, ona solidno potegnuti i u 1440p u većini naslova, pa će kod ove recenzije testovi biti samo u toj rezoluciji da ne gomilamo grafove. Koga zanimaju 1080p rezultati neka skokne na PowerColor recenziju. Testni monitor je Dellov S2721DGF rezolucije 2.560x 1.440 i stope osvježenja od 165 Hz. Baterija testova je standardna, a kao i do sada, napravili smo i testove zagrijavanja te potrošnje kroz nekoliko naslova. Uvijek uzimamo najveću vrijednost, a mjerena je potrošnja cijelog sistema. Vrijednosti buke koju navodimo u članku smo dobili mjerenjem uz pomoć Meterk MK09 mjerača. Ponašanje kartice i drivera kod testiranja Testirali smo s Adrenaline 23.40.01.15 driverima u beta verziji na Windowsima 11 22H2 i bilo je određenih problema u pojedinim naslovima kada bi imali potpuno crni ekran pri pokretanju benchmarka. No, na kraju smo ipak sve benchmarke odradili nakon više ponavljanja. Overclocking
Overclockirali smo uz pomoć Adrenaline drivera i Performance taba. Napon GPU-a nismo dirali, minimalni GPU takt postavili smo na 2,8 GHz, a maksimalni na 3,2 GHz. Maksimalnu snagu smo povećali za +15%. GPU-u će uz pomoć algoritma sam odrediti maksimalne taktove. Uz to, memoriju smo podigli na 2,5 GHz tj. 20 Gbps.
Kao i kod PowerColorove kartice, Hynixova se memorija pokazala kao solidan overclocker. Provjerom GPU-Z loga smo utvrdili kako je maksimalni takt GPU-a bio čak 3.257 MHz što je puno više nego kod PowerColorove kartice. Prosjeci po pojedinim naslovima su ipak bili znatno niži – između 2.700 i 2.800 MHz kao i kod konkurentske kartice pa će biti zanimljivo vidjeti kakve su performanse u usporedbi. Maksimalni board power draw je iznosio 225 W što je za 4 W iznad PowerColora. Rezultate overclockinga će te naravno vidjeti u zasebnim grafovima kao i uvijek.
Stranica 2 od 6
