SilentiumPC Grandis XE 1236 test
· · Hlađenje · Stranica 4 od 5
Rezultati testova
i5-3570K (4.2GHz) @ IDLESilentium Fera 2 – dual fan @ 1450 rpm: 25Silentium Fera 2 – dual fa…25Silentium Grandis XE1236 – dual fan @ 1450 rpm: 25Silentium Grandis XE1236 -…25Thermalright Ultra 120 Extreme – single fan @ 1500 rpm: 25Thermalright Ultra 120 Ext…25Silentium Fera 2 – single fan @ 1450 rpm: 25,75Silentium Fera 2 – single…25,75Silentium Grandis XE1236 – single fan @ 1450 rpm: 26Silentium Grandis XE1236 -…26Silentium Grandis XE1236 – dual fan @ 1000 rpm: 26Silentium Grandis XE1236 -…26Thermalright Ultra 120 Extreme – single fan @ 1000 rpm: 26Thermalright Ultra 120 Ext…26Silentium Fera 2 – dual fan @ 1000 rpm: 26,5Silentium Fera 2 – dual fa…26,5Silentium Fera 2 – single fan @ 1000 rpm: 28Silentium Fera 2 – single…28Silentium Grandis XE1236 – single fan @ 1000 rpm: 28Silentium Grandis XE1236 -…28031
Idle temperature nam nisu pokazale neke veće razlike u temperaturama, budući da je riječ o rasponu od 2-3 stupnja. Prva tri mjesta sa identičnim temperaturama dijele TRUE120 na maksimalnom broju okretaja, Grandis s dva ventilatora i Fera 2 u također push-pull konfiguraciji na 1450 okretaja.
i5-3570K (4.2GHz) @ LOADThermalright Ultra 120 Extreme – single fan @ 1500 rpm: 50,25Thermalright Ultra 120 Ext…50,25Silentium Grandis XE1236 – dual fan @ 1450 rpm: 51,5Silentium Grandis XE1236 -…51,5Silentium Grandis XE1236 – dual fan @ 1000 rpm: 53,25Silentium Grandis XE1236 -…53,25Thermalright Ultra 120 Extreme – single fan @ 1000 rpm: 53,5Thermalright Ultra 120 Ext…53,5Silentium Grandis XE1236 – single fan @ 1450 rpm: 57Silentium Grandis XE1236 -…57Silentium Fera 2 – dual fan @ 1450 rpm: 58Silentium Fera 2 – dual fa…58Silentium Fera 2 – single fan @ 1450 rpm: 59Silentium Fera 2 – single…59Silentium Grandis XE1236 – single fan @ 1000 rpm: 59Silentium Grandis XE1236 -…59Silentium Fera 2 – dual fan @ 1000 rpm: 60Silentium Fera 2 – dual fa…60Silentium Fera 2 – single fan @ 1000 rpm: 62Silentium Fera 2 – single…62068
Očekivano ili ne, prvu poziciju odnio je TRUE120 sa nešto više od stupnja razlike od Grandisa. Sa svoja dva ventilatora na maksimalnom i smanjenom broju okretaja zauzeo je drugu i treću poziciju prilikom našeg testiranja. Vremešni TRUE i dalje pokazuje zube u usporedbi s novijim igračima na tržištu. Tek smanjenjem brzine ventilatora na 1000 rpm, pada na četvrto mjesto s oko tri stupnja razlike u odnosu na Grandisa s jednim ventilatorom na 1450 okretaja. Fera 2 se smjestio u nekoj zlatnoj sredini po pitanju performansi, no na račun dva ventilatora na punoj brzini. Ostatak rezultata ne pokazuje veće razlike od 1-2 stupnja ukupno. Kao što uvijek kažemo, ove rezultate treba uzeti sa zrnom soli, budući da nismo imali snažniji procesor koji bi začinio čitavu stvar, a naša ploča se nije baš najbolje slagala s ovim procesorom na višim frekvencijama, tako da smo ostali na tek 4.2 GHz. Za nekakav kompromis po pitanju buke i performansi preporučamo korištenje Grandisa s dva ventilatora na nižim brzinama okretaja prilikom kojih ostvaruje i dalje odlične temperature. 50-ak stupnjeva je realno gledajući zanemarujuća temperatura za ovakve procesore.
Rezultati testova
Stranica 4 od 5
