Abit IP35 Dark Raider – zlatna sredina
· · MBO i RAM · Stranica 5 od 5
Zaključak – Conclusion
Abitica IP35 nas nije oduševila, ali ni pretjerano razočarala.
Za cca. 1000kn koliko košta u našim dućanima dobivate solidnog overclockera
sa ponešto manjkavim dizajnom i prosječnim bundleom. No, nakon višetjednog
rada i torture ni jednom nije popustila i mislimo kako je Abit napravio kvalitetan
i dugovječan proizvod. Kao što smo ranije napomenuli BIOS nudi pregršt opcija
za overclocking no krajnji rezultat od 405MHz FSB-a spada u prosjek klase.
Problem sa dvostrukim paljenjem overclockirane ploče pripisujemo verziji BIOS-a
te se nadamo kako će u kasnijim verzijama biti ispravljen. Kao zgodni feature
ove ploče navodimo HDMI podršku preko dodatnog bracketa. Ako ste zagriženi
OC-er sigurno ćete preskočiti ovu ploču i uzeti PRO model koji po raznim testovima
koje smo vidjeli sa lakoćom prelazi 500MHz FSB-a, a ako pak s druge starne
pazite na budžet no ipak želite malo OC-ati ova ploča bi mogla biti baš za
vas.
Conclusion in English
Abit IP35 board has not thrilled, neither disappointed us. For
circa 1000kn, you get a fair overclocker with somewhat lousy design and an
average bundle. But, after weeks of usage and torture the board has not shown any signs of
instability, and it’s our opinion that Abit has done a good job in building
a quality and long life product. As we mentioned earlier, BIOS offers us
a lot of options for overclocking to play with but the end result of 405MHz
FSB is just an average one. Problem with double reboot we detected will probably
be fixed with some new BIOS revision. Cool feature of this board is the
HDMI capability through additional bracket. If you are a hard core overclocker
you’ll definitely pass this board and go for a PRO model which easily exceeds
500MHz. But if you have to take your budget in mind and still want to overclock
a bit, this board might be a good choice.
Stranica 5 od 5
