ADATA Spectrix D40 32 GB & Gammix D10 16 GB recenzija
· · MBO i RAM · Stranica 3 od 3
Rezultati testova i zaključak
Rezultati testova X299 platforma
AIDA64 RAM ReadSpectrix D40 @ 3.466 MHz: 63.652Spectrix D40 @ 3.466 MHz63.652Spectrix D40 @ 3.000 MHz: 59.709Spectrix D40 @ 3.000 MHz59.709070.017
AIDA64 RAM WriteSpectrix D40 @ 3.466 MHz: 73.931Spectrix D40 @ 3.466 MHz73.931Spectrix D40 @ 3.000 MHz: 68.954Spectrix D40 @ 3.000 MHz68.954081.324
AIDA64 RAM CopySpectrix D40 @ 3.466 MHz: 59.878Spectrix D40 @ 3.466 MHz59.878Spectrix D40 @ 3.000 MHz: 53.188Spectrix D40 @ 3.000 MHz53.188065.866
AIDA64 LatencySpectrix D40 @ 3.466 MHz: 79,9Spectrix D40 @ 3.466 MHz79,9Spectrix D40 @ 3.000 MHz: 86,9Spectrix D40 @ 3.000 MHz86,9096
X299 platforma izvlači dobre četverokanalne performanse iz Spectrix kita, a pri overclockingu lijepo raste propusnost, dok vrijeme pristupa pada. X370 platforma
AIDA64 RAM ReadSpectrix D40 @ 2.933 MHz: 45.095Spectrix D40 @ 2.933 MHz45.095Gammix D10 @ 2.933 MHz: 44.485Gammix D10 @ 2.933 MHz44.485049.605
AIDA64 RAM WriteSpectrix D40 @ 2.933 MHz: 45.059Spectrix D40 @ 2.933 MHz45.059Gammix D10 @ 2.933 MHz: 43.871Gammix D10 @ 2.933 MHz43.871049.565
AIDA64 RAM CopySpectrix D40 @ 2.933 MHz: 43.199Spectrix D40 @ 2.933 MHz43.199Gammix D10 @ 2.933 MHz: 40.380Gammix D10 @ 2.933 MHz40.380047.519
AIDA64 LatencySpectrix D40 @ 2.933 MHz: 79,7Spectrix D40 @ 2.933 MHz79,7Gammix D10 @ 2.933 MHz: 82,5Gammix D10 @ 2.933 MHz82,5091
Propusnost na X370 platformi je nešto bolja za Spectrix kit unatoč činjenici kako oba rade na potpuno istim brzinama i latencijama – pripisat ćemo to činjenici kako sa Spectrixom popunjavamo sva četiri raspoloživa utora pa su i performanse propusnosti malo bolje. Ipak, vrijeme pristupa je veće jer se sada pristupa svim raspoloživim DIMM utorima. Overclocking vrijednosti na 3.066 MHz nismo stavljali, no porast je otprilike linearan.   Zaključak
ADATA ne kasni puno za konkurencijom i na tržište stavlja osvijetljeni Spectrix kit i to u dovoljno kombinacija i brzina, da zapapri i etabliranijoj konkurenciji. Istina, G.Skill je još uvijek nedodirljiv po overclocking mogućnosti, jer se i s latencijama XMP profila frekvencija može podizati što kod ADATA kita nije slučaj. Gammix će svima onima koji ne vole osvijetljene kitove donijeti slične performanse po nešto nižoj cijeni, ako uspoređujemo kitove istih specifikacija i kapaciteta. Overclocking mogućnosti oba kita su podjednake, no Gammix se ipak malo više zagrijava. S cijenom od oko 3.300 kuna Spectrix D40 AX4U300038G16-QRS kit nije ni malo jeftin, i sasvim je u rangu s primjerice usporedivom G.Skillovom memorijom. Ako vam ne treba četverokanalni kit, treba imati na pameti kako se Spectrix može nabaviti i u dvokanalnoj izvedbi i kako je tada znatno povoljniji. Za Gammix D10 AX4U300038G16-DRG još nije definirana cijena za naše tržište, a vani košta konkurentnih i hrvatskom džepu prihvatljivijih 160 €. Jamstvo koje daje hrvatski uvoznik je dvije godine.
Stranica 3 od 3
