ADATA SV620 240GB recenzija
· · Mediji · Stranica 2 od 2
Rezultati testova i zaključak
Rezultati testova
ATTO Disk BenchmarkSanDisk Extreme 510 @ Read: 461,927SanDisk Extreme 510 @ Read461,927ADATA SV620 240GB @ Read: 364,09ADATA SV620 240GB @ Read364,09ADATA SV620 240GB @ Write: 338,250ADATA SV620 240GB @ Write338,250SanDisk Extreme 510 @ Write: 245,568SanDisk Extreme 510 @ Write245,568ADATA HD710M @ Read: 116,508ADATA HD710M @ Read116,508ADATA HD710M @ Write: 115,481ADATA HD710M @ Write115,4810500
Crystal Disk MarkSanDisk Extreme 510 @ Read: 442,7SanDisk Extreme 510 @ Read442,7ADATA SV620 240GB @ Read: 280,3ADATA SV620 240GB @ Read280,3ADATA SV620 240GB @ Write: 272,7ADATA SV620 240GB @ Write272,7SanDisk Extreme 510 @ Write: 243,4SanDisk Extreme 510 @ Write243,4ADATA HD710M @ Read: 116,9ADATA HD710M @ Read116,9ADATA HD710M @ Write: 116,6ADATA HD710M @ Write116,60500
SV620 ima vrlo ujednačene linearne brzine zapisa i čitanja i kao što vidimo u zapisu je nešto bolji od San Diskovog Extreme 510 diska.
Kopiranje sa SSD-a na USBSanDisk Extreme 510 @ Large File (3.39 GB): 21,6SanDisk Extreme 510 @ Larg…21,6ADATA SV620 240GB @ Large File (3.39 GB): 26,4ADATA SV620 240GB @ Large…26,4ADATA HD710M @ Large File (3.39 GB): 34,1ADATA HD710M @ Large File…34,1SanDisk Extreme 510 @ Small Files (14.5 GB): 167,1SanDisk Extreme 510 @ Smal…167,1ADATA SV620 240GB @ Small Files (14.5 GB): 290ADATA SV620 240GB @ Small…290ADATA HD710M @ Small Files (14.5 GB): 342,2ADATA HD710M @ Small Files…342,20350
Test prijenosa podataka pokazuje veliku brzinu kod jednog većeg video fajla i nešto sporiju kod transfera puno manjih fajlova. Kod manjih fajlova performanse ni blizu nisu na razini Extreme 510 diska, no i dalje je to zadovoljavajuće brzo. Large File predstavlja jedan video fajl veličine 3.39 GB (3.564.010 KB) kojeg smo sa SSD-a (Corsair Neutron XT 480 GB), selili na testne diskove. Jednostavnom kalkulacijom dolazimo do grube brojke od oko 128 MB/s. Kod transfera velikog broja fajlova u Small Files testu dolazi do usporenja. Ovdje smo sa SSD-a kopirali podatke ukupne veličine 14.5 GB (15.569.798.024 bajta) i to raspoređene u 13.827 fajlova koji su se nalazili u 1.005 foldera. Ponovno, kalkulacija pokazuje kako je brzina transfera ugrubo oko 50 MB/s. Zaključak
SV620 je kao što smo vidjeli zadovoljavajuće brz disk koji se u radu ne zagrijava previše, a kompaktnih je dimenzija pa je lako prenosiv. Bit će idealan za sve koji ne žele prijenosni mehanički disk, od kojeg puno pouzdaniji, a jedino s čime se moraju pomiriti je viša cijena po GB kapaciteta. Ovaj disk kapaciteta 240 GB se prodaje po cijeni od oko 750 kuna, dok 480 GB model košta oko 1.500 kuna. Ako ga usporedimo sa SanDiskovim Extreme 510 vidimo kako je nešto veći, sporiji, puno se manje grije ali i košta dvije trećine cijene (u Njemačkoj je 510 480 GB 230 €, a SV620 480 GB 150 €). Ako pak nemate ništa protiv mehanike, treba reći kako za nešto manji iznos možete dobiti 1TB 2.5″ eksterni disk kao što je ADATA HD710M.
Stranica 2 od 2
