AMD Radeon RX 7800 XT 16GB & Sapphire Pulse Radeon RX 7700 XT 12GB recenzija
· · Video · Stranica 6 od 7
Rezultati testova – treći dio
Overclocking
Company of Heroes 3AMD Radeon RX 7800 XT: 159,64AMD Radeon RX 7800 XT159,64AMD Radeon RX 7800 XT @ OC: 159,59AMD Radeon RX 7800 XT @ OC159,59Sapphire RX 7700 XT @ OC: 141,6Sapphire RX 7700 XT @ OC141,6Sapphire RX 7700 XT: 139,73Sapphire RX 7700 XT139,730176
Cyberpunk 2077AMD Radeon RX 7800 XT @ OC: 97,21AMD Radeon RX 7800 XT @ OC97,21AMD Radeon RX 7800 XT: 92,99AMD Radeon RX 7800 XT92,99Sapphire RX 7700 XT @ OC: 82,35Sapphire RX 7700 XT @ OC82,35Sapphire RX 7700 XT: 80,26Sapphire RX 7700 XT80,260107
F1 22AMD Radeon RX 7800 XT: 270AMD Radeon RX 7800 XT270AMD Radeon RX 7800 XT @ OC: 263AMD Radeon RX 7800 XT @ OC263Sapphire RX 7700 XT @ OC: 223Sapphire RX 7700 XT @ OC223Sapphire RX 7700 XT: 215Sapphire RX 7700 XT2150297
Horizon Zero DawnAMD Radeon RX 7800 XT @ OC: 155AMD Radeon RX 7800 XT @ OC155AMD Radeon RX 7800 XT: 150AMD Radeon RX 7800 XT150Sapphire RX 7700 XT @ OC: 127Sapphire RX 7700 XT @ OC127Sapphire RX 7700 XT: 124Sapphire RX 7700 XT1240171
The Calysto ProtocolAMD Radeon RX 7800 XT @ OC: 93,21AMD Radeon RX 7800 XT @ OC93,21AMD Radeon RX 7800 XT: 86,83AMD Radeon RX 7800 XT86,83Sapphire RX 7700 XT @ OC: 79,15Sapphire RX 7700 XT @ OC79,150103
RX 7800 XT se jako čudno ponaša prilikom overclockinga pa je u nekom slučaju brža, a u drugom su performanse iste ili pak nešto niže. Da li je to slučaj samo s ovom referentnom vidjet ćemo u testovima nereferentnih modela, a čekaju nas dva.
S druge strane, porast kod RX 7700 XT je normalan u svim testiranim naslovima, premda ne i velik.
Potrošnja, zagrijavanje i buka
Potrošnja sistemaAMD Radeon RX 7800 XT: 470AMD Radeon RX 7800 XT470Sapphire Pulse RX 7700 XT: 450Sapphire Pulse RX 7700 XT450Gigabyte RTX 4060 Ti Gaming OC: 385Gigabyte RTX 4060 Ti Gamin…385Sapphire RX 7600 Pulse OC: 380Sapphire RX 7600 Pulse OC380Gigabyte RTX 4060 Gaming OC: 376Gigabyte RTX 4060 Gaming OC376PowerColor Hellhound RX 7600: 375PowerColor Hellhound RX 76…375AMD Radeon RX 7600: 360AMD Radeon RX 76003600517
Maksimalna potrošnja je dosta visoka u oba slučaja i Nvidia i dalje ima efikasniju arhitekturu. No, u prosjeku je to za RX 7800 XZ oko 430, a za slabiju oko 410 W.
ZagrijavanjeGigabyte RTX 4060 Gaming OC: 62,9Gigabyte RTX 4060 Gaming OC62,9Sapphire Pulse RX 7700 XT: 63Sapphire Pulse RX 7700 XT63Sapphire RX 7600 Pulse OC: 68Sapphire RX 7600 Pulse OC68Gigabyte RTX 4060 Ti Gaming OC: 68,7Gigabyte RTX 4060 Ti Gamin…68,7PowerColor Hellhound RX 7600: 70PowerColor Hellhound RX 76…70AMD Radeon RX 7600: 77AMD Radeon RX 760077AMD Radeon RX 7800 XT: 83AMD Radeon RX 7800 XT83091
AMD-ov polu zatvoreni tip hlandjaka i vrlo niska buka na koju su ciljali rezultira nešto višom temperaturom koja se još više osjeti na hot spotu gdje je dosegla 97°C. Sapphireova kartica je još tiša, a zbog otvorenijeg tipa hladnjaka se ne zagrijava previše – hot spot je bio na 89°C.
Buka (dBA)Gigabyte RTX 4060 Gaming OC: 35,1Gigabyte RTX 4060 Gaming OC35,1Sapphire Pulse RX 7700 XT: 35,1Sapphire Pulse RX 7700 XT35,1Gigabyte RTX 4060 Ti Gaming OC: 37,1Gigabyte RTX 4060 Ti Gamin…37,1AMD Radeon RX 7800 XT: 37,2AMD Radeon RX 7800 XT37,2Sapphire RX 7600 Pulse OC: 38,7Sapphire RX 7600 Pulse OC38,7PowerColor Hellhound RX 7600: 39,1PowerColor Hellhound RX 76…39,1AMD Radeon RX 7600: 39,9AMD Radeon RX 760039,9044
Pri punom opterećenju smo izmjerili (Meterk MK09) samo 35,1 dB(A) kod Sapphireove kartice, dok je AMD-ova referentna RX 7800 XT ostvarila također zadovoljavajuće tihih 37,2 dB(A). Obje su tako prikladne za gradnju tiših računala.
Stranica 6 od 7
