AMD Ryzen 5 5600X recenzija
· · Procesori · Stranica 5 od 6
Rezultati testiranja – treći dio
Porast performansi overclockingom
Cinebench 15Ryzen 5 5600X @ OC: 1.922Ryzen 5 5600X @ OC1.922Ryzen 5 5600X: 1.907Ryzen 5 5600X1.90702.114
Cinebench 20Ryzen 5 5600X @ OC: 4.471Ryzen 5 5600X @ OC4.471Ryzen 5 5600X: 4.351Ryzen 5 5600X4.35104.918
CoronaRyzen 5 5600X @ OC: 120Ryzen 5 5600X @ OC120Ryzen 5 5600X: 123Ryzen 5 5600X1230135
V-RayRyzen 5 5600X @ OC: 73Ryzen 5 5600X @ OC73Ryzen 5 5600X: 75Ryzen 5 5600X75083
wPrime v2.10Ryzen 5 5600X @ OC: 114,349Ryzen 5 5600X @ OC114,349Ryzen 5 5600X: 116,435Ryzen 5 5600X116,4350128
Porast performansi overclockingom nije velik jer procesor u svim ovim benchmarcima ionako boosta sve jezgre na oko 4,6+ GHz, a viđali smo i do 4,65 GHz. Tako s porastom na 4,7 GHz ne dobivamo previše.
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadRyzen 9 5950X: 68.569Ryzen 9 5950X68.569Ryzen 9 3900XT: 54.188Ryzen 9 3900XT54.188Ryzen 9 5900X: 54.099Ryzen 9 5900X54.099Core i7-10700K: 51.964Core i7-10700K51.964Ryzen 3 3300X: 51.794Ryzen 3 3300X51.794Ryzen 7 3800XT: 51.406Ryzen 7 3800XT51.406Core i5-10600K: 51.205Core i5-10600K51.205Core i5-10500: 51.131Core i5-1050051.131Ryzen 9 5900X: 51.129Ryzen 9 5900X51.129Core i5-10400: 51.080Core i5-1040051.080Ryzen 5 5600X: 50.950Ryzen 5 5600X50.950Ryzen 3 3100: 50.948Ryzen 3 310050.948075.426
AIDA64 RAM WriteRyzen 9 5950X: 53.108Ryzen 9 5950X53.108Ryzen 9 3900XT: 53.064Ryzen 9 3900XT53.064Ryzen 9 5900X: 53.028Ryzen 9 5900X53.028Core i7-10700K: 52.089Core i7-10700K52.089Core i5-10600K: 51.873Core i5-10600K51.873Core i5-10500: 51.767Core i5-1050051.767Core i5-10400: 51.474Core i5-1040051.474Ryzen 3 3100: 28.799Ryzen 3 310028.799Ryzen 3 3300X: 28.799Ryzen 3 3300X28.799Ryzen 9 5900X: 28.781Ryzen 9 5900X28.781Ryzen 5 5600X: 28.729Ryzen 5 5600X28.729Ryzen 7 3800XT: 27.798Ryzen 7 3800XT27.798058.419
AIDA64 RAM CopyRyzen 9 5950X: 64.649Ryzen 9 5950X64.649Ryzen 9 3900XT: 55.684Ryzen 9 3900XT55.684Ryzen 7 3800XT: 49.047Ryzen 7 3800XT49.047Ryzen 5 5600X: 48.992Ryzen 5 5600X48.992Ryzen 9 5900X: 48.489Ryzen 9 5900X48.489Ryzen 3 3100: 47.833Ryzen 3 310047.833Ryzen 3 3300X: 47.758Ryzen 3 3300X47.758Core i7-10700K: 47.125Core i7-10700K47.125Ryzen 9 5900X: 46.859Ryzen 9 5900X46.859Core i5-10600K: 45.223Core i5-10600K45.223Core i5-10400: 43.124Core i5-1040043.124Core i5-10500: 43.081Core i5-1050043.081071.114
AIDA64 RAM LatencyCore i7-10700K: 43,6Core i7-10700K43,6Core i5-10400: 46,7Core i5-1040046,7Core i5-10500: 46,9Core i5-1050046,9Core i5-10600K: 47,1Core i5-10600K47,1Ryzen 9 5900X: 58,8Ryzen 9 5900X58,8Ryzen 9 5900X: 59,1Ryzen 9 5900X59,1Ryzen 9 5950X: 59,8Ryzen 9 5950X59,8Ryzen 3 3300X: 65,8Ryzen 3 3300X65,8Ryzen 7 3800XT: 67,8Ryzen 7 3800XT67,8Ryzen 9 3900XT: 69Ryzen 9 3900XT69Ryzen 3 3100: 70,3Ryzen 3 310070,3Ryzen 5 5600X: 71,2Ryzen 5 5600X71,2078
Memorijske performanse su šarolike. Čitanje i zapis su slabiji, kopiranje nije loše i onda latencija dosta visoka.
Potrošnja sistema
Potrošnjai5-7500: 92i5-750092Ryzen 3 1200: 105Ryzen 3 1200105Ryzen 5 1400: 113Ryzen 5 1400113i7-6700K: 120i7-6700K120Core i5-10500: 124Core i5-10500124Core i5-10400: 125Core i5-10400125Ryzen 3 1300X: 125Ryzen 3 1300X125Ryzen 5 1500X: 130Ryzen 5 1500X130Ryzen 5 1600: 132Ryzen 5 1600132Ryzen 7 1700: 137Ryzen 7 1700137i7-7700K: 138i7-7700K138Ryzen 7 2700: 141Ryzen 7 2700141Ryzen 3 3100: 146Ryzen 3 3100146Ryzen 5 2600: 155Ryzen 5 2600155Ryzen 7 3700X: 160Ryzen 7 3700X160Ryzen 5 3600X: 162Ryzen 5 3600X162Ryzen 7 1700X: 162Ryzen 7 1700X162Ryzen 3 3300X: 163Ryzen 3 3300X163Ryzen 5 1600X: 163Ryzen 5 1600X163i5-8600K: 165i5-8600K165Core i5-10600K: 167Core i5-10600K167Ryzen 5 2600X: 170Ryzen 5 2600X170Ryzen 5 5600X: 172Ryzen 5 5600X172Ryzen 7 1800X: 173Ryzen 7 1800X173Core i7-10700K: 183Core i7-10700K183Ryzen 7 5800X: 183Ryzen 7 5800X183Ryzen 7 3800XT: 193Ryzen 7 3800XT193Ryzen 9 3900X: 195Ryzen 9 3900X195i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200Ryzen 7 2700X: 201Ryzen 7 2700X201i7-5820K: 205i7-5820K205Ryzen 9 5900X: 210Ryzen 9 5900X210Ryzen 9 3900XT: 211Ryzen 9 3900XT211i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225Ryzen 9 5950X: 225Ryzen 9 5950X225Ryzen 9 3950X: 230Ryzen 9 3950X2300253
Potrošnja sistema je mjerena s OCCT-ovim large testom kao i kod ostatka procesora i vidimo da je 5600X potrošač jednak kao i 10600K, i da za oko 10 W više troši od Ryzena 5 3600X koji je uzgred budi rečeno 95 W procesor. No, porast performansi je ipak puno veći od tih 6% veće potrošnje pa je efikasnost bolja.
Zagrijavanje @ Aorus Liquid Cooler 280
TemperatureRyzen 9 5950X: 61,5Ryzen 9 5950X61,5Ryzen 9 5900X: 64,5Ryzen 9 5900X64,5Ryzen 7 5800X: 68Ryzen 7 5800X68: 6969076
Maksimalna Tdie temperatura je najniža od četiri testirana procesora što je i logično. Zanimljivo za napomenuti je da je prosječni takt u 50 minuta testiranja (OCCT, Large Data), bio 4,65 GHz za sve jezgre što je više od deklariranog maksimalnog boost takta za jednu jezgru! Druga iskazana temperatura Tdie CCD1 je ipak bila viša – 68,3°C.
Za usporedbu smo napravili i testove zagrijavanja sa Wraith Spire hladnjakom i maksimalna Tdie temperatura je s njim iznosila 88,8°C, a Tdie CCD čak 92°C.
Stranica 5 od 6
