ASRock H55M Pro vs. MSI H55M-E33
Zaključak – Conclusion
Kao što smo na početku rekli, teško je ove dvije ploče smjestiti u istu kategoriju.
Po papirima, ali i u praksi je po svemu ASRockova ploča u prednosti, a ono najzanimljivije
u svemu je da je u prednosti i po cijeni. Vjerovali ili ne ASRockov model se
u domaćim trgovinama informatičke opreme dade nabaviti i po dosta nižoj cijeni
od MSI-eve ipak siromašnije ploče. ASRock donosi dva PCIe X16 utora, eSATA konektor,
Firewire, bolji je overclocker a i kavaliteta izrade i korištenih komponenata
je uzorna. Layout je no obje ploče dobar i tu nemamo većih zamjerki. Ukoliko
zažmirimo na ASRockov trik sa povećanjem BCLK-a, povišenim gotovo svim naponima
i u kranjem rezultatu znatno većoj potrošnji onda je situacija poprilično jasna.
U svakom je to pogledu bolji i opremljeniji proizvod, a samim time i isplativiji.
MSI ćemo preporučiti jedino u slučaju da slažete HTPC i pri tom pazite na potrošnju.
Conclusion
Like we said at the beginning of this article, it is difficult to put these
two boards in the same category. On paper and as we have seen in practice, ASRock
board is better in almost everything. One would imagine that MSI`s board is
therefore much cheaper, but that is not the case. To our big surprise, H55M
Pro board can in Croatian stores be found for even 10 € less that H55M-E33.
ASRock has two PCIe x16 slots, eSATA connector, Firewire, it is a better overclocker
and has a great build quality. Layout is good but both boards and there are
no major objections there. If we close our eyes on AS Rock’s little trick with
increased base clock, overvoltage and greater consumption, then the situation
is quite clear. In every respect it is a better product. We would recommend
MSI H55M-E33 only need a HTPC board, with lower consumption on your mind.
Stranica 6 od 6
