ASUS N3050M-E test
· · MBO i RAM · Stranica 2 od 5
ASUS N3050M-E – drugi dio
Specifikacije Asus N3050M-E
CPU (SoC) Intel Celeron Dual-Core N3050 SoC onboard Processors
OS Podrška Windows 8.1 , 64bit
Memorija 2 x U-DIMM, Max. 8GB, DDR3 1600/1066 MHz Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Utori za proširenja 1 x PCIe 2.0 x16 (x1 mode) 2 x PCIe 2.0 x1
Podrška za grafiku Integrated Graphics Processor Multi-VGA output support : HDMI/RGB ports – Supports HDMI with max. resolution 3840 x 2160 @ 30 Hz – Supports RGB with max. resolution 1920 x 1200 @ 60 Hz Maximum shared memory of 512 MB
LAN Realtek RTL8111H, 1 x Gigabit LAN Controller
Audio Realtek ALC887-VD2 8-Channel High Definition Audio CODEC
Storage Built-in Controller : 2 x SATA 6Gb/s ports, dark brown, Supports Intel Smart Connect Technology
USB Built-in Controller : 4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board) GL852G USB Hub : 4 x USB 2.0 port(s) (2 at back panel, , 2 at mid-board)
BIOS 64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.8, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information
Format mATX Form Factor 8.9 inch x 7.0 inch ( 22.6 cm x 17.8 cm )
Interni I/O portovi 1 x PS/2 keyboard (purple) 1 x PS/2 mouse (green) 1 x D-Sub 1 x HDMI 1 x LAN (RJ45) port(s) 2 x USB 3.0 (blue) 2 x USB 2.0 1 x Parallel port(s) 3 x Audio jack(s)
Specijalne značajke ASUS 5X Protection : – ASUS LANGuard – Advanced LAN protection – ASUS Enhanced DRAM Overcurrent Protection – Short circuit damage prevention – ASUS ESD Guards – Enhanced ESD protection – ASUS High-Quality 5K-Hour Solid Capacitors – 2.5x long lifespan with excellent durability – ASUS Stainless Steel Back I/O – 3x more durable corrosion-resistant coating ASUS Exclusive Features : – AI Suite 3 – Anti-Surge – Low EMI Solution – ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface – USB 3.0 Boost ASUS Quiet Thermal Solution : – Stylish Fanless Design Heat-sink solution – ASUS Fan Xpert ASUS EZ DIY : – ASUS CrashFree BIOS 3 – ASUS EZ Flash 2 – ASUS MyLogo 2 – ASUS UEFI BIOS EZ Mode – Push Notice ASUS Q-Design : – ASUS Q-Slot – ASUS Q-DIMM
Po specifikacijama vidimo kako je Asus primijenio neke od svojih poznatih tehnologija na ovoj ploči te kako korisnici neće ostati zakinuti za neke od opcija koje se nalaze i na puno jačim pločama. Ploča tako dolazi s opsežnim zaštitama kao što je LAN Guard, DRAM overcurrent zaštita, zatim su tu 5000 sati (105°C) solid kondenzatori, ESD zaštita, a ploča je prošla i testove, tj. provjere u trajanju od 7000 sati.
Na stražnjem se I/O panelu nalaze sljedeći konektori:
  • 1 x PS/2 keyboard (ljubičasti)
  • 1 x PS/2 mouse (zeleni)
  • 1 x D-Sub
  • 1 x HDMI
  • 1 x LAN (RJ45) port
  • 2 x USB 3.0 (plavi)
  • 2 x USB 2.0
  • 1 x Parallel port
  • 3 x Audio jacks
Kao kuriozitet tu nalazimo paralelni port koji je očito tu zbog moguće upotrebe ploče u industrijskim uvjetima, ostatak portova je poprilično standardan.
U detaljnijem pregledu ploče nailazimo na potpuno odvojenu audio jedinicu na kojoj dominira Realtekov ALC887-VD2 osam kanalni HD Audio CODEC a kraj njega su i audio kondenzatori te AAFP konektor. Na ovom dijelu ploče nalazimo i dva vertikalna SATA konektora, interne USB 2.0 i 3.0 konektore, COM port, konektor za ventilator, dva PCIe X1 porta, jedan PCIe X16 port (x8 električno) itd. PCIe portovi neće naravno moći svi raditi u punoj brzini jer procesor podržava samo četiri stazice.
Ploča donosi i podršku za DDR3L memoriju maksimalnog kapaciteta 8GB, a mi smo tek s nešto starijom memorijom imali problema, dok su noviji Corsairovi moduli radili bez problema. RTL8111H sa LAN guard zaštitom se nalazi tik iza stražnjih I/O portova, a tu nalazimo i dvo faznu napojnu jedinicu za procesor sa naravno digitalnim kontrolerom. Za dodatno napajanje je potrebno spojiti još i 4-pinski konektor uz naravno 24-pinski koji se nalazi na desnom boku. Na gornjoj strani ploče, tik iznad DIMM utora nalazi se još jedan konektor za ventilator. Ventilatori će u kućištu pomoći u hlađenju pasivnog hladnjaka koji se može malo zagrijati pod dužim opterećenjima procesora.
UEFI sučelje je tipično za Asus, te se sastoji od EZ i Advanced modova rada. Sve je pregledno i logično raspoređeno, a u odnosu na neke jače modele, naravno fale napredne opcije. Ipak, dopušteno nam je podešavati dosta toga pa ploču možemo lako prilagoditi prema svojim potrebama. Softverska podrška uključuje i FanXpert uz pomoć kojeg možemo nadzirati temperature sistema i upravljati ventilatorima u kućištu.
Stranica 2 od 5
