ASUS Striker Platinum GTX760
· · Video · Stranica 4 od 6
Rezultati testova – drugi dio
Hitman AbsolutionMSI R9 280X: 56,11MSI R9 280X56,11AMD HD7970 GHz: 55,62AMD HD7970 GHz55,62ASUS GTX770 DCU II OC: 49,38ASUS GTX770 DCU II OC49,38Asus GTX680 DCUII: 45,85Asus GTX680 DCUII45,85Sapphire R9 270X Toxic: 44,65Sapphire R9 270X Toxic44,65Gigabyte GTX580 SOC: 42,29Gigabyte GTX580 SOC42,29Sapphire R9 270X Vapor-X: 42,11Sapphire R9 270X Vapor-X42,11ASUS R9 270X DCU II TOP: 42,06ASUS R9 270X DCU II TOP42,06Asus Striker Platinum: 41,57Asus Striker Platinum41,57AMD R9 270X: 41,1AMD R9 270X41,1Gigabyte R9 270 OC: 38,95Gigabyte R9 270 OC38,95ASUS GTX660Ti DCU II TOP: 34,54ASUS GTX660Ti DCU II TOP34,54062
U Hitmanu na maksimalnim postavkama, GTX760 nije dovoljno brza kako bi prestigla R9 270X kartice, no ni najjača Toxic-ica joj ne bježi znatnije.
ThiefSapphire R9 270X Toxic: 41,4Sapphire R9 270X Toxic41,4Asus Striker Platinum: 38,7Asus Striker Platinum38,7046
Za Thiefa smi imali samo ove dvije kartice dostupne za test pa je graf kratak. Ipak, pokazuje kako je Striker u stanju pratiti jednu od najbržih R9 270X kartica i osigurati dobru igrivost na maksimalnim detaljima.
Tomb RaiderMSI R9 280X: 60,4MSI R9 280X60,4AMD HD7970 GHz: 57,7AMD HD7970 GHz57,7ASUS GTX770 DCU II OC: 56,7ASUS GTX770 DCU II OC56,7Asus GTX680 DCUII: 49,5Asus GTX680 DCUII49,5Sapphire R9 270X Toxic: 47,8Sapphire R9 270X Toxic47,8Asus GTX670 DCU Mini: 45,4Asus GTX670 DCU Mini45,4Asus Striker Platinum: 45Asus Striker Platinum45Sapphire R9 270X Vapor-X: 44,4Sapphire R9 270X Vapor-X44,4ASUS R9 270X DCU II TOP: 43,8ASUS R9 270X DCU II TOP43,8ASUS GTX660Ti DCU II TOP: 40,9ASUS GTX660Ti DCU II TOP40,9Gigabyte GTX580 SOC: 40,3Gigabyte GTX580 SOC40,3Gigabyte R9 270 OC: 39,8Gigabyte R9 270 OC39,8066
U Tomb Raideru je Striker Platinum ponovno za petama Toxicu, i iznad je njenih srodnih no malo sporijih Vapor-X i DCU II TOP kartica.
Overclocking
Bioshock InfiniteAsus Striker Platinum @ OC: 70,94Asus Striker Platinum @ OC70,94Asus Striker Platinum: 67,1Asus Striker Platinum67,1078
Hitman AbsolutionAsus Striker Platinum @ OC: 42,57Asus Striker Platinum @ OC42,57Asus Striker Platinum: 41,57Asus Striker Platinum41,57047
ThiefAsus Striker Platinum @ OC: 40,6Asus Striker Platinum @ OC40,6Asus Striker Platinum: 38,7Asus Striker Platinum38,7045
Overclocking nije pokazao pretjerani rast performansi i on je tek na prosječnih 5%.
Stranica 4 od 6
