Corsair Vengeance RGB 16 GB 3000 MHz recenzija
· · MBO i RAM · Stranica 3 od 4
Rezultati testova
X370 platforma
AIDA64 RAM ReadVengeance RGB @ 3.200 MHz: 47.364Vengeance RGB @ 3.200 MHz47.364Vengeance RGB @ 3.066 MHz: 45.831Vengeance RGB @ 3.066 MHz45.831Vengeance RGB @ 2.933 MHz: 44.757Vengeance RGB @ 2.933 MHz44.757052.100
AIDA64 RAM WriteVengeance RGB @ 3.200 MHz: 46.831Vengeance RGB @ 3.200 MHz46.831Vengeance RGB @ 3.066 MHz: 45.254Vengeance RGB @ 3.066 MHz45.254Vengeance RGB @ 2.933 MHz: 43.717Vengeance RGB @ 2.933 MHz43.717051.514
AIDA64 RAM CopyVengeance RGB @ 3.200 MHz: 41.014Vengeance RGB @ 3.200 MHz41.014Vengeance RGB @ 2.933 MHz: 40.523Vengeance RGB @ 2.933 MHz40.523Vengeance RGB @ 3.066 MHz: 40.364Vengeance RGB @ 3.066 MHz40.364045.115
AIDA64 LatencyVengeance RGB @ 3.066 MHz: 75,6Vengeance RGB @ 3.066 MHz75,6Vengeance RGB @ 3.200 MHz: 77,1Vengeance RGB @ 3.200 MHz77,1Vengeance RGB @ 2.933 MHz: 78,7Vengeance RGB @ 2.933 MHz78,7087
X370 platforma je ostvarila vrlo dobre performanse s ovim kitom, a i povećanje prilikom overclockinga je sasvim solidno. Na 3.066 MHz je pristupna latencija niža zbog stegnutijih latencija. Naime, na 2.933 MHz (D.O.C.P.) su latencije bile 16-17-17-35, kao i na 3.066 MHz, dok su na 3.200 rasle na 20-19-19-42.
Z370 platforma
AIDA64 RAM ReadVengeance RGB @ 3.466 MHz: 46.511Vengeance RGB @ 3.466 MHz46.511Vengeance RGB @ 3.333 MHz: 44.762Vengeance RGB @ 3.333 MHz44.762Vengeance RGB @ 3.000 MHz: 42.099Vengeance RGB @ 3.000 MHz42.099051.162
AIDA64 RAM WriteVengeance RGB @ 3.466 MHz: 49.513Vengeance RGB @ 3.466 MHz49.513Vengeance RGB @ 3.333 MHz: 47.464Vengeance RGB @ 3.333 MHz47.464Vengeance RGB @ 3.000 MHz: 43.342Vengeance RGB @ 3.000 MHz43.342054.464
AIDA64 RAM CopyVengeance RGB @ 3.466 MHz: 43.048Vengeance RGB @ 3.466 MHz43.048Vengeance RGB @ 3.333 MHz: 40.788Vengeance RGB @ 3.333 MHz40.788Vengeance RGB @ 3.000 MHz: 37.910Vengeance RGB @ 3.000 MHz37.910047.353
AIDA64 LatencyVengeance RGB @ 3.000 MHz: 52,3Vengeance RGB @ 3.000 MHz52,3Vengeance RGB @ 3.466 MHz: 53,2Vengeance RGB @ 3.466 MHz53,2Vengeance RGB @ 3.333 MHz: 54,4Vengeance RGB @ 3.333 MHz54,4060
Propusnost je vrlo slična na X370 i Z370 platformama, ali Intelov procesor ima bolji memorijski kontroler koji i za 20-tak nanosekundi brže pristupa memoriji. Latencije su s XMP profila (15-17-17-35), kod 3.333 MHz rasle na 17-19-19-39 do 18-20-20-42 pri 3.466 MHz pa su i vremena pristupa nešto viša.
Rezultati testova
Stranica 3 od 4
