G.Skill RipjawsX F3-17000CL9D-4GB
Zaključak – Conclusion
Na testu smo imali G.Skillovu memoriju iz Ripjaws X serije optimizirane za Intelovu Z68 i P67 platformu. Memorija je deklarirana za rad na 2133MHz pri latencijama od 9-11-9-28, 2T, na 1.6V, a testiranje i overclockiranje smo vršili s Asusovom Maximus IV Gene-Z pločom. Maksimalna postignuta frekvencija ove memorije bila je 2260MHz, pri CL9 i 1.6V. Pri tome smo bili ograničeni procesorom čiji je maksimalni baseclock iznosio 106MHz. Memorija je prilikom testiranja bila mlaka na dodir što znači da heatspreaderi dobro obavljaju svoj posao. Cijena po kojoj možete kupiti ovu memoriju je oko 380kn (PDV uključen) što je ekvivalentno solidnom 8GB DDR3 memorijskom kitu – dakle cijena je ipak previsoka unatoč visokoj frekvenciji. S druge pak strane, za nekoga tko se bavi overclockingom u slobodno vrijeme i želi imati mogućnost potegnuti preko 2200MHz, ovo je i više nego dobar izbor.
Conclusion
Today, we tested G.Skill`s Ripjaws X memory kit that is optimized for Intel’s Z68 and P67 platform. Memory is declared at 2133MHz frequency with timings of 9-11-9-28, 2T at 1.6V. Testing and overclocking was done on Asus`s Maximus IV Gene-Z motherboard, which proved to be very popular among enthusiasts. The maximum frequency we reached with this memory was 2260MHz, with CL9 @ 1.6V. In doing so, we were CPU limited whose maximum baseclock was 106MHz. All the time, this memory kit was only slightly warm during testing, which means that the heatspreaders are doing a good job. Ripjaws X F3-17000CL9D-4GB kit will set you back 380kn (with VAT), for which you can already buy an 8GB DDR3 memory kit. So, we can only conclude that the price is a bit steep, despite the fact the kit has a high operating frequency. On the other hand, for someone who is an overclocker in his/hers spare time and wants to have the possibility to pull over 2200MHz, this G.Skill`s kit will be more than a good choice.
Stranica 5 od 5
