Rezultati testova – treći dio
Overclocking
Borderlands Gigabyte RTX 4080 Super Gaming OC @ OC: 178,71 Gigabyte RTX 4080 Super Ga… 178,71 Gigabyte RTX 4080 Super Gaming OC: 174,93 Gigabyte RTX 4080 Super Ga… 174,93 0 197
Company of Heroes 3 Gigabyte RTX 4080 Super Gaming OC @ OC: 252,51 Gigabyte RTX 4080 Super Ga… 252,51 Gigabyte RTX 4080 Super Gaming OC: 239,73 Gigabyte RTX 4080 Super Ga… 239,73 0 278
Cyberpunk 2077 Gigabyte RTX 4080 Super Gaming OC @ OC: 122,65 Gigabyte RTX 4080 Super Ga… 122,65 Gigabyte RTX 4080 Super Gaming OC: 117,98 Gigabyte RTX 4080 Super Ga… 117,98 0 135
Horizon Zero Dawn Gigabyte RTX 4080 Super Gaming OC @ OC: 221 Gigabyte RTX 4080 Super Ga… 221 Gigabyte RTX 4080 Super Gaming OC: 211 Gigabyte RTX 4080 Super Ga… 211 0 243
The Caliisto Protocol : 156,63 156,63 : 148,79 148,79 0 172
Rezultati overclockinga su dobri u nekim naslovima, a u drugima slabiji pa je prosječan rast zapravo samo oko 4,3%.
Potrošnja, zagrijavanje i buka
Potrošnja sistema Gigabyte RTX 4080 Super Gaming OC: 562 Gigabyte RTX 4080 Super Ga… 562 Sapphire Nitro+ Radeon RX 7800 XT: 520 Sapphire Nitro+ Radeon RX… 520 Gigabyte RTX 4070 Ti Super Eagle OC: 502 Gigabyte RTX 4070 Ti Super… 502 AMD Radeon RX 7800 XT: 470 AMD Radeon RX 7800 XT 470 Gigabyte Radeon RX 7700 XT Gaming OC: 460 Gigabyte Radeon RX 7700 XT… 460 PowerColor Hellhound RX 7700 XT OC: 451 PowerColor Hellhound RX 77… 451 Sapphire Pulse RX 7700 XT: 450 Sapphire Pulse RX 7700 XT 450 Gigabyte RTX 4060 Ti Gaming OC: 385 Gigabyte RTX 4060 Ti Gamin… 385 Sapphire RX 7600 Pulse OC: 380 Sapphire RX 7600 Pulse OC 380 Gigabyte RTX 4060 Gaming OC: 376 Gigabyte RTX 4060 Gaming OC 376 PowerColor Hellhound RX 7600: 375 PowerColor Hellhound RX 76… 375 PowerColor RX 7600 XT 16GB: 372 PowerColor RX 7600 XT 16GB 372 AMD Radeon RX 7600: 360 AMD Radeon RX 7600 360 0 618
Potrošnja sistema s ovom karticom je dosta visoka što je i očekivano zbog visokih performansi, dok je GPU-Z log pokazao kako sama kartica “vuče” 319,3W (sam GPU čak 275 W).
Prilikom overclockinga se pak maksimalna temperatura GPU-a digla na tek 66°C (hot spot na 77,8°C), a podtošnja na 358,4 W (samo GPU je trošio 302,8 W).
Zagrijavanje PowerColor Hellhound RX 7700 XT OC: 62 PowerColor Hellhound RX 77… 62 Gigabyte RTX 4060 Gaming OC: 62,9 Gigabyte RTX 4060 Gaming OC 62,9 Sapphire Pulse RX 7700 XT: 63 Sapphire Pulse RX 7700 XT 63 Gigabyte Radeon RX 7700 XT Gaming OC: 65 Gigabyte Radeon RX 7700 XT… 65 Gigabyte RTX 4080 Super Gaming OC: 65,5 Gigabyte RTX 4080 Super Ga… 65,5 Sapphire Nitro+ Radeon RX 7800 XT: 66 Sapphire Nitro+ Radeon RX… 66 Sapphire RX 7600 Pulse OC: 68 Sapphire RX 7600 Pulse OC 68 Gigabyte RTX 4060 Ti Gaming OC: 68,7 Gigabyte RTX 4060 Ti Gamin… 68,7 PowerColor RX 7600 XT 16GB: 70 PowerColor RX 7600 XT 16GB 70 PowerColor Hellhound RX 7600: 70 PowerColor Hellhound RX 76… 70 Gigabyte RTX 4070 Ti Super Eagle OC: 70,1 Gigabyte RTX 4070 Ti Super… 70,1 AMD Radeon RX 7600: 77 AMD Radeon RX 7600 77 AMD Radeon RX 7800 XT: 83 AMD Radeon RX 7800 XT 83 0 91
Ogroman hladnjak i tri velika ventilatora jamac su za niske radne temperature. Temperatura GPU-a se na ovoj kartici tijekom igranja nije penjala iznad 65,5°C, a hot spot je bio na 75,4°C.
Buka (dBA) Sapphire Nitro+ Radeon RX 7800 XT: 34,9 Sapphire Nitro+ Radeon RX… 34,9 Gigabyte RTX 4060 Gaming OC: 35,1 Gigabyte RTX 4060 Gaming OC 35,1 Sapphire Pulse RX 7700 XT: 35,1 Sapphire Pulse RX 7700 XT 35,1 PowerColor Hellhound RX 7700 XT OC: 35,7 PowerColor Hellhound RX 77… 35,7 Gigabyte RTX 4060 Ti Gaming OC: 37,1 Gigabyte RTX 4060 Ti Gamin… 37,1 AMD Radeon RX 7800 XT: 37,2 AMD Radeon RX 7800 XT 37,2 Sapphire RX 7600 Pulse OC: 38,7 Sapphire RX 7600 Pulse OC 38,7 PowerColor Hellhound RX 7600 OC: 39 PowerColor Hellhound RX 76… 39 PowerColor RX 7600 XT 16GB: 39,1 PowerColor RX 7600 XT 16GB 39,1 Gigabyte RTX 4080 Super Gaming OC: 39,5 Gigabyte RTX 4080 Super Ga… 39,5 AMD Radeon RX 7600: 39,9 AMD Radeon RX 7600 39,9 Gigabyte RTX 4070 Ti Super Eagle OC: 42 Gigabyte RTX 4070 Ti Super… 42 Gigabyte Radeon RX 7700 XT Gaming OC: 44 Gigabyte Radeon RX 7700 XT… 44 0 48
Pri punom opterećenju smo izmjerili (Meterk MK09) solidnih 39,5 dB(A), što je čujno no ni malo nametljivo. Ventilatori se vrte do oko 1.800 okretaja u minuti (51% od maksimuma) i zapravo su zadovoljavajuće tihi za ovako moćnu karticu. Pri overclcokingu se zavrte tek malo brže – oko 1.870 okretaja u minuti (53% od maksimuma).
