Gigabyte X570S AERO G recenzija
· · MBO i RAM · Stranica 3 od 4
Rezultati testova
UL Benchmark
PCMark 10Asus ProArt X570-Creator WIFI: 8.351Asus ProArt X570-Creator W…8.351Gigabyte Z570S AERO G: 8.325Gigabyte Z570S AERO G8.32509.186
3DMark Time SpyAsus ProArt X570-Creator WIFI: 15.425Asus ProArt X570-Creator W…15.425Gigabyte Z570S AERO G: 15.369Gigabyte Z570S AERO G15.369016.968
3DMark CPU profile (Max Threads)Gigabyte Z570S AERO G: 12.722Gigabyte Z570S AERO G12.722Asus ProArt X570-Creator WIFI: 12.136Asus ProArt X570-Creator W…12.136013.994
PCMark mjeri općenite performanse sistema, Time Spy izvlači maksimum iz grafičke kartice, a CPU test izvlači maksimum iz svih dostupnih jezgri. Ploče su poprilično izjednačene u prva dva testa, ali novi CPU profile test unutar 3DMarka pokazuje da Gigabyteova ploča više forsira procesor od Asusove. CPU testovi
7-ZipGigabyte B550 Aorus Master: 130.189Gigabyte B550 Aorus Master130.189Gigabyte X570S Aorus Master: 127.811Gigabyte X570S Aorus Master127.811Asus ProArt B550-Creator: 127.103Asus ProArt B550-Creator127.103Asus ProArt X570-Creator WIFI: 111.574Asus ProArt X570-Creator W…111.574Gigabyte Z570S AERO G: 109.959Gigabyte Z570S AERO G109.9590143.208
Cinebench 20 (Single)Asus ProArt X570-Creator WIFI: 641Asus ProArt X570-Creator W…641Gigabyte X570S Aorus Master: 636Gigabyte X570S Aorus Master636Gigabyte Z570S AERO G: 635Gigabyte Z570S AERO G635Gigabyte B550 Aorus Master: 607Gigabyte B550 Aorus Master607Asus ProArt B550-Creator: 592Asus ProArt B550-Creator5920705
Cinebench 20 (Multi)Gigabyte Z570S AERO G: 10.552Gigabyte Z570S AERO G10.552Gigabyte B550 Aorus Master: 10.167Gigabyte B550 Aorus Master10.167Gigabyte X570S Aorus Master: 9.946Gigabyte X570S Aorus Master9.946Asus ProArt X570-Creator WIFI: 9.862Asus ProArt X570-Creator W…9.862Asus ProArt B550-Creator: 9.276Asus ProArt B550-Creator9.276011.607
Prema 7-Zip rezultatu ne bi se reklo da Gigabyteova ploča više forisra procesor kao što je to prethodni test pokazao, no u multithraded testu Cinebencha 20 se to ipak vidi. Single thread performanse ipak ostaju na strani Asusove ploče. Memorijska propusnost
AIDA64 – RAM ReadAsus ProArt B550-Creator: 54.916Asus ProArt B550-Creator54.916Gigabyte B550 Aorus Master: 54.898Gigabyte B550 Aorus Master54.898Gigabyte X570S Aorus Master: 54.800Gigabyte X570S Aorus Master54.800Gigabyte Z570S AERO G: 54.176Gigabyte Z570S AERO G54.176Asus ProArt X570-Creator WIFI: 54.137Asus ProArt X570-Creator W…54.137060.408
AIDA64 – RAM WriteGigabyte B550 Aorus Master: 54.112Gigabyte B550 Aorus Master54.112Gigabyte X570S Aorus Master: 54.096Gigabyte X570S Aorus Master54.096Asus ProArt B550-Creator: 53.967Asus ProArt B550-Creator53.967Gigabyte Z570S AERO G: 53.263Gigabyte Z570S AERO G53.263Asus ProArt X570-Creator WIFI: 53.147Asus ProArt X570-Creator W…53.147059.523
AIDA64 – RAM CopyGigabyte X570S Aorus Master: 51.786Gigabyte X570S Aorus Master51.786Gigabyte B550 Aorus Master: 51.680Gigabyte B550 Aorus Master51.680Asus ProArt B550-Creator: 50.475Asus ProArt B550-Creator50.475Gigabyte Z570S AERO G: 48.676Gigabyte Z570S AERO G48.676Asus ProArt X570-Creator WIFI: 47.709Asus ProArt X570-Creator W…47.709056.965
AIDA64 RAM LatencyAsus ProArt X570-Creator WIFI: 59,2Asus ProArt X570-Creator W…59,2Gigabyte Z570S AERO G: 59,3Gigabyte Z570S AERO G59,3Asus ProArt B550-Creator: 62Asus ProArt B550-Creator62Gigabyte B550 Aorus Master: 62,1Gigabyte B550 Aorus Master62,1Gigabyte X570S Aorus Master: 62,6Gigabyte X570S Aorus Master62,6069
Memorijska propusnost i latencija su vrlo slične kao i kod Asusove ploče. Audio performanse
Dva lošija mjerenja na audio jedinici i konačna ocjena je samo Good. Frekvencijski opseg i IMD + Noise su iz nekog razloga zaradili ocejnu Poor. Subjektivno, nismo osjetili nikakve probleme ili razlike u odnosu na bolje ocijenjene ploče u radu s našim Cambridge Soundworks zvučnicima.
Rezultati testova
Stranica 3 od 4
