Gigabyte Z590 Aorus Pro AX recenzija
· · MBO i RAM · Stranica 4 od 5
Rezultati testova
UL testovi
PCMark 10Gigabyte Z490 Aorus Master: 7.423Gigabyte Z490 Aorus Master7.423Gigabyte Z590 Vision G: 7.381Gigabyte Z590 Vision G7.381Gigabyte Z590 Aorus Pro AX: 7.310Gigabyte Z590 Aorus Pro AX7.31008.165
3DMark TimeSpyGigabyte Z590 Aorus Pro AX: 9.899Gigabyte Z590 Aorus Pro AX9.899Gigabyte Z490 Aorus Master: 9.873Gigabyte Z490 Aorus Master9.873Gigabyte Z590 Vision G: 9.844Gigabyte Z590 Vision G9.844010.889
PCMark 10 mjeri općenite performanse sistema, a 3DMark nam kombinirane performanse snage procesora i grafike. Razlike među pločama nisu velike, a dok je Pro AX u PCMarku posljednja, u TimeSpy testu izbija na vrh. CPU testovi
7-ZIPGigabyte Z590 Aorus Pro AX: 83.850Gigabyte Z590 Aorus Pro AX83.850Gigabyte Z490 Aorus Master: 83.266Gigabyte Z490 Aorus Master83.266Gigabyte Z590 Vision G: 83.196Gigabyte Z590 Vision G83.196092.235
Cinebench 20 nTGigabyte Z490 Aorus Master: 6.164Gigabyte Z490 Aorus Master6.164Gigabyte Z590 Vision G: 6.085Gigabyte Z590 Vision G6.085Gigabyte Z590 Aorus Pro AX: 6.035Gigabyte Z590 Aorus Pro AX6.03506.780
Cinebench 20 1TGigabyte Z490 Aorus Master: 507Gigabyte Z490 Aorus Master507Gigabyte Z590 Aorus Pro AX: 501Gigabyte Z590 Aorus Pro AX501Gigabyte Z590 Vision G: 474Gigabyte Z590 Vision G4740558
wPrime 2.0Gigabyte Z490 Aorus Master: 67,975Gigabyte Z490 Aorus Master67,975Gigabyte Z590 Vision G: 69,399Gigabyte Z590 Vision G69,399Gigabyte Z590 Aorus Pro AX: 69,51Gigabyte Z590 Aorus Pro AX69,51076
Samo je u prvom testu Pro AX na vrhu, dok je u ostalim testovima i ona sporija od Z490 Aorus Master koja očito izvlači malo više iz procesora. Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadGigabyte Z590 Vision G: 52.468Gigabyte Z590 Vision G52.468Gigabyte Z490 Aorus Master: 52.467Gigabyte Z490 Aorus Master52.467Gigabyte Z590 Aorus Pro AX: 52.414Gigabyte Z590 Aorus Pro AX52.414057.715
AIDA64 RAM WriteGigabyte Z490 Aorus Master: 51.550Gigabyte Z490 Aorus Master51.550Gigabyte Z590 Vision G: 51.323Gigabyte Z590 Vision G51.323: 51.23651.236056.705
AIDA64 RAM CopyGigabyte Z590 Aorus Pro AX: 48.325Gigabyte Z590 Aorus Pro AX48.325Gigabyte Z590 Vision G: 47.844Gigabyte Z590 Vision G47.844Gigabyte Z490 Aorus Master: 47.789Gigabyte Z490 Aorus Master47.789053.158
AIDA64 RAM LatencyGigabyte Z590 Aorus Pro AX: 45,9Gigabyte Z590 Aorus Pro AX45,9Gigabyte Z590 Vision G: 46,2Gigabyte Z590 Vision G46,2Gigabyte Z490 Aorus Master: 46,6Gigabyte Z490 Aorus Master46,6051
Memorijske performanse su solidne s najnižim pristupnim vremenom. Zagrijavanje
Pregledom temperatura koje mjere senzori na ploči vidimo kako je najtopliji senzor na VRM kontroleru s maksimumom na 93°C, te drugi s maksimumom na 84°C. Obje ove vrijednosti su slične kao kod Vision D ploče, no na ostatku su senzora temperature ipak niže, na nekima i po 5°C. Sve u svemu, temperature su u granicama normale, a tek bi poželjeli efikasnije hlađenje za VRM kontroler čija se temperatura popne i do 99°C prilikom overclockinga. Rightmark
Kvalitetu audio jedinice mjerimo RightMark audio analizatorom i dobivene vrijednosti su pred nama. Sve karakteristike su izvrsne i novi je Realtekov ALC4080 zaslužio najviše ocjene.
Rezultati testova
Stranica 4 od 5
