Gigabyte Z590 Vision G recenzija
· · MBO i RAM · Stranica 4 od 5
Rezultati testova
UL testovi
PCMark 10Gigabyte Z490 Aorus Master: 7.423Gigabyte Z490 Aorus Master7.423Gigabyte Z590 Vision G: 7.381Gigabyte Z590 Vision G7.38108.165
3DMark TimeSpyGigabyte Z490 Aorus Master: 9.873Gigabyte Z490 Aorus Master9.873Gigabyte Z590 Vision G: 9.844Gigabyte Z590 Vision G9.844010.860
PCMark 10 mjeri općenite performanse sistema, a 3DMark nam kombinirane performanse snage procesora i grafike. Razlike su kao što vidimo minimalne u oba benchmarka. CPU testovi
7-ZIPGigabyte Z490 Aorus Master: 83.266Gigabyte Z490 Aorus Master83.266Gigabyte Z590 Vision G: 83.196Gigabyte Z590 Vision G83.196091.593
Cinebench 20 nTGigabyte Z490 Aorus Master: 6.164Gigabyte Z490 Aorus Master6.164Gigabyte Z590 Vision G: 6.085Gigabyte Z590 Vision G6.08506.780
Cinebench 20 1TGigabyte Z490 Aorus Master: 507Gigabyte Z490 Aorus Master507Gigabyte Z590 Vision G: 474Gigabyte Z590 Vision G4740558
wPrime 2.0Gigabyte Z490 Aorus Master: 67,975Gigabyte Z490 Aorus Master67,975Gigabyte Z590 Vision G: 69,399Gigabyte Z590 Vision G69,399076
U prva dva testa su razlike manje, no onda dolazimo do single thread testa u Cinebenchu 20 gdje je razlika velika, a osjetna je i kod wPrime testa. Pregledom HWInfo logova dolazimo do toga da Z490 Aorus Master uvijek drži boost takt na svim jezgrama od 4,8 GHz, dok kod dužih opterećenja na Z590 Vision G ploči on ipak padne na 4,7 GHz. Slično je i kod boosta jedne jezgre. Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadGigabyte Z590 Vision G: 52.468Gigabyte Z590 Vision G52.468Gigabyte Z490 Aorus Master: 52.467Gigabyte Z490 Aorus Master52.467057.715
AIDA64 RAM WriteGigabyte Z490 Aorus Master: 51.550Gigabyte Z490 Aorus Master51.550Gigabyte Z590 Vision G: 51.323Gigabyte Z590 Vision G51.323056.705
AIDA64 RAM CopyGigabyte Z590 Vision G: 47.844Gigabyte Z590 Vision G47.844Gigabyte Z490 Aorus Master: 47.789Gigabyte Z490 Aorus Master47.789052.628
AIDA64 RAM LatencyGigabyte Z590 Vision G: 46,2Gigabyte Z590 Vision G46,2Gigabyte Z490 Aorus Master: 46,6Gigabyte Z490 Aorus Master46,6051
Propusnost memorije je vrlo slična, tj. razlike su minimalne. Zagrijavanje
Pregledom temperatura koje mjere senzori na ploči vidimo kako je najtopliji zapravo senzori na VRM kontroleru sa 92°C na jednom i 85°C na drugom senzoru što je i očekivano. i9-10850K vuče velike količine struje i to se mora negdje pretvoriti u silnu toplinu. Ostatak temperatura je niži i u granicama normale. Samo za usporedbu, temperature na Z490 Aorus Master su bile 86°C za VR Loop 1 i 70°C za VR Loop 2 – ona jasno ima puno jaču VRM jedinicu i nešto bolje hlađenje. U ovim smo testovima za opterećenje koristili loop test Cinebencha 20 (nT).
Rezultati testova
Stranica 4 od 5
