Kingmax DDR2-667 512 MB – zeleno, jeftino, dobro
· · MBO i RAM · Stranica 3 od 3
Zaključak (conclusion)
Kingmax je ponovo odradio izvrstan posao sa svojom memorijom. Premda ova memorija nema osobite performanse dok je rabimo na SPD postavkama, u stanju je pružiti zaista mnogo svima onima koji se ne overclockanja. Dakako, za to treba imati i solidnu ploču koja je memoriji u stanju pružiti odgovarajući napon. U nedostatku prave DDR2-800 memorije, Kingmax DDR2-667 je vrlo dobra alternativa, no treba imati na umu da vam ova memorija ipak ne može pružiti niske latencije pri taktu od 800 MHz. Ako takt pak planirate držati ispod ove vrijednosti, niske latencije bez problema postaju stvarnost.
Na kraju, kakva je situacija s dostupnošću i cijenom? Kingmax DDR2-667 module od 512 MB je bez problema moguće nabaviti u hrvatskim trgovinama i to po prilično niskoj cijeni od 310 do 350 kn. Sve u svemu, odlično.
Conclusion in english
Kingmax again did a very good with its memory. Altough modules we tested don’t have so good performance on SPD settings (defined by JEDEC), they are really excellent when it comes to overclocking. Of course, for this kind of sport you need to have a solid motheboard which is able to provide modules with enough "juice". In the absence of real DDR2-800 memory on the market (at least in mass quantities) , Kingmax DDR2-667 is a very good alternative, but you should still keep in mind that this memory can’t offer you agressive latencies on 800 MHz clock speed. On the other hand, if you are planning to keep the memory clock below this value, low latencies become a reality.
In the end, what is the situation with price and availabilty? Kingmax DDR2-667 modules with 512MB capacity can be easily obtained in croatian IT stores at a very competitive prices which ranges between 310 and 350 kn. All in all, excellent.
Stranica 3 od 3
