Rezultati testova – treći dio
Overclocking
The Division 2 MSI GTX 1660 Gaming X @ OC: 60 MSI GTX 1660 Gaming X @ OC 60 MSI GTX 1660 Gaming X: 54 MSI GTX 1660 Gaming X 54 0 66
Hitman MSI GTX 1660 Gaming X @ OC: 100,66 MSI GTX 1660 Gaming X @ OC 100,66 MSI GTX 1660 Gaming X: 96,78 MSI GTX 1660 Gaming X 96,78 0 111
Far Cry 5 MSI GTX 1660 Gaming X @ OC: 83 MSI GTX 1660 Gaming X @ OC 83 MSI GTX 1660 Gaming X: 76 MSI GTX 1660 Gaming X 76 0 91
Shadow of the Tomb Raider MSI GTX 1660 Gaming X @ OC: 56 MSI GTX 1660 Gaming X @ OC 56 MSI GTX 1660 Gaming X: 51 MSI GTX 1660 Gaming X 51 0 62
Strange Brigade MSI GTX 1660 Gaming X @ OC: 93 MSI GTX 1660 Gaming X @ OC 93 MSI GTX 1660 Gaming X: 83 MSI GTX 1660 Gaming X 83 0 102
Kartice se jednako overclockiraju unatoč različitim ograničenjima (114% vs. 107%), a i porast performansi je vrlo sličan, osim u Divisionu 2, gdje je MSI kartica bolje “disala”.
Potrošnja, buka i zagrijavanje
Potrošnja sistema @ i7-8700K @ 5.0 GHz MSI RTX 2080 Ti Gaming X Trio: 476 MSI RTX 2080 Ti Gaming X T… 476 AMD Radeon VII: 432 AMD Radeon VII 432 Sapphire Vega 56 Nitro+: 355 Sapphire Vega 56 Nitro+ 355 MSI RTX2070 Gaming Z: 351 MSI RTX2070 Gaming Z 351 Gigabyte RTX 2070 Gaming OC White: 346 Gigabyte RTX 2070 Gaming O… 346 MSI RTX 2060 Gaming Z: 325 MSI RTX 2060 Gaming Z 325 PowerColor RedDevil RX590 OC: 323 PowerColor RedDevil RX590… 323 MSI RTX2070 8GB Armor: 320 MSI RTX2070 8GB Armor 320 Gigabyte RTX 2060 Gaming OC Pro: 309 Gigabyte RTX 2060 Gaming O… 309 Gigabyte GTX 1660 Ti Gaming OC: 250 Gigabyte GTX 1660 Ti Gamin… 250 Gigabyte GTX 1660 Gaming OC: 240 Gigabyte GTX 1660 Gaming OC 240 MSI GTX 1660 Gaming X: 225 MSI GTX 1660 Gaming X 225 0 524
Potrošnju sistema uvijek mjerimo u Hitmanu pri čemu tražimo maksimalu brojku tijekom trajanja benchmarka . Ovdje je MSI kartica trošila 15 W manje od Gigabyteove što znači da ima malo efikasniju napojnu jedinicu uz mrvicu niži boost takt. I GPU-Z log je zabilježio razliku u potrošnji. Kod Gaming X kartice je to bilo 121.9 W, a kod Gaming OC 137.5.
Zagrijavanje AMD Radeon Vega 64 Liquid: 55 AMD Radeon Vega 64 Liquid 55 AMD Radeon R9 Fury X: 58 AMD Radeon R9 Fury X 58 ASUS STRIX GTX1080 11Gbps: 60 ASUS STRIX GTX1080 11Gbps 60 Gigabyte GTX970 Gaming G1: 60 Gigabyte GTX970 Gaming G1 60 MSI RX570 Gaming X 4GB: 60 MSI RX570 Gaming X 4GB 60 Asus GTX1060 STRIX: 61 Asus GTX1060 STRIX 61 ASUS GTX780 DCU II OC: 62 ASUS GTX780 DCU II OC 62 AMD R9 295X2: 63 AMD R9 295X2 63 ASUS Matrix Platinum GTX980: 64 ASUS Matrix Platinum GTX980 64 ASUS STRIX RX580 8GB TOP: 64 ASUS STRIX RX580 8GB TOP 64 Gigabyte GTX 1660 Gaming OC: 64 Gigabyte GTX 1660 Gaming OC 64 Gigabyte GTX 1660 Ti Gaming OC: 64 Gigabyte GTX 1660 Ti Gamin… 64 MSI GTX 1660 Gaming X: 64 MSI GTX 1660 Gaming X 64 MSI RTX2070 8GB Armor: 65 MSI RTX2070 8GB Armor 65 Gigabyte GTX1060 Gaming G1: 65 Gigabyte GTX1060 Gaming G1 65 MSI GTX1060 Gaming X: 66 MSI GTX1060 Gaming X 66 Sapphire Nitro+ Radeon RX Vega 56: 66 Sapphire Nitro+ Radeon RX… 66 MSI RTX 2060 Gaming Z: 67 MSI RTX 2060 Gaming Z 67 Gigabyte GTX1070 Gaming G1: 67 Gigabyte GTX1070 Gaming G1 67 MSI GTx1070 Ti Gaming X 8 GB: 68 MSI GTx1070 Ti Gaming X 8… 68 MSI GTX980 Gaming 4G: 68 MSI GTX980 Gaming 4G 68 ASUS GTX1060 9Gbps: 69 ASUS GTX1060 9Gbps 69 Gigabyte RTX 2060 Gaming OC Pro: 69 Gigabyte RTX 2060 Gaming O… 69 MSI GTX1070 Gaming X: 69 MSI GTX1070 Gaming X 69 MSI R9 290X Lightning: 69 MSI R9 290X Lightning 69 MSI RX580 8GB Gaming X: 70 MSI RX580 8GB Gaming X 70 Sapphire R9 290X Vapor-X 4GB OC: 70 Sapphire R9 290X Vapor-X 4… 70 Sapphire R9 390X Tri-X: 70 Sapphire R9 390X Tri-X 70 MSI RTX 2080 Ti Gaming X Trio: 71 MSI RTX 2080 Ti Gaming X T… 71 Asus Dual RX580 8GB: 71 Asus Dual RX580 8GB 71 Asus GTX780 STRIX OC: 71 Asus GTX780 STRIX OC 71 Gigabyte GTX580 SOC: 71 Gigabyte GTX580 SOC 71 Gigabyte GTX770 OC: 71 Gigabyte GTX770 OC 71 MSI GTX770 TwinFrozr: 71 MSI GTX770 TwinFrozr 71 MSI GTX1080 Ti Gaming X: 71 MSI GTX1080 Ti Gaming X 71 MSI RTX2070 Gaming Z: 71 MSI RTX2070 Gaming Z 71 MSI RX480 Gaming X 8GB: 71 MSI RX480 Gaming X 8GB 71 Sapphire R9 290X Vapor-X 8GB: 71 Sapphire R9 290X Vapor-X 8… 71 MSI GTX1080 Gaming X: 72 MSI GTX1080 Gaming X 72 ASUS STRIX Radeon RX Vega 64: 72 ASUS STRIX Radeon RX Vega… 72 Gigabyte RTX 2070 Gaming OC White: 72 Gigabyte RTX 2070 Gaming O… 72 Sapphire R9 290X Tri-X 8GB @ OC: 73 Sapphire R9 290X Tri-X 8GB… 73 Sapphire R9 Fury Tri-X: 73 Sapphire R9 Fury Tri-X 73 AMD Radeon VII: 74 AMD Radeon VII 74 Sapphire R9 390 Nitro: 74 Sapphire R9 390 Nitro 74 Sapphire RX580 Nitro+ 8GB: 74 Sapphire RX580 Nitro+ 8GB 74 Sapphire R9 290X Tri-X 8GB: 75 Sapphire R9 290X Tri-X 8GB 75 AMD R9 Nano: 75 AMD R9 Nano 75 ASUS Matrix Platinum GTX780Ti: 75 ASUS Matrix Platinum GTX78… 75 Gainward GTX970 Phantom: 75 Gainward GTX970 Phantom 75 Sapphire Nitro R9 Fury: 75 Sapphire Nitro R9 Fury 75 AMD Radeon RX Vega 56: 76 AMD Radeon RX Vega 56 76 ASUS STRIX GTX1080: 76 ASUS STRIX GTX1080 76 Sapphire RX480 Nitro+ 4GB: 77 Sapphire RX480 Nitro+ 4GB 77 PowerColor RedDevil RX590 OC: 78 PowerColor RedDevil RX590… 78 Sapphire R9 290 Tri-X: 80 Sapphire R9 290 Tri-X 80 Nvidia GTX980: 81 Nvidia GTX980 81 AMD Radeon RX Vega 64: 83 AMD Radeon RX Vega 64 83 ASUS STRIX R9 390X 8GB: 83 ASUS STRIX R9 390X 8GB 83 Nvidia GTX980 Ti: 84 Nvidia GTX980 Ti 84 Nvidia GTX780 Ti: 84 Nvidia GTX780 Ti 84 Nvidia GTX1080: 84 Nvidia GTX1080 84 GTX1080 Ti: 84 GTX1080 Ti 84 AMD Radeon RX 480: 90 AMD Radeon RX 480 90 ASUS MARS 760: 93 ASUS MARS 760 93 AMD Radeon R9 290: 94 AMD Radeon R9 290 94 AMD Radeon R9 290X: 95 AMD Radeon R9 290X 95 0 105
Ventilatori miruju do oko 63°C nakon čega se zavrte i ne idu nikada preko 1.500 okretaja u minuti. U radu su zadovoljavajuće tihi, izmjerili smo maksimalnih 48 dB, a temperaturu grafičkog procesora zadržavaju na solidnih 64°C. Hladnjaci su dakle identičnih performansi na Gaming X i Gaming OC, pri čemu je Gigabyteova kartica ipak nešto tiša (2 dB).
