MSI GeForce RTX 2070 Gaming Z 8GB recenzija
· · Video · Stranica 5 od 6
Rezultati testova – treći dio
Overclocking
DeusEX Mankind DividedRTX2070 Gaming Z @ OC: 61,6RTX2070 Gaming Z @ OC61,6RTX2070 Armor @ OC: 58,9RTX2070 Armor @ OC58,9RTX2070 Gaming Z: 55,7RTX2070 Gaming Z55,7RTX2070 Armor: 54,5RTX2070 Armor54,5068
HitmanRTX2070 Gaming Z @ OC: 114,83RTX2070 Gaming Z @ OC114,83RTX2070 Armor @ OC: 109,25RTX2070 Armor @ OC109,25RTX2070 Gaming Z: 104,24RTX2070 Gaming Z104,24RTX2070 Armor: 100,31RTX2070 Armor100,310126
DOW IIIRTX2070 Gaming Z @ OC: 101,1RTX2070 Gaming Z @ OC101,1RTX2070 Gaming Z: 95,35RTX2070 Gaming Z95,35RTX2070 Armor @ OC: 95RTX2070 Armor @ OC95RTX2070 Armor: 89,42RTX2070 Armor89,420111
Rise of the Tomb Raider (SSAA 2x)RTX2070 Gaming Z @ OC: 70,62RTX2070 Gaming Z @ OC70,62RTX2070 Armor @ OC: 67,50RTX2070 Armor @ OC67,50RTX2070 Gaming Z: 66,6RTX2070 Gaming Z66,6RTX2070 Armor: 62,37RTX2070 Armor62,37078
Armorica je pokazala solidan overclocking potencijal s porastom od 7.85%, a kod Gaming Z je to oko 7.2% u odnosu na tvorničke performanse. Uz to, zanimljivo je primijetiti i kako je overclockirana Gaming Z u prosjeku brža od overclockirane Armorice za 5.15%. Ako pak pogledamo ukupnu “razliku potencijala”, između neoverclockirane Armorice i overclockirane Gaming Z ona je impresivnih 13.4%. RTX 2070 ovime dokazuje kako je pun pogodak. Uz to, potrošnja nije rasla drastično.
4K performanse
DeusEX Mankind DividedRTX2070 Gaming Z: 30,3RTX2070 Gaming Z30,3RTX2070 Armor: 28,4RTX2070 Armor28,4033
HitmanRTX2070 Gaming Z: 60,64RTX2070 Gaming Z60,64RTX2070 Armor: 52,58RTX2070 Armor52,58067
Rise of the Tomb Raider (SSAA 2x)RTX2070 Gaming Z: 30,82RTX2070 Gaming Z30,82RTX2070 Armor: 29,25RTX2070 Armor29,25034
Gaming Z je i u 4K gamingu nešto brža od Armorice, no i dalje to nisu performanse za gladak gaming, barem u dva zahtjevnija naslova.
Potrošnja, buka i zagrijavanje
Potrošnja sistema @ i7-8700KMSI RTX2070 Gaming Z: 299MSI RTX2070 Gaming Z299MSI RTX2070 8GB Armor: 271MSI RTX2070 8GB Armor2710329
RTX 2070 kartice nisu veliki potrošači i sistem s Gaming Z troši oko 28 W više, no dodatne performanse to opravdavaju.
ZagrijavanjeAMD Radeon Vega 64 Liquid: 55AMD Radeon Vega 64 Liquid55AMD Radeon R9 Fury X: 58AMD Radeon R9 Fury X58ASUS STRIX GTX1080 11Gbps: 60ASUS STRIX GTX1080 11Gbps60Gigabyte GTX970 Gaming G1: 60Gigabyte GTX970 Gaming G160MSI RX570 Gaming X 4GB: 60MSI RX570 Gaming X 4GB60Asus GTX1060 STRIX: 61Asus GTX1060 STRIX61ASUS GTX780 DCU II OC: 62ASUS GTX780 DCU II OC62AMD R9 295X2: 63AMD R9 295X263ASUS Matrix Platinum GTX980: 64ASUS Matrix Platinum GTX98064ASUS STRIX RX580 8GB TOP: 64ASUS STRIX RX580 8GB TOP64MSI RTX2070 8GB Armor: 65MSI RTX2070 8GB Armor65Gigabyte GTX1060 Gaming G1: 65Gigabyte GTX1060 Gaming G165MSI GTX1060 Gaming X: 66MSI GTX1060 Gaming X66Sapphire Nitro+ Radeon RX Vega 56: 66Sapphire Nitro+ Radeon RX…66Gigabyte GTX1070 Gaming G1: 67Gigabyte GTX1070 Gaming G167MSI GTx1070 Ti Gaming X 8 GB: 68MSI GTx1070 Ti Gaming X 8…68MSI GTX980 Gaming 4G: 68MSI GTX980 Gaming 4G68ASUS GTX1060 9Gbps: 69ASUS GTX1060 9Gbps69MSI GTX1070 Gaming X: 69MSI GTX1070 Gaming X69MSI R9 290X Lightning: 69MSI R9 290X Lightning69MSI RX580 8GB Gaming X: 70MSI RX580 8GB Gaming X70Sapphire R9 290X Vapor-X 4GB OC: 70Sapphire R9 290X Vapor-X 4…70Sapphire R9 390X Tri-X: 70Sapphire R9 390X Tri-X70Asus Dual RX580 8GB: 71Asus Dual RX580 8GB71Asus GTX780 STRIX OC: 71Asus GTX780 STRIX OC71Gigabyte GTX580 SOC: 71Gigabyte GTX580 SOC71Gigabyte GTX770 OC: 71Gigabyte GTX770 OC71MSI GTX770 TwinFrozr: 71MSI GTX770 TwinFrozr71MSI GTX1080 Ti Gaming X: 71MSI GTX1080 Ti Gaming X71MSI RTX2070 Gaming Z: 71MSI RTX2070 Gaming Z71MSI RX480 Gaming X 8GB: 71MSI RX480 Gaming X 8GB71Sapphire R9 290X Vapor-X 8GB: 71Sapphire R9 290X Vapor-X 8…71MSI GTX1080 Gaming X: 72MSI GTX1080 Gaming X72ASUS STRIX Radeon RX Vega 64: 72ASUS STRIX Radeon RX Vega…72Sapphire R9 290X Tri-X 8GB @ OC: 73Sapphire R9 290X Tri-X 8GB…73Sapphire R9 Fury Tri-X: 73Sapphire R9 Fury Tri-X73Sapphire R9 390 Nitro: 74Sapphire R9 390 Nitro74Sapphire RX580 Nitro+ 8GB: 74Sapphire RX580 Nitro+ 8GB74Sapphire R9 290X Tri-X 8GB: 75Sapphire R9 290X Tri-X 8GB75AMD R9 Nano: 75AMD R9 Nano75ASUS Matrix Platinum GTX780Ti: 75ASUS Matrix Platinum GTX78…75Gainward GTX970 Phantom: 75Gainward GTX970 Phantom75Sapphire Nitro R9 Fury: 75Sapphire Nitro R9 Fury75AMD Radeon RX Vega 56: 76AMD Radeon RX Vega 5676ASUS STRIX GTX1080: 76ASUS STRIX GTX108076Sapphire RX480 Nitro+ 4GB: 77Sapphire RX480 Nitro+ 4GB77Sapphire R9 290 Tri-X: 80Sapphire R9 290 Tri-X80Nvidia GTX980: 81Nvidia GTX98081AMD Radeon RX Vega 64: 83AMD Radeon RX Vega 6483ASUS STRIX R9 390X 8GB: 83ASUS STRIX R9 390X 8GB83Nvidia GTX980 Ti: 84Nvidia GTX980 Ti84Nvidia GTX780 Ti: 84Nvidia GTX780 Ti84Nvidia GTX1080: 84Nvidia GTX108084GTX1080 Ti: 84GTX1080 Ti84AMD Radeon RX 480: 90AMD Radeon RX 48090ASUS MARS 760: 93ASUS MARS 76093AMD Radeon R9 290: 94AMD Radeon R9 29094AMD Radeon R9 290X: 95AMD Radeon R9 290X950105
TU106 je na Gaming Z brz i radi često i iznad 1.900 MHz, pa je jasno i da se zagrijava nešto više. Maksimalna izmjerena temperatura je bila 71°C, a maksimalni broj okretaja pri tome nešto iznad 1.300. Pri tim su okretajima ventilatori i dalje vrlo tihi i buka ne prelazi sasvim ugodnih 47 dB. Temperatura se prilikom overclockinga podigla samo za 1°C, a ventilatori su se zavrtjeli do oko 1.500 okretaja uz porast buke na i dalje tihih 48 dB.
Stranica 5 od 6
