Recenzija – MSGW Gamer Extreme X299 i101
· · Računala · Stranica 4 od 5
Rezultati testiranja – drugi dio
Memorijske performanse
AIDA64 RAM ReadMSGW X299 Gamer Extreme: 77.183MSGW X299 Gamer Extreme77.183084.901
AIDA64 RAM WriteMSGW X299 Gamer Extreme: 73.128MSGW X299 Gamer Extreme73.128080.441
AIDA64 RAM CopyMSGW X299 Gamer Extreme: 64.635MSGW X299 Gamer Extreme64.635071.099
AIDA64 RAM LatencyMSGW X299 Gamer Extreme: 70MSGW X299 Gamer Extreme70077
Memorijske performanse nisu najbolje koje smo vidjeli za X299 platformu, no sasvim su adekvatne i zapravo je teško opravdati nabavku bilo čega bržeg od četverokanalnog kita brzine 3.000 MHz. SSD i HDD performanse
Performanse M.2 SSD-a su očekivano visoke i on je odličan izbor za ovakvo računalo, za instalaciju OS-a i aplikacija/igara koje najčešće koristimo. Sve ostalo može ići na WD Black od 2 TB, koji ima znatno niže performanse ali sasvim u skladu s onime što HDD-i inače daju. Overclocking
Blenderi9-7900X @ 4.3GHz: 192,53i9-7900X @ 4.3GHz192,53i9-7900X @ 4.0 GHz: 204,38i9-7900X @ 4.0 GHz204,380225
Cinebench 15i9-7900X @ 4.3GHz: 2.316i9-7900X @ 4.3GHz2.316i9-7900X @ 4.0 GHz: 2.180i9-7900X @ 4.0 GHz2.18002.548
TrueCrypt v7.1i9-7900X @ 4.3GHz: 13,2i9-7900X @ 4.3GHz13,2i9-7900X @ 4.0 GHz: 12,2i9-7900X @ 4.0 GHz12,2015
wPrime v2.10i9-7900X @ 4.3GHz: 70,256i9-7900X @ 4.3GHz70,256i9-7900X @ 4.0 GHz: 75,755i9-7900X @ 4.0 GHz75,755083
Vidimo skoro pa linearan porast performansi u svim testovima. Potrošnja i zagrijavanje
PotrošnjaRyzen 7 1800X: 173Ryzen 7 1800X173i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200i7-5820K: 205i7-5820K205i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225i7-4960X: 252i7-4960X252i7-5960X: 255i7-5960X255i7-3960X: 267i7-3960X267Threadripper 1920X: 280Threadripper 1920X280Threadripper 1950X: 290Threadripper 1950X290i9-7900X non-enhanced: 295i9-7900X non-enhanced295i9-7900X enhanced: 400i9-7900X enhanced4000440
Potrošnja procesora (sistema) se uvelike razlikuje kod isključene i uključene MultiCore Enhancement opcije, a overclockingom na 4.3 to još raste na oko 450 W. Jasno je kako je 7900X veliki potrošač i kako mu treba osigurati moćno napajanje i moćno hlađenje. AMD s Threadripperima ovdje odnosi performance-per-watt bitku.
Temperaturei9-7900X non-enhanced: 90i9-7900X non-enhanced90i9-7900X enhanced: 104i9-7900X enhanced1040114
Velika je razlika u temperaturi kada isključimo MultiCore Enhancement pa to svakako i preporučujemo da napravite, osim ako vam ne trebaju maksimalne performanse na svim jezgrama.
Stranica 4 od 5
