takeMS mem.line rubber 500GB – crno-bijela elegancija
· · Mediji · Stranica 3 od 3
Zaključak – Conclusion
takeMS mem.line rubber smo aktivno koristili nekoliko tjedana
i moramo priznati kako smo vrlo zadovoljni njegovom kvalitetom i performansama.
Elegantna kombinacija crno-bijele boje uz nenametljiv i jednostavan dizajn čini
ga ugodnim oku, a gumirane površine aluminijskih poklopaca i sigurnim za prenošenje.
Performanse su vrlo solidne, u svakodnevnom radu cijenimo tišinu rada i tečan
transfer podataka. Model koji smo mi imali na testu kapacitetom će zadovoljiti
i najzahtjevnije korisnike. Ukoliko vam novac predstavlja problem, rubber će
te naći u kapacitetima od 160GB nadalje, pa svatko može pronaći nešto za svoj
džep i potrebe. Ne možemo reći kako se ovaj model nečime posebno ističe od konkurencije,
pa će svakako krajnja odluka ovisiti o cijeni i afinitetima kupca. U Hrvatskoj
ga još nema za kupiti a u Europi košta oko 80 € što je solidna cijena za kapacitet
koji nudi.
Conclusion
After a couple of weeks of hard and excessive use of this takeMS
product we were quite satisfied with its build quality and performance. Elegant
black and white color combination and its clean design makes mem.line rubber
pleasant to the eye, whilst rubberized surface makes it safe to carry around.
Performance is very good, and we liked its quiet operation. 500GB model which
we had on review is spacious enough for most users. If that is too much for
you, and you are aiming for something cheaper it is good to know that it comes
in 3 other versions – 160GB, 250GB and 320GB. This product does not stand out
with anything special from its rivals, so final decision will be based on its
pricing and buyers affinity. In Europe, 500GB model is priced around 80 € for
which is very competitive.
Stranica 3 od 3
