Acer Aspire E5 752G – napokon Carrizo
· · Mobilno · Stranica 4 od 5
Rezultati testova – drugi dio
Grafički rezultati 3DMark
3DMark Fire StrikeHP Elitebook 2570p – R9 270X eGPU: 5.772HP Elitebook 2570p – R9 27…5.772Dell Precision M6800 – M6100: 3.332Dell Precision M6800 – M61…3.332Asus X550JK – GTX 850M: 2.944Asus X550JK – GTX 850M2.944Acer Aspire E5-752G – M365DX: 2.077Acer Aspire E5-752G – M365…2.077Dell Inspiron 7737 – GTX 750M: 1.817Dell Inspiron 7737 – GTX 7…1.817Dell Inspiron 3543 – GT 840M: 1.612Dell Inspiron 3543 – GT 84…1.612Acer Aspire E5-752G – M360: 1.312Acer Aspire E5-752G – M3601.312Dell Inspiron 3542 – GT 820M: 843Dell Inspiron 3542 – GT 82…843Acer Aspire V13 – HD5500: 822Acer Aspire V13 – HD5500822Acer Travelmate P645-S – HD 5500: 787Acer Travelmate P645-S – H…787Acer Aspire R13 – HD5500: 756Acer Aspire R13 – HD5500756Dell Latitude E3450 – HD5500: 712Dell Latitude E3450 – HD55…712Dell Latitude E5250 – HD4400: 584Dell Latitude E5250 – HD44…584Dell Inspiron 5749 – HD5500: 530Dell Inspiron 5749 – HD5500530Dell Inspiron 3148 – HD 4400: 493Dell Inspiron 3148 – HD 44…49306.349
Hibridni Crossfire osjetno podiže rezultate, dok se R7 M360 (nakon što smo u upravljačkim programima ugasili hibridni Crossfire) smjestila između GT 840M i GT 820M. Tomb Raider
Tomb Raider – High presetAsus X550JK – GTX 850M @ HD High: 55,4Asus X550JK – GTX 850M @ H…55,4Acer Aspire E5-752G @ HD High: 46,54Acer Aspire E5-752G @ HD H…46,54Dell Inspiron 3543 – GT 840M @ HD High: 32,4Dell Inspiron 3543 – GT 84…32,4Acer Aspire E5-752G @ HD High: 31,5Acer Aspire E5-752G @ HD H…31,5Acer Aspire V13 – HD5500 @ HD High: 29,9Acer Aspire V13 – HD5500 @…29,9Acer Aspire R13 – HD5500 @ HD High: 29,7Acer Aspire R13 – HD5500 @…29,7Dell Inspiron 3148 – HD 4400 @ HD Low: 28,7Dell Inspiron 3148 – HD 44…28,7Dell Latitude E5250 – HD4400 @ HD High: 25,9Dell Latitude E5250 – HD44…25,9Dell Inspiron 3148 – HD4400 @ HD High: 11,4Dell Inspiron 3148 – HD440…11,4061
Rezultati 3D Marka jasno se iscrtavaju i u Tomb Raideru, osim što smo ovdje imali prilike vidjeti kako micro stutering izgleda u praksi. Naime s upaljenim hibridnom crossfireom, rezultati nisu izostali, ali stuttering je bio neizbježan. Isti se nije pretjerano pojavljivao i kvario dojam igre, ali sasvim dovoljno da ga primijetimo. Autonomija
Trajanje baterije – 1080p h264Dell Latitude E3450 – 58Wh: 520Dell Latitude E3450 – 58Wh520Acer Travelmate P645-S – 55Wh: 492Acer Travelmate P645-S – 5…492Acer Aspire R13 – 48Wh: 396Acer Aspire R13 – 48Wh396Dell Inspiron 3543 – 40Wh: 349Dell Inspiron 3543 – 40Wh349Acer Aspire V13 – 48Wh: 346Acer Aspire V13 – 48Wh346Dell Inspiron 3148 – 43Wh: 336Dell Inspiron 3148 – 43Wh336Dell Precision M6800 – 97Wh: 323Dell Precision M6800 – 97Wh323Dell Latitude E5250 – 38Wh: 315Dell Latitude E5250 – 38Wh315Dell Inspiron 5749 – 40Wh: 307Dell Inspiron 5749 – 40Wh307Acer Aspire E5-752G -37Wh: 225Acer Aspire E5-752G -37Wh225Asus G751JY – 90Wh: 201Asus G751JY – 90Wh201Asus X550JK: 188Asus X550JK1880572
YouTube 720pDell Latitude E3450: 610Dell Latitude E3450610Acer Travelmate P645-S – 55Wh: 580Acer Travelmate P645-S – 5…580Acer Aspire R13: 417Acer Aspire R13417Dell Inspiron 3543: 382Dell Inspiron 3543382Acer Aspire V13: 369Acer Aspire V13369Dell Precision M6800: 370Dell Precision M6800370Dell Inspiron 3148: 330Dell Inspiron 3148330Dell Inspiron 5749: 315Dell Inspiron 5749315Acer Aspire E5-752G: 271Acer Aspire E5-752G271Dell Latitude E5250: 239Dell Latitude E5250239Asus X550JK: 186Asus X550JK1860671
U našim testovima dobili smo iskoristivih malo preko 3h, što je u skladu s praksom i ugrađenom baterijom. AMD je na ovom polju napravio velik pomak s Carrizo arhitekturom, ali 17″ ekran i dedicirana grafička te baterija relativno malog kapaciteta od svega 37Wh utječu na maksimalnu iskoristivost. Kada bismo smanjili osvjetljenje ekrana na nekih 25% i ugasili WiFi karticu bez problema se može doći do 4 sata laganog uredskog rada. WiFi rezultati
WiFi mjerenja vršimo na tri lokacije. Lokacija A predstavlja prijenosnik na udaljenosti od 3 metra od routera bez ikakvih prepreka. Lokacija B predstavlja lokaciju udaljenu oko 4 m gdje prepreke predstavljaju dva zida debljine 45 cm. Lokacija C predstavlja worst case scenario, udaljenost je oko 5 metara, no između routera i zida nalazi se poveće ogledalo i oko 2 metra od ukupne udaljenosti puni zidovi, od kojih jedan sadrži armaturu. Ogledalo smo namjerno spomenuli s obzirom da ono reflektira većinu bežičnog signala koji se probio kroz zidove, a prijenosnici odašilju prema routeru s Lokacije C – micanjem ogledala niti jedan prijenosnik ne bi imao problema na Lokaciji C, ali onda naše testiranje ne bi predstavljalo worst case scenario. Router koji koristimo je Belkin N750 DB. Radi se o dual band routeru, a za potrebe mjerenja koristimo 2.4GHz mrežu koja pokriva 802.11 b/g/n standarde pri čemu koristimo širinu kanala od 20MHz. WiFi – Snaga signala
Snaga signala – Lokacija A (-dB)Asus G751JY – Intel AC 7260: 29Asus G751JY – Intel AC 726029Dell Precision M6800 – Intel N 6300: 29Dell Precision M6800 – Int…29Dell Inspiron 3148 – Broadcom BCM 43142: 33Dell Inspiron 3148 – Broad…33Acer Aspire V13 – Atheros AR5BWB222: 34Acer Aspire V13 – Atheros…34Acer Travelmate P645 – Intel 17226: 40Acer Travelmate P645 – Int…40Acer Aspire E5-772G – RTL8168/8111: 45Acer Aspire E5-772G – RTL8…45Acer Aspire Switch 12 – Atheros AR5BWB222: 47Acer Aspire Switch 12 – At…47052
Snaga signala – Lokacija B (-dB)Asus G751JY – Intel AC 7260: 44Asus G751JY – Intel AC 726044Dell Precision M6800 – Intel N 6300: 47Dell Precision M6800 – Int…47Acer Travelmate P645 – Intel 17226: 47Acer Travelmate P645 – Int…47Dell Inspiron 3148 – Broadcom BCM 43142: 50Dell Inspiron 3148 – Broad…50Acer Aspire E5-772G – RTL8168/8111: 51Acer Aspire E5-772G – RTL8…51Acer Aspire V13 – Atheros AR5BWB222: 55Acer Aspire V13 – Atheros…55Acer Aspire Switch 12 – Atheros AR5BWB222: 62Acer Aspire Switch 12 – At…62068
Snaga signala – Lokacija C (-dB)Acer Travelmate P645 – Intel 17226: 50Acer Travelmate P645 – Int…50Dell Precision M6800 – Intel N 6300: 54Dell Precision M6800 – Int…54Acer Aspire V13 – Atheros AR5BWB222: 60Acer Aspire V13 – Atheros…60Asus G751JY – Intel AC 7260: 62Asus G751JY – Intel AC 726062Acer Aspire E5-772G – RTL8168/8111: 64Acer Aspire E5-772G – RTL8…64Dell Inspiron 3148 – Broadcom BCM 43142: 69Dell Inspiron 3148 – Broad…69Acer Aspire Switch 12 – Atheros AR5BWB222: 71Acer Aspire Switch 12 – At…71078
Iako se radi o 17″ prijenosniku u kojem biste očekivali bolje rezultate E5-772G se smijestio u donju polovicu ljestvice. WiFi – brzina kopiranja:
Transfer Rate – Lokacija A (MB/s)Asus G751JY – Intel AC 7260: 5,5Asus G751JY – Intel AC 72605,5Dell Precision M6800 – Intel N 6300: 5,2Dell Precision M6800 – Int…5,2Acer Aspire V13 – Atheros AR5BWB222: 5,1Acer Aspire V13 – Atheros…5,1Acer Travelmate P645 – Intel 17226: 4,95Acer Travelmate P645 – Int…4,95Acer Aspire E5-772G – RTL8168/8111: 3,36Acer Aspire E5-772G – RTL8…3,36Dell Inspiron 3148 – Broadcom BCM 43142: 2,87Dell Inspiron 3148 – Broad…2,87Acer Aspire Switch 12 – Atheros AR5BWB222: 1,96Acer Aspire Switch 12 – At…1,9606
Transfer Rate – Lokacija B (MB/s)Asus G751JY – Intel AC 7260: 4,8Asus G751JY – Intel AC 72604,8Dell Precision M6800 – Intel N 6300: 4,5Dell Precision M6800 – Int…4,5Acer Aspire V13 – Atheros AR5BWB222: 3,6Acer Aspire V13 – Atheros…3,6Dell Inspiron 3148 – Broadcom BCM 43142: 3,3Dell Inspiron 3148 – Broad…3,3Acer Aspire E5-772G – RTL8168/8111: 2,7Acer Aspire E5-772G – RTL8…2,7Acer Aspire Switch 12 – Atheros AR5BWB222: 2,2Acer Aspire Switch 12 – At…2,2: 0,2440,24405
Transfer Rate – Lokacija C (MB/s)Dell Precision M6800 – Intel N 6300: 0,64Dell Precision M6800 – Int…0,64Acer Travelmate P645 – Intel 17226: 0,6Acer Travelmate P645 – Int…0,6Acer Aspire V13 – Atheros AR5BWB222: 0,35Acer Aspire V13 – Atheros…0,35Asus G751JY – Intel AC 7260: 0,3Asus G751JY – Intel AC 72600,3Acer Aspire E5-772G – RTL8168/8111: 0,2Acer Aspire E5-772G – RTL8…0,2Dell Inspiron 3148 – Broadcom BCM 43142: 0,0Dell Inspiron 3148 – Broad…0,0Acer Aspire Switch 12 – Atheros AR5BWB222: 0,0Acer Aspire Switch 12 – At…0,001
Tek prolazna ocjena u testu brzine kopiranja. Zanimljivo je da pucanje veze na lokaciji C nismo imali tokom samog trajanja testa kopiranja, ali do gubitaka je dolazilo. Isto tako ponovno spajanje nije prolazilo bezbolno, ali konekcija bi se uspješno uspostavila unutar 20ak sekundi.
Stranica 4 od 5
