Acer Aspire Switch 12 – Is it a laptop? Is it a tablet? No it’s Switch 12!
· · Mobilno · Stranica 4 od 5
Rezultati testova – drugi dio
Grafički rezultati 3DMark
3DMark Fire StrikeHP Elitebook 2570p – R9 270X eGPU: 5.772HP Elitebook 2570p – R9 27…5.772Dell Precision M6800 – M6100: 3.332Dell Precision M6800 – M61…3.332Asus X550JK – GTX 850M: 2.944Asus X550JK – GTX 850M2.944Dell Inspiron 7737 – GTX 750M: 1.817Dell Inspiron 7737 – GTX 7…1.817Dell Inspiron 3543 – GT 840M: 1.612Dell Inspiron 3543 – GT 84…1.612Dell Inspiron 3542 – GT 820M: 843Dell Inspiron 3542 – GT 82…843Acer Aspire V13 – HD5500: 822Acer Aspire V13 – HD5500822Acer Travelmate P645-S – HD 5500: 787Acer Travelmate P645-S – H…787Acer Aspire R13 – HD5500: 756Acer Aspire R13 – HD5500756Dell Latitude E3450 – HD5500: 712Dell Latitude E3450 – HD55…712Dell Latitude E5250 – HD4400: 584Dell Latitude E5250 – HD44…584Dell Inspiron 5749 – HD5500: 530Dell Inspiron 5749 – HD5500530Dell Inspiron 3148 – HD 4400: 493Dell Inspiron 3148 – HD 44…493Acer Aspire Switch 12 – HD 5300: 366Acer Aspire Switch 12 – HD…36606.349
Najslabija grafička kartica na testu (odnosno najograničenija TDPom) vodi do najnižeg rezultata. Autonomija
Trajanje baterije – 1080p h264Dell Latitude E3450 – 58Wh: 520Dell Latitude E3450 – 58Wh520Acer Travelmate P645-S – 55Wh: 492Acer Travelmate P645-S – 5…492Acer Aspire R13 – 48Wh: 396Acer Aspire R13 – 48Wh396Acer Aspire Switch 12 – 37WH: 393Acer Aspire Switch 12 – 37…393Dell Inspiron 3543 – 40Wh: 349Dell Inspiron 3543 – 40Wh349Acer Aspire V13 – 48Wh: 346Acer Aspire V13 – 48Wh346Dell Inspiron 3148 – 43Wh: 336Dell Inspiron 3148 – 43Wh336Dell Precision M6800 – 97Wh: 323Dell Precision M6800 – 97Wh323Dell Latitude E5250 – 38Wh: 315Dell Latitude E5250 – 38Wh315Dell Inspiron 5749 – 40Wh: 307Dell Inspiron 5749 – 40Wh307Asus G751JY – 90Wh: 201Asus G751JY – 90Wh201Asus X550JK: 188Asus X550JK1880572
YouTube 720pDell Latitude E3450: 610Dell Latitude E3450610Acer Travelmate P645-S: 580Acer Travelmate P645-S580Acer Aspire Switch 12: 423Acer Aspire Switch 12423Acer Aspire R13: 417Acer Aspire R13417Dell Inspiron 3543: 382Dell Inspiron 3543382Acer Aspire V13: 369Acer Aspire V13369Dell Precision M6800: 370Dell Precision M6800370Dell Inspiron 3148: 330Dell Inspiron 3148330Dell Inspiron 5749: 315Dell Inspiron 5749315Dell Latitude E5250: 271Dell Latitude E5250271Asus X550JK: 186Asus X550JK186: 1761760671
S obzirom na malu potrošnju Core M-5Y10, ugrađen SSD i ekran malene dijagonale, autonomija je potpuno očekivana te pruža oko šest sati laganog rada i surfanja. WiFi rezultati
WiFi mjerenja vršimo na tri lokacije. Lokacija A predstavlja prijenosnik na udaljenosti od 3 metra od routera bez ikakvih prepreka. Lokacija B predstavlja lokaciju udaljenu oko 4 m gdje prepreke predstavljaju dva zida debljine 45 cm. Lokacija C predstavlja worst case scenario, udaljenost je oko 5 metara, no između routera i zida nalazi se poveće ogledalo i oko 2 metra od ukupne udaljenosti puni zidovi, od kojih jedan sadrži armaturu. Ogledalo smo namjerno spomenuli s obzirom da ono reflektira većinu bežičnog signala koji se probio kroz zidove, a prijenosnici odašilju prema routeru s Lokacije C – micanjem ogledala niti jedan prijenosnik ne bi imao problema na Lokaciji C, ali onda naše testiranje ne bi predstavljalo worst case scenario. Router koji koristimo je Belkin N750 DB. Radi se o dual band routeru, a za potrebe mjerenja koristimo 2.4GHz mrežu koja pokriva 802.11 b/g/n standarde pri čemu koristimo širinu kanala od 20MHz. WiFi – Snaga signala
Snaga signala – Lokacija A (-dB)Asus G751JY – Intel AC 7260: 29Asus G751JY – Intel AC 726029Dell Precision M6800 – Intel N 6300: 29Dell Precision M6800 – Int…29Dell Inspiron 3148 – Broadcom BCM 43142: 33Dell Inspiron 3148 – Broad…33Acer Aspire V13 – Atheros AR5BWB222: 34Acer Aspire V13 – Atheros…34Acer Travelmate P645 – Intel 17226: 45Acer Travelmate P645 – Int…45Acer Aspire Switch 12 – Atheros AR5BWB222: 47Acer Aspire Switch 12 – At…47052
Snaga signala – Lokacija B (-dB)Asus G751JY – Intel AC 7260: 44Asus G751JY – Intel AC 726044Dell Precision M6800 – Intel N 6300: 47Dell Precision M6800 – Int…47Acer Travelmate P645 – Intel 17226: 47Acer Travelmate P645 – Int…47Dell Inspiron 3148 – Broadcom BCM 43142: 50Dell Inspiron 3148 – Broad…50Acer Aspire V13 – Atheros AR5BWB222: 55Acer Aspire V13 – Atheros…55Acer Aspire Switch 12 – Atheros AR5BWB222: 62Acer Aspire Switch 12 – At…62068
Snaga signala – Lokacija C (-dB)Acer Travelmate P645 – Intel 17226: 50Acer Travelmate P645 – Int…50Dell Precision M6800 – Intel N 6300: 54Dell Precision M6800 – Int…54Acer Aspire V13 – Atheros AR5BWB222: 60Acer Aspire V13 – Atheros…60Asus G751JY – Intel AC 7260: 62Asus G751JY – Intel AC 726062Dell Inspiron 3148 – Broadcom BCM 43142: 69Dell Inspiron 3148 – Broad…69Acer Aspire Switch 12 – Atheros AR5BWB222: 71Acer Aspire Switch 12 – At…71078
Vrlo malen uređaj s malim antenama naravno nudi relativno slab prijem WiFi signala. Rezultati su u skladu s tabletima i pametnim telefonima, ali s obzirom da se radi o 2u1 prijenosniku vrlo rado bismo vidjeli nešto više vrijednosti. WiFi – brzina kopiranja:
Transfer Rate – Lokacija A (MB/s)Asus G751JY – Intel AC 7260: 5,5Asus G751JY – Intel AC 72605,5Dell Precision M6800 – Intel N 6300: 5,2Dell Precision M6800 – Int…5,2Acer Aspire V13 – Atheros AR5BWB222: 5,1Acer Aspire V13 – Atheros…5,1Acer Travelmate P645 – Intel 17226: 4,95Acer Travelmate P645 – Int…4,95Dell Inspiron 3148 – Broadcom BCM 43142: 2,87Dell Inspiron 3148 – Broad…2,87Acer Aspire Switch 12 – Atheros AR5BWB222: 1,96Acer Aspire Switch 12 – At…1,9606
Transfer Rate – Lokacija B (MB/s)Asus G751JY – Intel AC 7260: 4,8Asus G751JY – Intel AC 72604,8Dell Precision M6800 – Intel N 6300: 4,5Dell Precision M6800 – Int…4,5Acer Aspire V13 – Atheros AR5BWB222: 3,6Acer Aspire V13 – Atheros…3,6Dell Inspiron 3148 – Broadcom BCM 43142: 3,3Dell Inspiron 3148 – Broad…3,3Acer Aspire Switch 12 – Atheros AR5BWB222: 2,7Acer Aspire Switch 12 – At…2,7: 0,2440,24405
Transfer Rate – Lokacija C (MB/s)Dell Precision M6800 – Intel N 6300: 0,64Dell Precision M6800 – Int…0,64Acer Travelmate P645 – Intel 17226: 0Acer Travelmate P645 – Int…0Acer Aspire V13 – Atheros AR5BWB222: 6Acer Aspire V13 – Atheros…6Asus G751JY – Intel AC 7260: 0,35Asus G751JY – Intel AC 72600,35Dell Inspiron 3148 – Broadcom BCM 43142: 0,3Dell Inspiron 3148 – Broad…0,3Acer Aspire Switch 12 – Atheros AR5BWB222: 0Acer Aspire Switch 12 – At…0: 0007
S obzirom na dosad viđene rezultate, nemogućnost uspostavljanja veze na lokaciji C nije uopće iznenađujuća, ali je razočaravajuća. Da malo ponovimo – lokacija C je problematična za većinu (gotovo sve) pametnih telefona i tableta, a oni koji i uspijevaju uhvatiti signal bateriju troše drastično brže, a ujedno se i dosta više griju.
Stranica 4 od 5
