AMD A10-7860K & MSI A68HI test
· · Procesori · Stranica 4 od 5
Rezultati testova
3DMark – FireStrikei7-5775C: 1.806i7-5775C1.806A10-7870K: 1.621A10-7870K1.621Radeon HD7730 1GB: 1.602Radeon HD7730 1GB1.602A10-7850K: 1.509A10-7850K1.509A10-7800: 1.428A10-78001.428A10-7860K: 1.423A10-7860K1.423A8-7670K: 1.410A8-7670K1.410A8-7600: 1.340A8-76001.340i7-4770K: 892i7-4770K89201.987
Novi je APU tek mrvicu brži od A8-7670K modela i malo sporiji od A10-7800, no tek ćemo u igrama saznati realne grafičke performanse.
7-ZIPA10-7870K: 12.257A10-7870K12.257Athlon X4 860K: 12.080Athlon X4 860K12.080A10-7850K: 11.711A10-7850K11.711A10-7860K: 11.448A10-7860K11.448A8-7670K: 11.427A8-7670K11.427A8-7650K: 10.921A8-7650K10.921Pentium G3258: 7.400Pentium G32587.400013.483
7-zip performanse su vrlo slične A8-7670K APU-u.
Cinebench 15A10-7870K: 321A10-7870K321Athlon X4 860K: 313Athlon X4 860K313A8-7670K: 309A8-7670K309A10-7860K: 303A10-7860K303A8-7650K: 290A8-7650K290Pentium G3258: 248Pentium G32582480353
Ponovno i očekivano slične performanse kao i kod A8-7670K.
TrueCrypt v7.1A10-7870K: 2,3A10-7870K2,3A10-7850K: 2,1A10-7850K2,1A10-7860K: 2,1A10-7860K2,1Athlon X4 860K: 2,1Athlon X4 860K2,1A8-7650K: 2,0A8-7650K2,0A8-7670K: 1,9A8-7670K1,9Pentium G3258: 0,299Pentium G32580,29903
Ovdje je ipak novi APU malo pobjegao 7670K i u društvu je s X4 860K Athlonom i A10-7850K.
Luxmark 2.0 RoomA10-7860K @ GPU + CPU: 346A10-7860K @ GPU + CPU346A10-7860K @ GPU: 332A10-7860K @ GPU332A8-7670K @ GPU + CPU: 328A8-7670K @ GPU + CPU328A10-7870K @ CPU + GPU: 272A10-7870K @ CPU + GPU272A8-7670K @ GPU: 261A8-7670K @ GPU261A8-7650K @ CPU + GPU: 259A8-7650K @ CPU + GPU259i5-4690K: 248i5-4690K248FX-8370e: 235FX-8370e235FX-8320e: 230FX-8320e230A8-7670K @ CPU: 136A8-7670K @ CPU136A10-7860K @ CPU: 133A10-7860K @ CPU133A10-7870K @ CPU: 105A10-7870K @ CPU105Athlon X4 860K: 102Athlon X4 860K102A8-7650K @ CPU: 99A8-7650K @ CPU990381
OpenCL performanse su nešto porasle kada kombiniramo GPU i CPU, te samo GPU i to zahvaljujući upravljačkim programima. Same CPU performanse su ostale na sličnoj razini kao i kod ranije testiranog 7670K.
wPrime 2.0 1024MA10-7870K: 415,356A10-7870K415,356Athlon X4 860K: 419,982Athlon X4 860K419,982A10-7860K: 428,062A10-7860K428,062A8-7670K: 434,045A8-7670K434,045A8-7650K: 452,399A8-7650K452,3990498
7860K je tek malo brži od 7670K i sporiji od X4 860K.
PotrošnjaPentium G3258: 65Pentium G325865i5-4690K: 95i5-4690K95A8-7650K: 99A8-7650K99A10-7860K: 108A10-7860K108A8-7670K: 118A8-7670K118Athlon X4 860K: 120Athlon X4 860K120A10-7850K: 125A10-7850K1250138
Potrošnja se kreće između 7670K i X4 860K što je i očekivano bez obzira na deklarirani 65 W TDP. Zagrijavanje pri maksimalnoj potrošnji nije pretjerano i kreće se oko 55°C.
Sniper Elite 3 (1680×1050 @ Low Details)A8-7650K @ DualGraphics: 53,3A8-7650K @ DualGraphics53,3A10-7860K: 43,5A10-7860K43,5i7-5775C: 42i7-5775C42A10-7870K: 38,2A10-7870K38,2A8-7670K: 33,3A8-7670K33,3R7 250: 31,1R7 25031,1A8-7650K: 30,8A8-7650K30,8059
Za lijep porast performansi su zaslužni novi upravljački programi.
Thief (1680×1050 @ Low)A8-7650K @ DualGraphics: 27,5A8-7650K @ DualGraphics27,5i7-5775C: 26,2i7-5775C26,2A10-7870K: 23,5A10-7870K23,5R7 250: 22,1R7 25022,1A8-7670K: 21,7A8-7670K21,7A10-7860K: 21,1A10-7860K21,1A8-7650K: 20,2A8-7650K20,2030
Ovdje nema porasta performansi, a riječ je i o zahtjevnijem naslovu od prethodnog. No opet, očekivali bi malo više performanse u odnosu na 7670K.
Ostatak se grafičkih testova može pogledati na videu kojeg smo snimili, a zaključak je kao i uvijek da su A10 i A8 APU-i vrlo sposobni za pokretanje manje zahtjevnih igara i to se posebno odnosi na eSports naslove. Kao što u videu vidimo, čak se dobro nosi i sa zahtjevnijim naslovima ali u Low detaljima.
Rezultati testova
Stranica 4 od 5
