AMD Ryzen 7 1700X recenzija
· · Procesori · Stranica 3 od 6
Rezultati testiranja – prvi dio
PCMark 8i7-7700K: 4.864i7-7700K4.864i7-6700K: 4.727i7-6700K4.727Ryzen 7 1800X @ 4.0 GHz: 4.647Ryzen 7 1800X @ 4.0 GHz4.647Ryzen 7 1700X @ 3.9 GHz: 4.484Ryzen 7 1700X @ 3.9 GHz4.484Ryzen 7 1800X: 4.370Ryzen 7 1800X4.370Ryzen 7 1700X: 4.240Ryzen 7 1700X4.24005.350
3DMark TimespyRyzen 7 1800X @ 4.0: 7.601Ryzen 7 1800X @ 4.07.601Ryzen 7 1700X @ 3.9: 7.587Ryzen 7 1700X @ 3.97.587Ryzen 7 1700X: 7.506Ryzen 7 1700X7.506Ryzen 7 1800X: 7.493Ryzen 7 1800X7.49308.361
3DMark FirestrikeRyzen 7 1700X @ 3.9: 17.733Ryzen 7 1700X @ 3.917.733Ryzen 7 1800X @ 4.0: 17.308Ryzen 7 1800X @ 4.017.308Ryzen 7 1700X: 16.948Ryzen 7 1700X16.948Ryzen 7 1800X: 16.820Ryzen 7 1800X16.820019.506
U PCMarku primjećujemo kako niža radna frekvencija odnosi bodove u konačnici i kada su u pitanju referentni taktovi i overclockirani. U 3DMarku stvari postaju zanimljive, u TimeSpyu je 1700X nešto brži od 1800X na tvorničkim taktovima, no kada overclockiramo stvari se vraćaju u normalu. u FireStrikeu pak imamo situaciju da je overclockirani 1700X nešto brži od overclockiranog 1800X – kod svih testova cijelom dužinom trajanja testa procesori drže punu frekvenciju na svim jezgrama.
7-ZIPi7-6950X: 50.375i7-6950X50.375Ryzen 7 1800X: 41.197Ryzen 7 1800X41.197i7-5960X: 40.065i7-5960X40.065Ryzen 7 1700X: 39.010Ryzen 7 1700X39.010i7-4960X: 35.921i7-4960X35.921i7-3960X: 34.371i7-3960X34.371i7-5930K: 32.228i7-5930K32.228i7-5820K: 31.261i7-5820K31.261i7-980X: 29.058i7-980X29.058i7-3930K: 28.938i7-3930K28.938i7-7700K: 28.583i7-7700K28.583i7-6700K: 26.328i7-6700K26.328i7-4790K: 26.327i7-4790K26.327i7-3770K: 24.437i7-3770K24.437i7-4770K: 23.564i7-4770K23.564FX-8150: 20.957FX-815020.957i7-2600K: 20.101i7-2600K20.101i5-4690K: 18.528i5-4690K18.528i5-6600K: 18.155i5-6600K18.155i5-4670K: 17.203i5-4670K17.203i5-2500K: 14.254i5-2500K14.254055.413
Seriju CPU testova otvaramo 7-Zipom gdje je 1700X očekivano sporiji od 1800X, te se smjestio tik ispod moćnog 5960X-a.
Cinebench 15i7-6950X: 1.864i7-6950X1.864Ryzen 7 1800X: 1.624Ryzen 7 1800X1.624Ryzen 7 1700X: 1.542Ryzen 7 1700X1.542i7-5960X: 1.377i7-5960X1.377i7-5930K: 1.101i7-5930K1.101i7-5820K: 1.074i7-5820K1.074i7-7700K: 989i7-7700K989i7-6700K: 935i7-6700K935i5-6600K: 651i5-6600K65102.050
Razlika od 200 MHz u osnovnom taktu znači razliku od 80 bodova u Cinebenchu, a zanimljivo je kako i 1700X ovdje “tuče” 5960X.
HandbrakeRyzen 7 1800X: 25,6Ryzen 7 1800X25,6Ryzen 7 1700X: 24,6Ryzen 7 1700X24,6i7-5820K: 17,2i7-5820K17,2i7-7700K: 17,1i7-7700K17,1i7-6700K: 15,9i7-6700K15,9028
Handbrake također pokazuje nešto niži rezultat što je sasvim očekivano.
TrueCrypt v7.1i7-6950X: 10,5i7-6950X10,5Ryzen 7 1800X: 10,0Ryzen 7 1800X10,0Ryzen 7 1700X: 9,4Ryzen 7 1700X9,4i7-5960X: 8,4i7-5960X8,4i7-5930K: 6,6i7-5930K6,6i7-5820K: 6,3i7-5820K6,3i7-4960X: 6i7-4960X6i7-7700K: 5,6i7-7700K5,6i7-3960X: 5,5i7-3960X5,5i7-6700K: 5,2i7-6700K5,2i7-4790K: 5,2i7-4790K5,2i7-4770K: 4,5i7-4770K4,5i5-6600K: 3,4i5-6600K3,4i5-4670K: 3,3i5-4670K3,3FX-8150: 3,3FX-81503,3i5-4690K: 3,3i5-4690K3,3i7-3770K: 3,2i7-3770K3,2i5-2500K: 2,8i5-2500K2,8012
I TrueCrypt rezultat je impresivan i iznad je 5960X procesora.
wPrime 2.0i7-6950X: 86,854i7-6950X86,854Ryzen 7 1800X: 103,919Ryzen 7 1800X103,919Ryzen 7 1700X: 108,265Ryzen 7 1700X108,265i7-5960X: 116,929i7-5960X116,929i7-4960X: 129,637i7-4960X129,637i7-3960X: 135,127i7-3960X135,127i7-5930K: 136,293i7-5930K136,293i7-5820K: 140,245i7-5820K140,245i7-3930K: 164,566i7-3930K164,566i7-7700K: 167,364i7-7700K167,364i7-6700K: 178,347i7-6700K178,347i7-4790K: 186,468i7-4790K186,468i7-4770K: 195,174i7-4770K195,174i7-3770K: 198,092i7-3770K198,092i7-2600K: 225i7-2600K225FX-8150: 275,996FX-8150275,996i5-6600K: 277,733i5-6600K277,733i5-4670K: 285,449i5-4670K285,449i5-2500K: 321,608i5-2500K321,6080354
I ovdje je 1700X brži od 5960X procesora  – odličan rezultat za AMD.
x.264 Benchmark v5.0i7-6950X: 128,21i7-6950X128,21Ryzen 7 1800X: 104,4Ryzen 7 1800X104,4Ryzen 7 1700X: 99,67Ryzen 7 1700X99,67i7-5930K: 92,30i7-5930K92,30i7-5960X: 91,94i7-5960X91,94i7-5820K: 89,84i7-5820K89,84i7-6700K: 78,18i7-6700K78,18i7-4770R: 72,21i7-4770R72,21i5-4670K: 62,63i5-4670K62,63i5-6600K: 53,37i5-6600K53,370141
Ponovno sasvim očekivani pad performansi, tj. ne prevelik zaostatak iza 1800X i ponovno ispred cijele plejade Broadwell-E procesora.
Stranica 3 od 6
