AMD Ryzen 9 3950X recenzija
· · Procesori · Stranica 5 od 6
Rezultati testiranja – treći dio
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadR9 3900X: 55.094R9 3900X55.094R9 3950X: 54.484R9 3950X54.484R7 3700X: 51.226R7 3700X51.226060.603
AIDA64 RAM WriteR9 3950X: 53.165R9 3950X53.165R9 3900X: 51.942R9 3900X51.942R7 3700X: 28.745R7 3700X28.745058.482
AIDA64 RAM CopyR9 3950X: 55.876R9 3950X55.876R9 3900X: 52.688R9 3900X52.688R7 3700X: 49.050R7 3700X49.050061.464
AIDA64 RAM LatencyR9 3950X: 67,6R9 3950X67,6R7 3700X: 68,6R7 3700X68,6R9 3900X: 69,9R9 3900X69,9077
Ryzen 9 3950X pokazuje izvrsne memorijske performanse i gotovo u svim je testovima na vrhu.
Potrošnja sistema
Potrošnjai5-7500: 92i5-750092Ryzen 3 1200: 105Ryzen 3 1200105Ryzen 5 1400: 113Ryzen 5 1400113i7-6700K: 120i7-6700K120Ryzen 3 1300X: 125Ryzen 3 1300X125Ryzen 5 1500X: 130Ryzen 5 1500X130Ryzen 5 1600: 132Ryzen 5 1600132Ryzen 7 1700: 137Ryzen 7 1700137i7-7700K: 138i7-7700K138Ryzen 7 2700: 141Ryzen 7 2700141Ryzen 5 2600: 155Ryzen 5 2600155Ryzen 7 3700X: 160Ryzen 7 3700X160Ryzen 7 1700X: 162Ryzen 7 1700X162Ryzen 5 1600X: 163Ryzen 5 1600X163i5-8600K: 165i5-8600K165Ryzen 5 2600X: 170Ryzen 5 2600X170Ryzen 7 1800X: 173Ryzen 7 1800X173Ryzen 9 3900X: 195Ryzen 9 3900X195i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200Ryzen 7 2700X: 201Ryzen 7 2700X201i7-5820K: 205i7-5820K205i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225Ryzen 9 3950X: 230Ryzen 9 3950X230i7-4960X: 252i7-4960X252i7-5960X: 255i7-5960X255Threadripper 2920X: 265Threadripper 2920X265i7-3960X: 267i7-3960X267Threadripper 2950X: 270Threadripper 2950X270Threadripper 1920X: 280Threadripper 1920X280Threadripper 1950X: 290Threadripper 1950X290Threadripper 2990WX: 326Threadripper 2990WX326Threadripper 2970WX: 330Threadripper 2970WX3300363
Moramo napomenuti da su sve performanse dobivene bez uključenog PBO-a (precision boost overclocking), a to se vidi i po potrošnji sustava od samo 230 W, kao i isčitanom podatku o 118 W snage koju je procesor vukao iz socketa (prema HWInfo64 aplikaciji). Izvrstan rezultat!
Zagrijavanje
TemperatureRyzen 9 3900X @ Aorus 280: 67,8Ryzen 9 3900X @ Aorus 28067,8Ryzen 9 3950X @ Aorus 280: 68,9Ryzen 9 3950X @ Aorus 28068,9Ryzen 9 3900X @ D15: 78,8Ryzen 9 3900X @ D1578,8Ryzen 9 3950X @ D15: 78,8Ryzen 9 3950X @ D1578,8087
Zanimljivo, no 16-jezgreni se procesor ne zagrijava ništa više od 12-jezgrenog što potvrđuje test s dva tipa hladnjaka. Iz ovoga je testa jasno i zašto je AMD preporučio korištenje minimalno 280-milimetarskog AIO vodenog hlađenja za 3950X, koji naravno dobro dođe i za 3900X. Ipak, kod overclockinga se temperatura s D15 penje na 95°C, a s Aorus 280 hladnjakom na pristojnijih 86,6°C.
Stranica 5 od 6
