Rezultati testiranja – treći dio
Memorijske performanse
AIDA64 RAM Read DDR4 @ 3.600 MHz: 52.320 DDR4 @ 3.600 MHz 52.320 0 57.552
AIDA64 RAM Write DDR4 @ 3.600 MHz: 52.157 DDR4 @ 3.600 MHz 52.157 0 57.373
AIDA64 RAM Copy DDR4 @ 3.600 MHz: 49.762 DDR4 @ 3.600 MHz 49.762 0 54.738
AIDA64 RAM Latency DDR4 @ 3.600 MHz: 61,5 DDR4 @ 3.600 MHz 61,5 0 68
Propusnost DDR4 memorije nije visoka kao kod DDR5, no sasvim je respektabilna za ovakav procesor.
Potrošnja sistema
Potrošnja i5-7500: 92 i5-7500 92 Ryzen 3 1200: 105 Ryzen 3 1200 105 Ryzen 5 1400: 113 Ryzen 5 1400 113 i7-6700K: 120 i7-6700K 120 Core i5-10500: 124 Core i5-10500 124 Core i5-10400: 125 Core i5-10400 125 Ryzen 3 1300X: 125 Ryzen 3 1300X 125 Ryzen 5 1500X: 130 Ryzen 5 1500X 130 Ryzen 5 1600: 132 Ryzen 5 1600 132 Core i3-12100F: 137 Core i3-12100F 137 Ryzen 7 1700: 137 Ryzen 7 1700 137 i7-7700K: 138 i7-7700K 138 Ryzen 7 2700: 141 Ryzen 7 2700 141 Ryzen 3 3100: 146 Ryzen 3 3100 146 Ryzen 5 2600: 155 Ryzen 5 2600 155 Ryzen 7 3700X: 160 Ryzen 7 3700X 160 Ryzen 5 3600X: 162 Ryzen 5 3600X 162 Ryzen 7 1700X: 162 Ryzen 7 1700X 162 Ryzen 3 3300X: 163 Ryzen 3 3300X 163 Ryzen 5 1600X: 163 Ryzen 5 1600X 163 i5-8600K: 165 i5-8600K 165 Core i5-10600K: 167 Core i5-10600K 167 Ryzen 5 2600X: 170 Ryzen 5 2600X 170 Ryzen 5 5600X: 172 Ryzen 5 5600X 172 Ryzen 7 1800X: 173 Ryzen 7 1800X 173 Core i7-10700K: 183 Core i7-10700K 183 Ryzen 7 5800X: 183 Ryzen 7 5800X 183 Ryzen 7 3800XT: 193 Ryzen 7 3800XT 193 Ryzen 9 3900X: 195 Ryzen 9 3900X 195 i7-6950X: 196 i7-6950X 196 i7-8700K: 200 i7-8700K 200 Ryzen 7 2700X: 201 Ryzen 7 2700X 201 i7-5820K: 205 i7-5820K 205 Ryzen 9 5900X: 210 Ryzen 9 5900X 210 Ryzen 9 3900XT: 211 Ryzen 9 3900XT 211 i7-5930K: 216 i7-5930K 216 i7-7800X: 225 i7-7800X 225 Ryzen 9 5950X: 225 Ryzen 9 5950X 225 Core i5-12600K: 226 Core i5-12600K 226 Ryzen 9 3950X: 230 Ryzen 9 3950X 230 Core i9-10850K: 275 Core i9-10850K 275 i9-12900K: 325 i9-12900K 325 0 358
Potrošnja sistema nije pretjerana i malo kapacitetniji hladnjak će ga bez problema hladiti. No, ako želite malo niže temperature i nižu buku morate gledati dalje od onoga koji dolazi u kutiji s procesorom.
Zagrijavanje
Temperature (Tdie) Arctic Freezer i35 A-RGB: 62 Arctic Freezer i35 A-RGB 62 Intel Box hladnjak: 79 Intel Box hladnjak 79 0 87
Ogromna je razlika u temperaturi između dva hladnjaka no ipak je Freezer i puno veći hladnjak, pa nas to zapravo ne treba čuditi. Ono što je bitnije je da je tiši. Stoga, ako imate kućište koje može primiti veći hladnjak, obavezno to i iskoristite.
