ASUS EN8800GTS 512MB – nabrijani GT
Zaključak – Conclusion
Zbog boljeg hladnjaka koji dopušta veći OC skloniji bi bili
preporuci GTS 512MB modela, da nije razlike u cijeni. Za ovaj GTS model morati
ćete izdvojiti nešto malo preko 2500kn dok je GT model oko 2000kn. Spomenimo
i da uz GT model dobivate novu Company of Heroes: Opposing Fronts ekspanziju
te da u novijim revizijama kartica dolazi poboljšani hladnjak u još uvijek
one-slot izdanju. S druge strane GTS model je jako brz. Dobitak u performansama
na stock taktovima i nije naročito veli no ipak se osjeti. To se još može
drastično poboljšati overclockingom, pa ako vam 500kn više nije problem i
ne patite previše za bundleom svakako nabavite ovu karticu.
Conclusion
If there weren’t a large price difference we would definitely
recommend you GTS 512MB model. Its price in Croatian stores is a bit under
350 € while GT model costs around 270 €. With GT model u get a cool Company
of Heroes: Opposing Fronts expansion and in new card revisions you get improved
cooler. On the other hand, GTS is fast. Performance gain in stock speeds isn’t
big, but that can be drastically changed with overclocking. If the extra money
isn’t a problem and u don’t care if the bundle is weak u should definitely
get this card.
Stranica 5 od 5
