Dell XPS 18 test
· · Mobilno · Stranica 2 od 3
Rezultati testova
PCMark 8Acer Aspire R7: 2.938Acer Aspire R72.938Dell XPS 12: 2.702Dell XPS 122.702Dell XPS 18: 2.051Dell XPS 182.05103.000
Za početak kao i uvijek cjelokupni test računala uz pomoć PCMarka 8.  XPS je uvjerljivo zadnji premda dijeli kompletnu platformu sa XPS-om 12 osim diskovnog podsustava. Kod 18-ice je on znatno sporiji što se osjeti i pri učitavanju zahtjevnijih aplikacija. U tom bi smislu SSD puno značio, a ovakav premium uređaj premium cijene ga svakako i zaslužuje.
7-Zip (MIPS)Dell XPS 14z: 9.430Dell XPS 14z9.430Acer R7: 8.681Acer R78.681Dell XPS 12: 8.563Dell XPS 128.563Dell Inspiron 5520: 8.254Dell Inspiron 55208.254Dell XPS 18: 8.085Dell XPS 188.085Dell Inspiron 3521/5521: 7.001Dell Inspiron 3521/55217.001Dell Vostro 3360: 6.995Dell Vostro 33606.995Dell Vostro V131: 6.094Dell Vostro V1316.094010.000
Kada je riječ o sirovim CPU preformansama vidimo kako je procesor postigao za otprilike 500 bodova niži rezultat nego isti takav u XPS-u 12.
AIDA64 Memory WriteDell XPS 18: 21.478Dell XPS 1821.478Dell Inspiron 5737: 20.359Dell Inspiron 573720.359Acer Aspire R7: 19.787Acer Aspire R719.787Dell XPS 12: 18.443Dell XPS 1218.443Dell Inspiron 7520: 16.776Dell Inspiron 752016.776Dell Inspiron 3521/5521: 15.511Dell Inspiron 3521/552115.511Acer Aspire S7: 14.687Acer Aspire S714.687Dell Vostro 3360: 11.839Dell Vostro 336011.839022.000
AIDA64 Memory ReadDell Inspiron 5737: 23.717Dell Inspiron 573723.717Dell XPS 18: 23.068Dell XPS 1823.068Acer Aspire R7: 20.880Acer Aspire R720.880Dell XPS 12: 18.817Dell XPS 1218.817Dell Inspiron 7520: 16.099Dell Inspiron 752016.099Dell Inspiron 3521/5521: 14.744Dell Inspiron 3521/552114.744Acer Aspire S7: 14.236Acer Aspire S714.236Dell Vostro 3360: 12.494Dell Vostro 336012.494024.000
AIDA64 Memory CopyDell XPS 18: 21.186Dell XPS 1821.186Dell Inspiron 5737: 20.949Dell Inspiron 573720.949Acer Aspire R7: 19.508Acer Aspire R719.508Dell Inspiron 7520: 18.877Dell Inspiron 752018.877Dell XPS 12: 17.651Dell XPS 1217.651Dell Inspiron 3521/5521: 17.164Dell Inspiron 3521/552117.164Acer Aspire S7: 15.544Acer Aspire S715.544Dell Vostro 3360: 11.667Dell Vostro 336011.667022.000
Memorijske performanse su izvrsne zahvaljujući dual-channel konfiguraciji i brzini od 1600 MHz.
ATTO BenchmarkST500LT012@Read: 105,278ST500LT012@Read105,278ST500LT012@Write: 79,197ST500LT012@Write79,1970110
Za diskovni podsustav ne možemo reći da je spor, pogotovo kad se na pomoćni SSD “poslože” sve aplikacije koje najčešće koristimo, no kao što smo već ranije zaključili – ovakav proizvod mora imati samo SSD.
Trajanje baterije (Minute)Dell XPS 12: 351Dell XPS 12351Dell Inspiron 3521: 315Dell Inspiron 3521315Dell Vostro 3360: 308Dell Vostro 3360308Dell Inspiron 5521: 301Dell Inspiron 5521301Acer Aspire S7: 297Acer Aspire S7297Dell XPS 18: 212Dell XPS 18212Acer Aspire R7: 192Acer Aspire R71920360
Pogledom na kapacitet baterije i dijagonalu ekrana jasno je kako autonomija neće biti sjajna. Mi smo izmjerili malo više od tri i pol sata 1080p reprodukcije, što se normalnim korištenjem može produžiti i za sat vremena.
Rashladni je sistem učinkovit i u normalnom se radu ne XPS zagrijava previše, te niti ne buči. Čujniji je tek postao kada smo ga maksimalno opteretili kada su i temperature porasle iznad 70°C, no to će se ipak rijetko događati u praksi i svakodnevnoj upotrebi.
Rezultati testova
Stranica 2 od 3
