Foxconn P55A-S – solidan prosjek
· · MBO i RAM · Stranica 4 od 5
Rezultati testova – 2.dio
3DMark
Vantage
GPU
Score
Gigabyte
GA-P55 UD4P @ OC
18810
Foxconn
P55A-S @ OC
18806
Gigabyte
GA-P55 UD4P
18148
Foxconn
P55A-S
18142
0 95 00 190
00
CPU
Score
Gigabyte
GA-P55 UD4P @ OC
16292
Foxconn
P55A-S @ OC
16280
Gigabyte
GA-P55 UD4P
12276
Foxconn
P55A-S
12269
0 85 00 170
00
Everest
Read
(MB/s)
Foxconn
P55A-S @ OC
13762
Gigabyte
GA-P55 UD4P @ OC
13440
Foxconn
P55A-S
13039
Gigabyte
GA-P55 UD4P
12986
0 70 00 140
00
Write
(MB/s)
Gigabyte
GA-P55 UD4P @ OC
13003
Foxconn
P55A-S @ OC
12875
Foxconn
P55A-S
9594
Gigabyte
GA-P55 UD4P
9590
0 65 50 131
00
Copy
(MS/s)
Foxconn
P55A-S @ OC
17775
Gigabyte
GA-P55 UD4P @ OC
17573
Gigabyte
GA-P55 UD4P
13655
Foxconn
P55A-S
13400
0 90 00 180
00
Fritz
Chess
Speed
(s)
Gigabyte
GA-P55 UD4P
16,39
Foxconn
P55A-S
16,41
Foxconn
P55A-S @ OC
21,62
Gigabyte
GA-P55 UD4P @ OC
21,83
0 1 1 2
2
Kilo
nodes per second
Gigabyte
GA-P55 UD4P @ OC
10480
Foxconn
P55A-S @ OC
10376
Foxconn
P55A-S
7873
Gigabyte
GA-P55 UD4P
7868
0 52 50 105
00
Nuclearus
MC
ALU
Speed
Gigabyte
GA-P55 UD4P @ OC
6989
Foxconn
P55A-S @ OC
6943
Gigabyte
GA-P55 UD4P
5169
Foxconn
P55A-S
5155
0 35 00 70
00
FPU
Speed
Gigabyte
GA-P55 UD4P @ OC
10232
Foxconn
P55A-S @ OC
10154
Gigabyte
GA-P55 UD4P
7564
Foxconn
P55A-S
7555
0 51 50 103
00
Multi
Thread Speed
Gigabyte
GA-P55 UD4P @ OC
30113
Foxconn
P55A-S @ OC
29856
Gigabyte
GA-P55 UD4P
22290
Foxconn
P55A-S
21091
0 15 100 302
00
wPrime
Time
(s)
Gigabyte
GA-P55 UD4P @ OC
9,326
Foxconn
P55A-S @ OC
9,393
Gigabyte
GA-P55 UD4P
12,481
Foxconn
P55A-S
12,494
0 6 ,5 1
3
Resident
Evil 5
1024×768
(DX10, high)
Gigabyte
GA-P55 UD4P @ OC
125,5
Foxconn
P55A-S @ OC
125,1
Gigabyte
GA-P55 UD4P
102,9
Foxconn
P55A-S
91,8
0 6 3 12
6
Crysis
Warhead
1024×768
(DX10, high)
Gigabyte
GA-P55 UD4P @ OC
86,76
Foxconn
P55A-S @ OC
86,73
Gigabyte
GA-P55 UD4P
81,32
Foxconn
P55A-S
81,23
0 3 0 6 0 9
0
U drugoj seriji testova priča se ponavlja u slučaju 3DMarka, dok se loptica
vraća na GB-ov teren u Everestovom Read test, gdje je Foxconn brži, kao
i u Copy testovima. Write je više manje jednak. U Fritz Chessu, situacija
ponovno ista. Foxconnica je na stock brža, dok ju Gigabyteica skida pri
overclockiranim brzinama. Ista stvar je dešava i kod Nuclearusa koji barata
samo s procesorom. wPrime koji je osjetljiv ne samo na procesor nego i na
memoriju ponovno utvrđuje Gigabyteicu kao bržu. U RE5 vidimo značajnu prednost
GB-ice nad Foxconnicom, što nam je pomalo bilo čudno, no testove smo vrtjeli
više puta, tako da brojke govore same za sebe. U Crysisu nikakve osjetne
razlike, tu je ipak samo kartica na tapeti.
Stranica 4 od 5
