G.Skill RipjawsX DDR3-17000 2 x 2GB – 2133MHz za P67
Zaključak – Conclusion
Cijena se ovome kitu u Njemačkom webshopovima kreće oko 95 – 100 € što je sasvim korektan iznos za ono što on nudi. Cijena je to u prosjeku ostalih 4GB kitova, a G.Skill se potrudio ponuditi puno više od prosjeka. Uz činjenicu kako ovome kitu nije potrebno više od 1.5V napona za rad na 2133MHz pri CL9 latencijama, tu je pridodan kvalitetan i učinkovit heatsink, te unaprijeđeni Turbulence II rashladni sistem. Nije najtiši, no dovoljno je učinkovit da bez bojazni ovu memoriju potjerate na višim naponima i brzinama. Čim se na tržištu pojave ploče s ispravljenim čipsetima ovo je memorije koju definitivno vrijedi uzeti u obzir prilikom nabave. Ukoliko pak želite zaštedjeti koju kunu i modeli s nešto višim latencijama definitivno dolaze u obzir.
Conclusion
While this kit isn`t yet sold in Croatia, its price in Germany is around 100 €, which is very fair. This is an average price for a 2133MHz 4GB kit, but G.Skill has done more than average here. Above average is the fact that this kit doesn’t need more than 1.5V to work on 2133MHz with CL9 latencies, and it has a great heatsink backed up by a very efficient Turbulence II cooler. It is not the quietest out there, but it certainly is a big improvement over the original Turbulence, and efficient enough that you can push this memory on higher frequencies and higher voltages. As soon as the new P67 boards hit the shelves this will be the kit of choice. If you want to save some €, you can even pick the ones with a slightly higher latencies.
Stranica 4 od 4
