G.Skill Trident Z5 RGB DDR5-5600 recenzija
· · MBO i RAM · Stranica 3 od 3
Rezultati testiranja i zaključak
Propusnost XMP profila na Z690 platformi te usporedba s DDR4 memorijom na Z590 platformi
AIDA64 RAM ReadG.Skill Trident Z5 RGB 5.600 MHz: 85.264G.Skill Trident Z5 RGB 5.6…85.264Corsair Dominator Platinum RGB DDR5 5.200 MHz: 82.718Corsair Dominator Platinum…82.718Kingston Fury Beast DDR5 5.200 MHz: 82.266Kingston Fury Beast DDR5 5…82.266Corsair Dominator Platinum RGB DDR5 4.800 MHz: 76.281Corsair Dominator Platinum…76.281G.Skill Trident Z Royal DDR4 4.000 MHz: 63.784G.Skill Trident Z Royal DD…63.784093.790
AIDA64 RAM WriteG.Skill Trident Z5 RGB 5.600 MHz: 78.721G.Skill Trident Z5 RGB 5.6…78.721Corsair Dominator Platinum RGB DDR5 5.200 MHz: 74.199Corsair Dominator Platinum…74.199Kingston Fury Beast DDR5 5.200 MHz: 73.983Kingston Fury Beast DDR5 5…73.983Corsair Dominator Platinum RGB DDR5 4.800 MHz: 69.212Corsair Dominator Platinum…69.212G.Skill Trident Z Royal DDR4 4.000 MHz: 59.079G.Skill Trident Z Royal DD…59.079086.593
AIDA64 RAM CopyG.Skill Trident Z5 RGB 5.600 MHz: 77.160G.Skill Trident Z5 RGB 5.6…77.160Corsair Dominator Platinum RGB DDR5 5.200 MHz: 75.038Corsair Dominator Platinum…75.038Kingston Fury Beast DDR5 5.200 MHz: 74.593Kingston Fury Beast DDR5 5…74.593Corsair Dominator Platinum RGB DDR5 4.800 MHz: 69.869Corsair Dominator Platinum…69.869G.Skill Trident Z Royal DDR4 4.000 MHz: 60.202G.Skill Trident Z Royal DD…60.202084.876
AIDA64 RAM LatencyG.Skill Trident Z5 RGB 5.600 MHz: 70,9G.Skill Trident Z5 RGB 5.6…70,9G.Skill Trident Z Royal DDR4 4.000 MHz: 76,2G.Skill Trident Z Royal DD…76,2Kingston Fury Beast DDR5 5.200 MHz: 78,2Kingston Fury Beast DDR5 5…78,2Corsair Dominator Platinum RGB DDR5 5.200 MHz: 78,7Corsair Dominator Platinum…78,7Corsair Dominator Platinum RGB DDR5 4.800 MHz: 81,9Corsair Dominator Platinum…81,9090
Performanse memorije su izvrsne. Ne čudi naravno da je G.Skill memorija na vrhu grafa jer je nazivno brža od uspoređene konkurencije. Razlika u propusnosti kod overclockinga
AIDA64 RAM ReadG.Skill Trident Z5 RGB 6.400 MHz: 95.377G.Skill Trident Z5 RGB 6.4…95.377G.Skill Trident Z5 RGB 6.000 MHz: 91.937G.Skill Trident Z5 RGB 6.0…91.937G.Skill Trident Z5 RGB 5.600 MHz: 85.264G.Skill Trident Z5 RGB 5.6…85.2640104.915
AIDA64 RAM WriteG.Skill Trident Z5 RGB 6.400 MHz: 87.960G.Skill Trident Z5 RGB 6.4…87.960G.Skill Trident Z5 RGB 6.000 MHz: 84.108G.Skill Trident Z5 RGB 6.0…84.108G.Skill Trident Z5 RGB 5.600 MHz: 78.721G.Skill Trident Z5 RGB 5.6…78.721096.756
AIDA64 RAM CopyG.Skill Trident Z5 RGB 6.400 MHz: 85.249G.Skill Trident Z5 RGB 6.4…85.249G.Skill Trident Z5 RGB 6.000 MHz: 82.059G.Skill Trident Z5 RGB 6.0…82.059G.Skill Trident Z5 RGB 5.600 MHz: 77.160G.Skill Trident Z5 RGB 5.6…77.160093.774
AIDA64 RAM LatencyG.Skill Trident Z5 RGB 6.000 MHz: 67G.Skill Trident Z5 RGB 6.0…67G.Skill Trident Z5 RGB 5.600 MHz: 70,9G.Skill Trident Z5 RGB 5.6…70,9G.Skill Trident Z5 RGB 6.400 MHz: 71,6G.Skill Trident Z5 RGB 6.4…71,6079
Overclocking je zanimljiva priča jer smo postigli vrlo respektabilne brojke, a bez da smo previše podizali napon. S XMP postavkama i frekvencijom od 6.000 MHz vidimo da je latencija najniža, koja počinje rasti kada opustimo latencije memorije. No, propusnost je ta koja nezaustavljivo raste što je viši takt. Razlika u gamingu
Hitman 3 (1280×720)G.Skill Trident Z5 RGB 6.400 MHz: 174,65G.Skill Trident Z5 RGB 6.4…174,65G.Skill Trident Z5 RGB 5.600 MHz: 164,56G.Skill Trident Z5 RGB 5.6…164,560192
Hitman 3 (1280×720)G.Skill Trident Z5 RGB 6.400 MHz: 204,2G.Skill Trident Z5 RGB 6.4…204,2G.Skill Trident Z5 RGB 5.600 MHz: 188,86G.Skill Trident Z5 RGB 5.6…188,860225
Za kraj gaming. Prvi graf predstavlja prosječni broj sličica u sekundi za CPU performanse, a drugi GPU, na način kako to mjeri in-game benchmark Hitmana 3. Na temelju jednog testa ne možemo donijeti generalni zaključak, no porast performansi je ipak znakovit na ovoj niskoj rezoluciji. Jasno, ako se volimo igrati u punim detaljima i najvišoj rezoluciji brža nam memorija neće puno pomoći, no ako ste natjecatelj i bitan vam je samo framerate, tada hoće!
G.Skill i dalje dokazuje da su vrhu proizvođača memorijskih modula, kako po dizjanu i izvedbi, tako i po performansama te overclocking potencijalu. F5-5600J3636C16GX2-TZ5RS kit je na ulaznom dijelu ponude Trident Z5 kitova, no dokazuje kako se nema čega sramiti i ostvarenih 6.400 MHz pri overclockingu je impresivno. Istina, G.Skillovi kitovi su i viših cijena, no ne bez razloga. Odlično su dizajnirani, imaju dobre hladnjake i ne griju se, RGB LED rasvjeta je impresivna, a k tome donose i birane DRAM čipove za visoke performanse. S cijenom od oko 250 € za 32 GB su među skupljima, no svakako su isplativa kupnja, pogotovo ako ste entuzijast i/ili clocker.
Stranica 3 od 3
