G.Skill Trident Z5 RGB DDR5-6800 recenzija
· · MBO i RAM · Stranica 3 od 3
Rezultati testiranja i zaključak
Propusnost XMP profila i usporedba s drugim kitovima
AIDA64 RAM ReadG.Skill Trident Z5 RGB 6.800: 103.140G.Skill Trident Z5 RGB 6.8…103.140G.Skill Trident Z5 RGB 5.600: 85.264G.Skill Trident Z5 RGB 5.6…85.264Corsair Dominator Platinum RGB DDR5 5.200: 82.718Corsair Dominator Platinum…82.718Kingston Fury Beast DDR5 5.200: 82.266Kingston Fury Beast DDR5 5…82.266Corsair Dominator Platinum RGB DDR5 4.800: 76.281Corsair Dominator Platinum…76.281G.Skill Trident Z Royal DDR4 4.000: 63.784G.Skill Trident Z Royal DD…63.7840113.454
AIDA64 RAM WriteG.Skill Trident Z5 RGB 6.800: 90.490G.Skill Trident Z5 RGB 6.8…90.490G.Skill Trident Z5 RGB 5.600: 78.721G.Skill Trident Z5 RGB 5.6…78.721Corsair Dominator Platinum RGB DDR5 5.200: 74.199Corsair Dominator Platinum…74.199Kingston Fury Beast DDR5 5.200: 73.983Kingston Fury Beast DDR5 5…73.983Corsair Dominator Platinum RGB DDR5 4.800: 69.212Corsair Dominator Platinum…69.212G.Skill Trident Z Royal DDR4 4.000: 59.079G.Skill Trident Z Royal DD…59.079099.539
AIDA64 RAM CopyG.Skill Trident Z5 RGB 6.800: 93.906G.Skill Trident Z5 RGB 6.8…93.906G.Skill Trident Z5 RGB 5.600: 77.160G.Skill Trident Z5 RGB 5.6…77.160Corsair Dominator Platinum RGB DDR5 5.200: 75.038Corsair Dominator Platinum…75.038Kingston Fury Beast DDR5 5.200: 74.593Kingston Fury Beast DDR5 5…74.593Corsair Dominator Platinum RGB DDR5 4.800: 69.869Corsair Dominator Platinum…69.869G.Skill Trident Z Royal DDR4 4.000: 60.202G.Skill Trident Z Royal DD…60.2020103.297
AIDA64 RAM LatencyG.Skill Trident Z5 RGB 6.800: 68,2G.Skill Trident Z5 RGB 6.8…68,2G.Skill Trident Z5 RGB 5.600: 70,9G.Skill Trident Z5 RGB 5.6…70,9G.Skill Trident Z Royal DDR4 4.000: 76,2G.Skill Trident Z Royal DD…76,2Kingston Fury Beast DDR5 5.200: 78,2Kingston Fury Beast DDR5 5…78,2Corsair Dominator Platinum RGB DDR5 5.200: 78,7Corsair Dominator Platinum…78,7Corsair Dominator Platinum RGB DDR5 4.800: 81,9Corsair Dominator Platinum…81,9090
Performanse memorije su očekivano izvrsne, s obzirom na to da radi na vrlo visokoj frekvenciji od 3.400 MHz (data rate je 6.800 MT/s – zbog prirode rada DDR memorije). Propusnost je visoka, a latencija niska i bit će odličan izbor za nove Core procesore. Razlika u propusnosti kod overclockinga
AIDA64 RAM ReadG.Skill Trident Z5 RGB 7.600: 111.830G.Skill Trident Z5 RGB 7.6…111.830G.Skill Trident Z5 RGB 7.400: 111.150G.Skill Trident Z5 RGB 7.4…111.150G.Skill Trident Z5 RGB 6.800: 103.140G.Skill Trident Z5 RGB 6.8…103.1400123.013
AIDA64 RAM WriteG.Skill Trident Z5 RGB 7.400: 97.181G.Skill Trident Z5 RGB 7.4…97.181G.Skill Trident Z5 RGB 7.600: 95.807G.Skill Trident Z5 RGB 7.6…95.807G.Skill Trident Z5 RGB 6.800: 90.490G.Skill Trident Z5 RGB 6.8…90.4900106.899
AIDA64 RAM CopyG.Skill Trident Z5 RGB 7.400: 101.570G.Skill Trident Z5 RGB 7.4…101.570G.Skill Trident Z5 RGB 7.600: 100.061G.Skill Trident Z5 RGB 7.6…100.061G.Skill Trident Z5 RGB 6.800: 93.906G.Skill Trident Z5 RGB 6.8…93.9060111.727
AIDA64 RAM LatencyG.Skill Trident Z5 RGB 7.400: 64,6G.Skill Trident Z5 RGB 7.4…64,6G.Skill Trident Z5 RGB 7.600: 65,9G.Skill Trident Z5 RGB 7.6…65,9G.Skill Trident Z5 RGB 6.800: 68,2G.Skill Trident Z5 RGB 6.8…68,2075
Overclocking daje zanimljive rezultate. Dok povećavamo frekvenciju, a zadržavamo latencije performanse lijepo rastu, a vrijeme pristupa pada. No, kada još podignemo frekvenciju, a opustimo latencije samo brzina čitanja raste, dok ostalo stagnira. Pametnije je dakle izvući maksimum na nižim latencijama. Razlika u gamingu
Dirt 5 (1280×720)G.Skill Trident Z5 RGB 7.600 MHz: 166,8G.Skill Trident Z5 RGB 7.6…166,8G.Skill Trident Z5 RGB 7.400 MHz: 163,9G.Skill Trident Z5 RGB 7.4…163,9G.Skill Trident Z5 RGB 6.800 MHz: 159,4G.Skill Trident Z5 RGB 6.8…159,40183
For Honor (1280×720)G.Skill Trident Z5 RGB 7.400 MHz: 388,7G.Skill Trident Z5 RGB 7.4…388,7G.Skill Trident Z5 RGB 7.600 MHz: 387,86G.Skill Trident Z5 RGB 7.6…387,86G.Skill Trident Z5 RGB 6.800 MHz: 384,23G.Skill Trident Z5 RGB 6.8…384,230428
Horizon Zero Dawn (1280×720)G.Skill Trident Z5 RGB 7.400 MHz: 199G.Skill Trident Z5 RGB 7.4…199G.Skill Trident Z5 RGB 7.600 MHz: 197G.Skill Trident Z5 RGB 7.6…197G.Skill Trident Z5 RGB 6.800 MHz: 197G.Skill Trident Z5 RGB 6.8…1970219
Gaming pokazuje porast performansi s frekvencijom memorije u dva od tri naslova, s tim da su i u trećem rasli minimalni broj sličica u sekundi kao i 0,1% low. Opuštanje latencija i forsiranje takta čini se ne šteti performansama kao kod propusnosti, barem u prvom slučaju. No ipak, generalno gledajući, bolje je opet izvući maksimum frekvencije na XMP latencijama.
Kod Intel Core procesora vrijedi čim brža DDR 5 memorija tim bolja. Jedino pravo ograničenje je dakle dubina vašeg džepa. F5-6800J3445G16GX2-TZ5RS kit je odličan ako si ga možete priuštiti jer je već tvornički vrlo brz, a ima i izvrstan overclocking potencijal. Kao i uvijek, moduli su kvalitetno napravljeni i tek se pri overclockingu nešto više zagrijavaju, pa je poželjna zračna struja preko njih. Dizajn je lijep s dvije teksture aluminija, a RGB LED osvjetljenje je efektno. S cijenom u njemačkim shopovima od oko 316 € ovaj kit ne možemo okarakterizirati kao povoljan, no entuzijasti i overclockeri ovdje dobro znaju što plaćaju.
Stranica 3 od 3
