Gigabyte BRIX Pro
· · Računala · Stranica 2 od 4
Rezultati testova – prvi dio
3DMark FirestrikeRadeon HD7730 1GB: 1.602Radeon HD7730 1GB1.602A10-7850K: 1.509A10-7850K1.509A10-7800 @ 65W: 1.428A10-7800 @ 65W1.428i7-4770R: 1.378i7-4770R1.378A8-7600: 1.340A8-76001.340A10-7800 @ 45W: 1.267A10-7800 @ 45W1.267i7-4770K: 892i7-4770K892i7-4790K: 891i7-4790K89101.762
Znali smo da bi Iris Pro 5200 mogla biti brza, no nismo ni slutili koliko. U kombinaciji s moćnim CPU jezgrama rezultat se penje vrlo blizu najjačim AMD APU-ima.
7-ZIPi7-4790K: 26.327i7-4790K26.327i7-4770K: 23.564i7-4770K23.564i7-4770R: 21.886i7-4770R21.886i5-4670K: 17.203i5-4670K17.203i5-3470: 16.807i5-347016.807i5-2500K: 14.254i5-2500K14.254A10-6800K: 12.012A10-6800K12.012A10-7850K: 11.711A10-7850K11.711A10-6700: 11.642A10-670011.642A10-7800 @ 65W: 11.454A10-7800 @ 65W11.454A10-5800K: 11.237A10-5800K11.237A8-7600: 10.985A8-760010.985A10-5700: 10.519A10-570010.519A10-7800 @ 45W: 9.350A10-7800 @ 45W9.350028.960
CPU performanse nisu upitne i 4770R ovdje briljira, te se smješta tik ispod 4770K modela.
Cinebench 11.5i7-4790K: 9,68i7-4790K9,68i7-4770K: 8,51i7-4770K8,51i7-4770R: 7,82i7-4770R7,82i5-4670K: 6,5i5-4670K6,5i5-3470: 6,06i5-34706,06i5-2500K: 5,51i5-2500K5,51A10-6800K: 3,58A10-6800K3,58A10-7850K: 3,58A10-7850K3,58A8-7800 @ 65W: 3,47A8-7800 @ 65W3,47A8-7600: 3,42A8-76003,42A10-6700: 3,38A10-67003,38A10-5800K: 3,32A10-5800K3,32A10-5700: 3,03A10-57003,03A8-7800 @ 45W: 3,0A8-7800 @ 45W3,0011
Ponovno, samo potvrda izvrsnih CPU performansi.
x.264 Benchmark v5.0 Pass 1i7-4770R: 72,21i7-4770R72,21i5-4670K: 62,63i5-4670K62,63A10-7850K: 36,04A10-7850K36,04A10-7800: 34,85A10-780034,85A8-7600: 34,7A8-760034,7079
I transcoding će ovaj procesor odraditi s lakoćom.
PotrošnjaA10-5700: 88A10-570088i7-4770R: 90i7-4770R90A10-6700: 93A10-670093A10-7800 @ 45W: 100A10-7800 @ 45W100A8-7600: 109A8-7600109A10-5800K: 109A10-5800K109A10-6800K: 112A10-6800K112i5-4670K: 114i5-4670K114A10-7800 @ 65W: 119A10-7800 @ 65W119A10-7850K: 120A10-7850K120i7-4770K: 135i7-4770K135i7-4790K: 165i7-4790K1650170
Velika odlika Haswella je niska potrošnja. Jasno je kako je BRIX ima efikasnije napajanje od onoga kojeg smo koristili kod APU testova, no svejedno, što god radili ovaj procesor nije htio trošiti iznad 90W. Buka i zagrijavanje su druga strana medalje ovoga izvrsnog strojčića. Pri nikakvom ili minimalnom opterećenju ventilator je praktički nečujan no čim procesor opteretimo, bilo zahtjevnim CPU ili GPU zadatkom buka postaje vrlo visoka i u pojedinim se trenucima penje i do vrlo čujnih 59 dB, kada je BRIX neugodno slušati. Temperature su također visoke i penju se i preko 90°C što se odražava i na toplinu malenog kućišta. Jasno je, ovakva se procesna i grafička snaga negdje mora osjetiti, a BRIX-ovo je kućište jednostavno premaleno za ovu zvijer.
Stranica 2 od 4
